EEPROM.H stc單片機片內(nèi)存儲器的操作頭文件下載:
#ifndef _EERPOM_H_
#define _EEPROM_H_
#include <reg51.h>
#include "intrins.h"
#define nop() _nop_()
#define uint8 unsigned char
#define uint16 unsigned int
/*Declare SFR associated with the IAP */
sfr IAP_DATA = 0xC2; //Flash data register
sfr IAP_ADDRH = 0xC3; //Flash address HIGH
sfr IAP_ADDRL = 0xC4; //Flash address LOW
sfr IAP_CMD = 0xC5; //Flash command register
sfr IAP_TRIG = 0xC6; //Flash command trigger
sfr IAP_CONTR = 0xC7; //Flash control register
/*Define ISP/IAP/EEPROM command*/
#define CMD_IDLE 0 //Stand-By
#define CMD_READ 1 //Byte-Read
#define CMD_PROGRAM 2 //Byte-Program
#define CMD_ERASE 3 //Sector-Erase
/*Define ISP/IAP/EEPROM operation const for IAP_CONTR*/
//#define ENABLE_IAP 0x80 //if SYSCLK<30MHz
#define ENABLE_IAP 0x81 //if SYSCLK<24MHz
//#define ENABLE_IAP 0x82 //if SYSCLK<20MHz
//#define ENABLE_IAP 0x83 //if SYSCLK<12MHz
//#define ENABLE_IAP 0x84 //if SYSCLK<6MHz
//#define ENABLE_IAP 0x85 //if SYSCLK<3MHz
//#define ENABLE_IAP 0x86 //if SYSCLK<2MHz
//#define ENABLE_IAP 0x87 //if SYSCLK<1MHz
//Start address for STC11/10xx EEPROM
//#define IAP_ADDRESS 0x0400
//Start address for STC12C5A60S2 EEPROM
#define IAP_ADDRESS 0x0000
void EEPROMDelay(uint8 n)
uint16 x;
while (n--)
x =125;
while (x--);
* 名稱 : IapIdle();
* 功能 : 關(guān)閉IAP EEPROM編輯功能,安全操作
void IapIdle()
IAP_CONTR = 0; //Close IAP function
IAP_CMD = 0; //Clear command to standby
IAP_TRIG = 0; //Clear trigger register
IAP_ADDRH = 0x80; //Data ptr point to non-EEPROM area
IAP_ADDRL = 0; //Clear IAP address to prevent misuse
* 名稱 : IapReadByte(0x0000);
* 功能 : 讀扇區(qū)
uint8 IapReadByte(uint16 addr)
uint8 dat; //Data buffer
IAP_CONTR = ENABLE_IAP; //Open IAP function, and set wait time
IAP_CMD = CMD_READ; //Set ISP/IAP/EEPROM READ command
IAP_ADDRL = addr; //Set ISP/IAP/EEPROM address low
IAP_ADDRH = addr >> 8; //Set ISP/IAP/EEPROM address high
IAP_TRIG = 0x5a; //Send trigger command1 (0x5a)
IAP_TRIG = 0xa5; //Send trigger command2 (0xa5)
nop(); //MCU will hold here until ISP/IAP/EEPROM operation complete
dat = IAP_DATA; //Read ISP/IAP/EEPROM data
IapIdle(); //Close ISP/IAP/EEPROM function
return dat; //Return Flash data
* 名稱 : IapEraseSector(0x0000);
* 功能 : 扇區(qū)擦除
void IapEraseSector(uint16 addr)
IAP_CMD = CMD_ERASE; //Set ISP/IAP/EEPROM ERASE command
IapIdle();
* 名稱 : IapProgramByte(0x0000,data);
* 功能 : 扇區(qū)編輯
void IapProgramByte(uint16 addr, uint8 dat)
IAP_CMD = CMD_PROGRAM; //Set ISP/IAP/EEPROM PROGRAM command
IAP_DATA = dat; //Write ISP/IAP/EEPROM data
IapIdle();
* 名稱 : IapProgramWord(0x0000,data);
* 功能 : 十六位扇區(qū)編輯
void IapProgramWord(uint16 addr, uint16 dat)
uint8 dat_L,dat_H;
dat_L=dat;
dat_H=dat >> 8;
IAP_ADDRL = addr+0x0001;
IAP_ADDRH = (addr+0x0001)>> 8;
IAP_DATA = dat_H;
IAP_TRIG = 0x5a;
IAP_TRIG = 0xa5;
nop();
IapIdle();
IAP_ADDRL = addr;
IAP_DATA = dat_L;
IAP_TRIG = 0x5a;
IAP_TRIG = 0xa5;
nop();
IapIdle();
* 名稱 : IapReadWord(0x0000);
* 功能 : 讀十六位扇區(qū)
uint16 IapReadWord(uint16 addr)
uint16 dat; //Data buffer
uint8 dat_H,dat_L;
IAP_ADDRL = (addr+0x0001); //Set ISP/IAP/EEPROM address low
IAP_ADDRH = (addr+0x0001) >> 8; //Set ISP/IAP/EEPROM address high
dat_H = IAP_DATA; //Read ISP/IAP/EEPROM data
IapIdle();
dat_L= IAP_DATA; //Read ISP/IAP/EEPROM data
dat=(dat_H << 8)+dat_L;
#endif
