查看: 4275|回復: 4
矩陣鍵盤16乘16高效率程序(新算法)
ID:76556 發表于 2015-4-10 02:43 | 顯示全部樓層 |閱讀模式
電路圖下載:http://www.raoushi.com/f/ks51.pdf
  1. #include<reg52.h>
  2. sbit ADDR0 = P1^0;
  3. sbit ADDR1 = P1^1;
  4. sbit ADDR2 = P1^2;
  5. sbit ADDR3 = P1^3;
  6. sbit ENLED = P1^4;
  7. sbit KEY_IN1 = P2^4;
  8. sbit KEY_IN2 = P2^5;
  9. sbit KEY_IN3 = P2^6;
  10. sbit KEY_IN4 = P2^7;
  11. sbit KEY_OUT1 = P2^3;
  12. sbit KEY_OUT2 = P2^2;
  13. sbit KEY_OUT3 = P2^1;
  14. sbit KEY_OUT4 = P2^0;
  15. unsigned char code LedChar[]={
  16. 0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,
  17. 0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E
  18. };
  19. unsigned char Key_Buff[4][4]={{1,1,1,1},{1,1,1,1},{1,1,1,1},{1,1,1,1}};
  20. void T0_Init()
  21. {
  22. EA = 1;
  23. TMOD = 0x01;
  24. TH0 = 0xFC;
  25. TL0 = 0x67;
  26. ET0 = 1;
  27. TR0 = 1;
  28. }
  29. void main()
  30. {
  31. unsigned char Key_Loosen[4][4]={{1,1,1,1},{1,1,1,1},{1,1,1,1},{1,1,1,1}};
  32. ENLED = 0;
  33. ADDR3 = 1;
  34. ADDR2 = 0;
  35. ADDR1 = 0;
  36. ADDR0 = 0;
  37. P0 = LedChar[0];
  38. P2=0xff;
  39. T0_Init();
  40. while(1)
  41. {
  42. unsigned char Num2,Num4;
  43. for(Num4=0;Num4<4;Num4++)
  44. {
  45. for(Num2=0;Num2<4;Num2++)
  46. {
  47. if(Key_Loosen[Num4][Num2]!=Key_Buff[Num4][Num2])
  48. // 第一遍(最開始backup[i][j]的值等于1)        第二遍(由于KeySta[i][j]的值附給了backup[i][j],,backup[i][j]的值等于0,但是KeySta[i][j]的值任然等于0,由于if(backup[i][j] != KeySta[i][j])才能進入此程序所以KeySta[i][j]的值必須等于1,而KeySta[i][j]的值等于1的唯一辦法就是松開按鍵,按鍵松開KeySta[i][j]的值等于1便進入了
  49. {
  50. if(Key_Loosen[Num4][Num2]==0)
  51. //第一遍(backup[i][j]的值任然等于1所以無法進入if)        第二遍(此時backup[i][j] == 0便順理成章的進入了
  52. {
  53. P0 = LedChar[Num4*4+Num2];
  54. }
  55. Key_Loosen[Num4][Num2]=Key_Buff[Num4][Num2];
  56. //第一遍(KeySta[i][j]的值附給了backup[i][j],所以此時backup[i][j]的值等于0)        第二遍(由于此時KeySta[i][j]的值等于1,而KeySta[i][j]又把自己的值賦給了        backup[i][j],所以backup[i][j]的值又回到了初始化時的1)Over^-^
  57. }
  58. }
  59. }
  60. }
  61. }
  62. void InterruptTimer0() interrupt 1
  63. {
  64. unsigned char Num1;
  65. static unsigned char Keys=0;
  66. TH0 = 0xFC;
  67. TL0 = 0x67;
  68. Key_Buff[Keys][0]=(Key_Buff[Keys][0]<<1)|KEY_IN1;
  69. Key_Buff[Keys][1]=(Key_Buff[Keys][1]<<1)|KEY_IN2;
  70. Key_Buff[Keys][2]=(Key_Buff[Keys][2]<<1)|KEY_IN3;
  71. Key_Buff[Keys][3]=(Key_Buff[Keys][3]<<1)|KEY_IN4;
  72. for(Num1=0;Num1<4;Num1++)
  73. {
  74. if((Key_Buff[Keys][Num1]&0x0f)==0x00)
  75. {
  76. Key_Buff[Keys][Num1]=0;
  77. }
  78. }
  79. Keys++;
  80. Keys=Keys&0x03;
  81. switch(Keys)
  82. {
  83. case 0:KEY_OUT4=1;KEY_OUT1=0;break;
  84. case 1:KEY_OUT1=1;KEY_OUT2=0;break;
  85. case 2:KEY_OUT2=1;KEY_OUT3=0;break;
  86. case 3:KEY_OUT3=1;KEY_OUT4=0;break;
  87. }
  88. }
  89. //注意數組也會重新初始化!
  90. 設計者:薛羽豪
ID:76556 發表于 2015-4-10 02:44 | 顯示全部樓層
矩陣鍵盤的一種新算法         程序運行效率超高
根本沒用延時
注意for語句的特殊性
數組沒加code函數的話內部的數值是可以更改的
鄭重聲明:0. 飛過漠北的南天只是馬家溝皇家核工業高級技工專修學院的一名學生, 不是什么大神,只是傻 B 一個,菜鳥一枚!大神們請自覺繞道, 拍磚可以, 但切莫人生攻擊!!
1.  本文所寫程序,過程不一定是最規范的,但一定是對的,因為這是 哥自己試驗過得, 證明是可行的。3. 本文所有權,解釋權,都歸飛過漠北的南天所有!若有轉載,請注明出處!4. 如有問題, 請聯系
但是。。。有問題也不一定回,
注意:數組也會重興初始化,如果不能移動數組的話,最好的方法是將數組定義為靜態變量,(默認情況下數組都是動態變量即自動變量)
