查看: 2789|回復: 0
單片機c51怎么實現兩個8x8點陣三色變化,就是模擬交通信號燈,當一邊紅色,另一邊...
ID:79568 發表于 2015-5-10 21:17 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
file:///c:/users/278475044/appdata/roaming/360se6/User Data/temp/8718367adab44aedac7f0356b61c8701a18bfb4b.jpgfile:///c:/users/278475044/appdata/roaming/360se6/User Data/temp/b812c8fcc3cec3fdcd7f04b8d288d43f869427bd.jpgfile:///c:/users/278475044/appdata/roaming/360se6/User Data/temp/b812c8fcc3cec3fdcd7f04b8d288d43f869427bd.jpgfile:///c:/users/278475044/appdata/roaming/360se6/User Data/temp/a233ddc451da81cb08a720005666d01608243112.jpg
單片機c51怎么實現兩個8x8點陣三色變化,就是模擬交通信號燈,當一邊紅色,另一邊綠色,當一邊紅色,另一邊黃色
