查看: 3205|回復: 0
單片機-數碼管、LED多任務匯編語言編程
ID:75926 發表于 2015-4-4 02:29 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
Time1                 Equ           65535-1000+5
LedPort               Equ           P1
SegCS                 Equ           2000H
SegDisPlay            Equ           0000H
FlagUnit              Equ           20H
Sec0001F              Bit           FlagUnit.0
Sec001F               Bit           FlagUnit.1
Sec01F                Bit           FlagUnit.2
SecondF               Bit           FlagUnit.3
MinuteF               Bit           FlagUnit.4
Sec0001               Data          22H
Sec001                Data          23H
Sec01                 Data          24H
Second                Data          25H
Minute                Data          26H
CSNum                 Data          27H
LedNum                Data          28H
SegNum                Data          29H
;2Ah..2fh
DisBuf                Equ           30H;..35h
                      Org           0000H
                      Ajmp          Main
                      Org           001BH
                      Mov           TL1,#Low(Time1)
                      Mov           TH1,#High(Time1)
                      AJmp          CTCEntry
CTCEntry:             Setb          Sec0001F
                      Djnz          Sec0001,CTCEntryQ
                      Mov           Sec0001,#10
                      Setb          Sec001F
                      Djnz          Sec001,CTCEntryQ
                      Mov           Sec001,#10
                      Setb          Sec01F
                      Djnz          Sec01,CTCEntryQ
                      Mov           Sec01,#10
                      Setb          SecondF
                      Djnz          Second,CTCEntryQ
                      Mov           Second,#60
                      Setb          MinuteF
CTCEntryQ:            RetI
InitSysT:       Mov           TMod,#00000001B
                      Mov           TL1,#Low(Time1)
                      Setb          EA
                      Setb          ET1
                      Setb          TR1
                      Mov           Sec0001,#10
                      Mov           Sec001,#10
                      Mov           Sec01,#10
                      Mov           Second,#10
                      Clr           Sec0001F
                      Clr           Sec001F
                      Clr           Sec01F
                      Clr           SecondF
                      Clr           MinuteF
                      Ret
InitSeg:              Mov           DisBuf+0,#0
                      Mov           DisBuf+1,#1
                      Mov           DisBuf+2,#2
                      Mov           DisBuf+3,#3
                      Mov           DisBuf+4,#4
                      Mov           DisBuf+5,#5
                      AJmp          InitDis
InitLed:
                      Mov           LedNum,#0
                      Ret
Delay:                Mov           R6,#0
Delay1:               Mov           R7,#0
Delay2:               Djnz          R7,Delay2
                      Djnz          R6,Delay1
                      Ret
Ledplay:              Mov           Dptr,#LedTab1
                      Mov           A,LedNum
                      Movc          A,@A+Dptr
                      Mov           LedPort,A
                      Inc           LedNum
                      Mov           A,LedNum
                      Cjne          A,#8,LedQ
                      Mov           LedNum,#0
LedQ:                 Ret
LedTab1:              DB            11111110B
                      DB            11111101B
                      DB            11111011B
                      DB            11110111B
                      DB            11101111B
                      DB            11011111B
                      DB            10111111B
                      DB            01111111B
LedTab2:
SegPlay:              Mov           A,CSNum
                      Mov           Dptr,#SegCS
                      MovX          @Dptr,A
                      Rl            A
                      Mov           CSNum,A
                      Mov           Dptr,#DisTab
                      Mov           R0,SegNum
                      Mov           A,@R0
                      Movc          A,@A+Dptr
                      Mov           Dptr,#SegDisplay
                      Movx          @Dptr,A
                      Inc           SegNum
                      Mov           A,SegNum
                      Cjne          A,#DisBuf+6,SegPlayQ
InitDis:              Mov           CSNum,#00000001B
                      Mov           SegNum,#DisBuf
SegPlayQ:             Ret
;                     Char          "0" ,"1" ,"2" ,"3" ,"4","5","6","7","8"
DisTab:               DB            0c0h,0f9h,0a4h,0b0h,99h,92h,82h,0f8h,80h
Main:                 Mov           SP,#07H
                      Acall         Delay
                      Acall         InitSysT
                      Acall         InitSeg
                      Acall         InitLed
MainLoop :            Jbc           Sec0001F,DoSec0001
                      Jbc           Sec001F,DoSec001
                      Jbc           Sec01F,DoSec01
                      Jbc           SecondF,DoSecond
                      Jbc           MinuteF,DoMinute
                      Ajmp          MainLoop
DoSec0001:
                      Ajmp          MainLoop
DoSec001:
                      Acall         SegPlay
                      Ajmp          MainLoop
DoSec01:
                      Ajmp          MainLoop
DoSecond:             Acall         Ledplay
                      Ajmp          MainLoop
DoMinute:
                      Ajmp          MainLoop
                      End
