查看: 2719|回復: 0
有高手能改下這個倒計時程序嗎?
ID:73480 發表于 2015-3-4 20:19 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
如果改成這樣,應該怎么改?:初始時間及定時時間可調,且動態顯示剩余時間,并在最后一分鐘發出警告聲,時間到提醒。
轉:倒計時器帶鬧c程序,最長定時99:59,時間到,鬧鈴10秒,已在學習板上通過,稍改后可用于控制其他負載。剛學請各位老師指導!用數碼管顯示的吧,電路下載:http://www.raoushi.com/f/ks51.pdf
#include <reg52.h>
typedef  unsigned char   uint8;
typedef  unsigned int    uint16;
code uint8 number[] = {0xc0,0xf9,0xa4,0xb0,
                                              0x99,0x92,0x82,0xf8,
                                            0x80,0x90};
uint8 a[6];
uint16 counter = 0;
uint8 sec,min=0,hour=0,t_min=0,t_hour=0,ky=0;      //操作:a:1、開機顯示6個0,可進行鬧時設置。-> 2、功能按鍵K3按1下走時。->        // 3 、功能鍵再按1下關鬧鈴。->再按1下回到鬧時設置。循環。
uint16  counter1=0;
        //b:  K1、K2可設置時、分,最長定時99:59。
sbit BUZZ = P1^6;
sbit ENLED = P1^4;
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit KeyOut1=P2^3;
sbit K1 = P2^4;
sbit K2 = P2^5;
sbit K3 = P2^6;
void timer1_init()   //定時器1初使化
        TMOD |= 0x10;
        TMOD &= 0xdf;
        TH1   = 0xFC;
        TL1   = 0x67;
    ET1 = 1;
        EA  = 1;
         TR1 = 1;
void interrupt_timer1()interrupt 3  //中斷函數
{          TH1 = 0xFC;
          TL1 = 0x67;
          counter1++;
          if(counter1 == 1000)
          { counter1 =0;
           TR1 = 0;}
           BUZZ = ~BUZZ;
void timer2_init()         //  定時器T2運行函數
        T2MOD=0X00;
        TH2=(65536-110592/60)/256;
        TL2=(65536-110592/60)%256;
        RCAP2H=TH2;
        RCAP2L=TL2;
        EA=1;
        ET2=1;
        TR2=1;
void refresh_led() //數碼管刷新函數
          static uint8 j = 0;
                switch(j)
                   case 0: ADDR0 = 0;ADDR1 = 0;ADDR2 = 0;j++;P0=0x7f & number[a[0]];break;
                case 1: ADDR0 = 1;ADDR1 = 0;ADDR2 = 0;j++;P0 = number[a[1]];break;
                case 2: ADDR0 = 0;ADDR1 = 1;ADDR2 = 0;j++;P0 =0x7f & number[a[2]];break;
                case 3: ADDR0 = 1;ADDR1 = 1;ADDR2 = 0;j++;P0 = number[a[3]];break;
                case 4: ADDR0 = 0;ADDR1 = 0;ADDR2 = 1;j++;P0 =0x7f & number[a[4]];break;
                case 5: ADDR0 = 1;ADDR1 = 0;ADDR2 = 1;j = 0;P0 = number[a[5]];break;
                default: break;
void Hms(void)         //秒,分,時計算函數
        static uint16 ui2msCount=0;
               if(ky==1)
            ui2msCount++;
                if(ui2msCount>499)
                 ui2msCount=0;
                 if (sec==0)
                     sec=60;
                    if (min==0)
                        min=60;
                     if (hour==0)
                        hour=99;
                         hour--;
                     min--;
                  sec--;
                 a[5]=hour/10;
                 a[4]=hour%10;
                 a[3]=min/10;
                 a[2]=min%10;
                 a[1]=sec/10;
                 a[0]=sec%10;
                        if((ky==1)&&(sec==0)&&(min==0)&&(hour==0))
                        (timer1_init(),ky=0);
void Key3(void) //K3按鍵處理函數
             while(!K3);
              ky++;
             if(ky > 1)
              ky=0;
void Key2(void) //K2按鍵處理函數
  while(!K2);
   if(ky==0)
        min++;
     if(min>59)
        min=0;
void Key1(void)          //K1按鍵處理函數
   while(!K1);
    if(ky==0)
            hour++;
      if(hour>99)
         hour=0;
void Delay(uint8 ms)        //毫秒延時函數
uint8 i;
        while(ms--)
          for( i=0;i<125;i++)
main()                   //主函數
        ENLED = 0; ADDR3 = 1;
        timer2_init();
     KeyOut1=0;
         while(1)                 //主循環
                if(!K1)
                Delay(5);
                if(!K1)
                Key1();
                if(!K2)
                Delay(5);
                if(!K2)
                Key2();
                    if(!K3)
                        Delay(5);
                    if(!K3)
                        Key3();
void interrupt_timer2()        interrupt 5           //定時器T2中斷函數
          TF2=0;
          Hms();
          refresh_led();
