查看: 2768|回復: 0
格式化輸出算法實現
ID:80436 發表于 2015-5-21 23:30 | 顯示全部樓層 |閱讀模式
屏幕顯示
//功能:往屏幕上Location的位置寫入字符t(字符的ascii碼為t)
//定義:void PutChar(char t,int Location)
//參數:char t,int Location
//返回值:NULL
int addr = 0;
if(Location<= 15)
addr =128+Location;
addr = 176 + Location;
lcd1602_write_char(0,addr);
delay_nms(25);
  RW_L;
E_L;
lcd1602_write_char(1,t);
delay_nms(25);
屏幕顯示
//功能:往屏幕上寫入字符串s
//定義:void PutString(unsigned char *s)
//參數:unsigned char *s字符串的指針
//返回值:NULL
int i=0;
int index=0;
//LCD_clear();
for( i=0 ;i<=48;i++)
if(s[i] =='\n')
if (i<=15){i =15;}
else{break;}
index=index+1;
else if (s[i] == '\0')
break;
PutChar(s[index],i);
index=index+1;
//整型轉換為字符串//
void itoa(int data, char *buf, char radix)
unsigned char static i, len;
int DBUF, mod;
DBUF=data;
//轉成二進制
if(radix==2)
for(len=0; ;len++)
DBUF=DBUF/2;
if(DBUF==0)
break;
DBUF=data;
for(i=0; i<=len; i++)
*(buf+len-i)=DBUF%2+'0';
DBUF=DBUF/2;
//轉成10進制
if(radix==10)
for(len=0; ;len++)
DBUF=DBUF/10;
if(DBUF==0)
break;
DBUF=data;
*(buf+len-i)=DBUF%10+'0';
DBUF=DBUF/10;
//轉成16進制
if(radix==16)
for(len=0; ;len++)
DBUF=DBUF/10;
if(DBUF==0)
break;
DBUF=data;
mod=DBUF%16;
if(mod<10)
*(buf+len-i)=mod+'0';
*(buf+len-i)=mod-10+'A';
DBUF=DBUF/16;
屏幕顯示
//功能:printf函數的一個實現
//定義:int Printf(const char *fmt, ...)__arm
//參數:const char *fmt, ...
//返回值:NULL
    const char *s;
char *Buf;
    int d;
float f;
char tbuf[16], i=0;
char ShowBuf[40]={' '};
    va_list ap;
    va_start(ap, fmt);
    Buf=ShowBuf;
    while (*fmt)
for(i=0; i<sizeof(tbuf); i++)
tbuf[i]=0;
        if (*fmt != '%')
            *Buf++=*fmt++;
            continue;
        switch (*++fmt) {
//字符串
            case 's':
                s = va_arg(ap, const char *);
if (s == NULL) {break;}
                for ( ; *s; s++) {
                    *Buf++=*s;
                break;
//二進制
            case 'b':
                d = va_arg(ap, int);
                itoa(d, tbuf, 2);
                for (i=0; tbuf[i]!='\0';i++) {
                    *Buf++=tbuf[i];
                break;
//十進制
            case 'd':
                sprintf(tbuf, "%d",d);
                    *Buf++=tbuf[i];
                break;
   //十六進制
           case 'x':
                sprintf(tbuf, "%x",d);
                    *Buf++=tbuf[i];
                break;
           case 'f':
                f = va_arg(ap, double);
                sprintf(tbuf, "%f",f);
                    *Buf++=tbuf[i];
                break;
            // Add other specifiers here...
            default:
                *Buf++=*fmt++;
                break;
        fmt++;
*Buf='\0';
    va_end(ap);
//CLRVLCD(0);
//PrintfVLCD(ShowBuf);
//CpyVLCDToLCD();
//sprintf(ShowBuf,"b=%d",i);
       // if (  ScreenNeedClear  == 1) {PutString("                                ");}
PutString(ShowBuf);
    return 1;   // Dummy return value
屏幕顯示
