查看: 9985|回復: 2
STemWIN顯示中文字體
ID:75926 發表于 2015-4-10 17:22 | 顯示全部樓層 |閱讀模式
想讓STemWIN顯示中文字體首先要移植了文件系統和STemWIN才行.
#include"GUI.h"
#include "ff.h"
GUI_XBF_DATA XBF_Data;
GUI_FONT     XBF_Font;
FIL          Fontfile;//定義文件
FRESULT result;//文件操作標準
uint32_t br,bw;//
FATFSfatfs;//定義文件系統
*       _cbGetData
* Function description
*   Callback function for getting font data
* Parameters:
*   Off      - Position of XBF file to be read文件內偏移量
*   NumBytes - Number of requested bytes需要讀取的文件數量
*   pVoid    - Application defined pointer//文件指針
*   pBuffer  - Pointer to buffer to be filled by the function讀出來的文件數據緩沖區
* Return value:
*   0 on success, 1 on error
static int _cbGetData(U32 Off, U16 NumBytes, void * pVoid, void * pBuffer)
FIL *FontFile;
/* The pVoid pointer may be used to get a file handle */
FontFile = (FIL *)pVoid;
* Set file pointer to the required position
result =f_lseek(FontFile, Off);
if (result != FR_OK)
return 1; /* Error */
* Read data into buffer
result = f_read(FontFile, pBuffer, NumBytes, &bw);
return 0;
            f_mount(0,&fatfs);
result = f_open(&Fontfile, "0:/Font.xbf", FA_OPEN_EXISTING | FA_READ | FA_OPEN_ALWAYS);//黑色字體的字符串是 字體的文件名
return;
// Create XBF font
GUI_XBF_CreateFont(&XBF_Font,       // Pointer to GUI_FONT structure in RAM(3)
&XBF_Data,         // Pointer to GUI_XBF_DATA structure in RAM
GUI_XBF_TYPE_PROP_AA4_EXT, // Font type to be created
_cbGetData,        // Pointer to callback function
&Fontfile);
GUI_UC_SetEncodeUTF8();
//紅色字體的代碼在主函數中調用
//這是顯示效果 上張圖片看看
ID:139917 發表于 2016-9-20 14:50 | 顯示全部樓層
贊
ID:191494 發表于 2017-4-20 09:10 | 顯示全部樓層
你好,請問用STemWIN顯示字體是鏡像的怎么辦?
