查看: 4523|回復: 1
AVR_點亮LED程序
ID:80436 發表于 2015-5-22 01:11 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
很糾結的用ICC AVR寫了個程序。調試通過,木有仿真下載線。貌似挺貴,
窮人家的孩子買不起。鉆研下做個AVR ISP還是比較靠譜,加油!
#include <iom16v.h>
#include <macros.h>
#define  uchar unsigned char
#define  uint  unsigned int
void delay(uint ms)
    uint i,j;
for(i=0;i<ms;i++)
    for(j=0;j<1141;j++);
   uchar k;
   DDRA|=BIT(2);
   PORTA|=BIT(2);//我表示AVR的位操作比51單片機更加復雜,|運算是關鍵
   DDRB=0XFF;
   PORTB=0XFF;
   for(k=0;k<8;k++) //for語句
   PORTB&=~BIT(k);//取反操作
   delay(500);//延時500ms
   PORTB|=BIT(k);
   delay(500);
}//我靠!寫完了。滾床睡覺,很晚了, 明天是該死的體育考試,oh my god
ID:80436 發表于 2015-5-22 01:17 | 只看該作者
  1. #include <iom16.h>
  2. #include <macros.h>
  3. /* This seems to produce the right amount of delay for the LED to be
  4. * seen
  5. */
  6. void Delay()
  7. {
  8. unsigned char a, b;
  9. for (a = 1; a; a++)
  10. for (b = 1; b; b++)
  11. ;
  12. }
  13. void LED_On(int i)
  14. {
  15. PORTB = ~BIT(i);        /* low output to turn LED on */
  16. Delay();
  17. }
  18. void main()
  19. {
  20. int i;
  21. DDRB = 0xFF;        /* output */
  22. PORTB = 0xFF;        /* all off */
  23. while (1)
  24. {
  25. /* forward march */
  26. for (i = 0; i < 8; i++)
  27. LED_On(i);
  28. /* backward march */
  29. for (i = 8; i > 0; i--)
  30. LED_On(i);
  31. /* skip */
  32. for (i = 0; i < 8; i += 2)
  33. LED_On(i);
  34. for (i = 7; i > 0; i -= 2)
  35. LED_On(i);
  36. }
  37. }
