查看: 3177|回復: 0
STM32 ADC多通道 關鍵代碼
ID:80436 發表于 2015-5-20 14:41 | 顯示全部樓層 |閱讀模式
define ADC1_DR_Address    ((u32)0x4001244C)
vu16 AD_Value[2];
關鍵代碼
void ADC1_Configuration(void)
    ADC_InitTypeDef ADC_InitStructure;
    ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
    ADC_InitStructure.ADC_ScanConvMode = ENABLE;
    ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //連續轉換開啟
    ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
    ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
    ADC_InitStructure.ADC_NbrOfChannel = 2;     //設置轉換序列長度為2
    ADC_Init(ADC1, &ADC_InitStructure);
    //ADC內置溫度傳感器使能(要使用片內溫度傳感器,切忌要開啟它)
    ADC_TempSensorVrefintCmd(ENABLE);
    //常規轉換序列1:通道10
    ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_13Cycles5);
    //常規轉換序列2:通道16(內部溫度傳感器),采樣時間>2.2us,(239cycles)
    ADC_RegularChannelConfig(ADC1, ADC_Channel_16, 2, ADC_SampleTime_239Cycles5);
    // Enable ADC1
    ADC_Cmd(ADC1, ENABLE);
    // 開啟ADC的DMA支持(要實現DMA功能,還需獨立配置DMA通道等參數)
    ADC_DMACmd(ADC1, ENABLE);
    // 下面是ADC自動校準,開機后需執行一次,保證精度
    // Enable ADC1 reset calibaration register
    ADC_ResetCalibration(ADC1);
    // Check the end of ADC1 reset calibration register
    while(ADC_GetResetCalibrationStatus(ADC1));
    // Start ADC1 calibaration
    ADC_StartCalibration(ADC1);
    // Check the end of ADC1 calibration
    while(ADC_GetCalibrationStatus(ADC1));
    // ADC自動校準結束---------------
* Function Name : DMA_Configuration
* Description    : DMA設置:從ADC模塊自動讀轉換結果至內存
* Input          : None
* Output         : None
* Return         : None
void DMA_Configuration(void)
    DMA_InitTypeDef DMA_InitStructure;
    DMA_DeInit(DMA1_Channel1);
    DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
    DMA_InitStructure.DMA_MemoryBaseAddr = (u32)AD_Value;  //AD_Value為數組地址
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
    //BufferSize=2,因為ADC轉換序列有2個通道
    //如此設置,使序列1結果放在AD_Value[0],序列2結果放在AD_Value[1]
    DMA_InitStructure.DMA_BufferSize = 2;
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
    //循環模式開啟,Buffer寫滿后,自動回到初始地址開始傳輸
    DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
    DMA_InitStructure.DMA_Priority = DMA_Priority_High;
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
    DMA_Init(DMA1_Channel1, &DMA_InitStructure);
    //配置完成后,啟動DMA通道
    DMA_Cmd(DMA1_Channel1, ENABLE);
