查看: 4294|回復: 7
我搞的頻率計c程
ID:71774 發表于 2015-1-24 18:38 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>                                   //        自寫頻率計程序,在學習板上通過
typedef  unsigned char   uint8;
typedef  unsigned int    uint16;
typedef  unsigned long   uint32;
code uint8 number[] = {0xc0,0xf9,0xa4,0xb0,
                                              0x99,0x92,0x82,0xf8,
                                            0x80,0x90};
uint8 a[6];
uint16 counter,counter1;
uint8 ky;
uint32 sec;
sbit ENLED = P1^4;
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit KeyOut1=P2^3;
sbit K1 = P2^4;
bit flag;
void refresh_led()
          static uint8 j = 0;
                switch(j)
                   case 0: ADDR0 = 0;ADDR1 = 0;ADDR2 = 0;j++;P0 = number[a[0]];break;
                case 1: ADDR0 = 1;ADDR1 = 0;ADDR2 = 0;j++;P0 = number[a[1]];break;
                case 2: ADDR0 = 0;ADDR1 = 1;ADDR2 = 0;j++;P0 = number[a[2]];break;
                case 3: ADDR0 = 1;ADDR1 = 1;ADDR2 = 0;j++;P0 = number[a[3]];break;
                case 4: ADDR0 = 0;ADDR1 = 0;ADDR2 = 1;j++;P0 = number[a[4]];break;
                case 5: ADDR0 = 1;ADDR1 = 0;ADDR2 = 1;j = 0;P0 = number[a[5]];break;
                default: break;
void Key1(void)
             while(!K1);
              ky++;
             if(ky > 1)
              ky=0;
void Delay(uint16 ms)
uint8 i;
        while(ms--)
          for( i=0;i<125;i++)
main()
        ENLED = 0; ADDR3 = 1;
     KeyOut1=0;
     TMOD=0x15;
     TH0=0;
     TL0=0;
     TH1=(65536-4000)/256;
         TL1=(65536-4000)%256;
     TR1=1;
     TR0=1;
     ET0=1;
     ET1=1;
     EA=1;
                if(!K1)
                Delay(5);
                if(!K1)
                Key1();
          if(flag==1)
                     { flag=0;
                        sec=counter*65536+TH0*256+TL0;
                            if(ky==1)
                         sec=0;
                          a[0] = sec%10;
                        a[1] = sec/10%10;
                        a[2] = sec/100%10;
                        a[3] = sec/1000%10;
                        a[4] = sec/10000%10;
                        a[5] = sec/100000%10;
                counter=0;
                counter1=0;
                TH0=0;
                TL0=0;
                TR0=1;
void t0(void) interrupt 1 using 1
   counter ++;
void t1(void) interrupt 3 using 2
counter1++;
if(counter1==250)
TR0=0;
counter1=0;
flag=1;
refresh_led();
admin + 50 共享資料的積分獎勵!
ID:1 發表于 2015-1-24 18:55 | 只看該作者
補充一下 這應該是用數碼管顯示的吧,電路下載:http://www.raoushi.com/f/ks51.pdf
ID:71774 發表于 2015-1-24 19:59 | 只看該作者
本帖最后由 三元里 于 2015-1-24 20:02 編輯
admin 發表于 2015-1-24 18:55
是用6個數碼管的,沒專門電路,還是在學習板上實驗。我的學習板就是金沙灘的。
ID:72756 發表于 2015-1-25 06:40 來自觸屏版 | 只看該作者
收藏了,有用,謝謝三元兄。
ID:65226 發表于 2015-1-27 21:17 來自觸屏版 | 只看該作者
學習了 謝謝
ID:86621 發表于 2015-8-12 16:44 | 只看該作者
精確度怎么樣
ID:86621 發表于 2015-8-13 09:28 | 只看該作者
范圍有哪些啊   有什么硬件
ID:4150 發表于 2017-8-31 20:16 | 只看該作者
請問樓主這種測試方法是基于測周法嗎
