//有一路報警輸出,可設(shè)置報警時間 //實間時間請調(diào)整TH1,TL1值使更準(zhǔn)確 //designed by ljc,gdwm ceramic com,.ltd #include<at89x51.h> #define uchar unsigned char #define uint unsigned int #define segment P0 //數(shù)碼管顯示 #define wei P2 //數(shù)碼管位控制 uchar hour,min,sec; //定義小時,分 uchar ms; //當(dāng)前毫秒 uchar alarm_h1,alarm_m1;//報警設(shè)置,hour,minute; uchar alarm_h2,alarm_m2; sbit flash=P1^0; //秒閃爍標(biāo)志 sbit seth=P3^0; //小時設(shè)置 sbit setm=P3^1; //分設(shè)置 sbit seta1h=P3^2; //alarm1 set sbit seta1m=P3^3; //alarm1 set sbit alarm_out=P1^7; //設(shè)定時間到,報警輸出 bit hour_min_sign; //時,分設(shè)置標(biāo)志 bit pop_key; //鍵彈起標(biāo)志 uchar code design[10]={0x28, 0x7E, 0xA2, 0x62, 0x74, 0x61, 0x21, 0x7A, 0x20, 0x60};//0,1,2,3,4,5,6,7,8,9 //************************************************* //********** void delay(uint i) { uint j; for(;i>0;i--) for(j=0;j<120;j++) {;} } //************************************************* //********** void initial() { TMOD=0x01; TH0=0X3C; //50ms定時 TL0=0xc0; EA=1; ET0=1; TR0=1; //報警時間初使化 alarm_h1=7; alarm_m1=0; alarm_h2=14; alarm_m2=0; } //************************************************* //********** void time0_int() interrupt 1 { TH0=0x3c; TL0=0xc0; if(ms<20) { ms++;} else { ms=0; sec++; if(sec>59) { sec=0; min++; if(min>59) { min=0; hour++; if(hour>=24) { hour=0;} } } } if(ms>10){flash=1;} else{flash=0;} } //************************************************ //********* void display(uchar h,m,ah1,am1) { uchar hh,hl,mh,ml,hh1,hh2,mm1,mm2; hh=h/10; hl=h%10; mh=m/10; ml=m%10; hh1=ah1/10;hh2=ah1%10;mm1=am1/10;mm2=am1%10; //報警時間顯示 // segment=design[hh]; wei=0xef; delay(2); // segment=design[hl]; wei=0xdf; delay(2); // segment=design[mh]; wei=0xbf; delay(2); // segment=design[ml]; wei=0x7f; delay(2); //報警顯示 segment=design[hh1]; wei=0xfe; delay(5); segment=design[hh2]; wei=0xfd; delay(2); segment=design[mm1]; wei=0xfb; delay(2); segment=design[mm2]; wei=0xf7; delay(2); } //************************************************ //鍵防拌處理********** void scan_key(bit set_h_m) { if(!set_h_m) { delay(30); if(!set_h_m) { delay(10); hour_min_sign=1; } else{hour_min_sign=0;} } while(set_h_m&hour_min_sign)//等街鍵彈起 { delay(30); if(set_h_m&hour_min_sign) { delay(10); pop_key=1; } //鍵彈起標(biāo)志 hour_min_sign=0; } } //時間設(shè)置**************************************** //********** void time_set() { pop_key=0; scan_key(seth); if(pop_key) //小時鍵按下,小時加1 { if(hour>23) { hour=0;} else{hour++;} display(hour,min,alarm_h1,alarm_m1); } pop_key=0; // scan_key(setm); //分鍵按下,分加1 if(pop_key) { if(min>59) { min=0;} else{min++;} display(hour,min,alarm_h1,alarm_m1); } pop_key=0; } //*********************************************** //報警時間設(shè)置:小時,分鐘* //有報警時間設(shè)置功能,延時關(guān)閉功能 void alarm() { //報警1 pop_key=0; scan_key(seta1h); //報警1設(shè)置 if(pop_key) { alarm_h1++; if(alarm_h1>23) { alarm_h1=0;} } pop_key=0; display(hour,min,alarm_h1,alarm_m1); scan_key(seta1m); if(pop_key) { alarm_m1++; if(alarm_m1>59) { alarm_m1=0;} } display(hour,min,alarm_h1,alarm_m1); if((hour==alarm_h1)&(min==alarm_m1))//相等 { alarm_out=0;} //報警輸出 } //*********************************************** //************************* void main() { initial(); for(;;) { time_set(); //時間設(shè)置 display(hour,min,alarm_h1,alarm_m1); alarm(); } }
