是用51hei單片機(jī)開(kāi)發(fā)板 電路圖詳見(jiàn):http://www.raoushi.com/f/51hei-5.pdf 的數(shù)碼管部分, 用2個(gè)74hc573 鎖存,p0口作為數(shù)據(jù)口 ,p3.6和p3.7分別是段和位的鎖存端口.
- #include<reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- uchar code SEG7[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
- sbit D=P3^6;
- sbit V=P3^7;
- void delay(uint k)
- uint i,j;
- for(i=0;i<k;i++){
- for(j=0;j<121;j++)
- void main(void)
- uchar a,b,sum;
- a=55;
- b=200;
- sum=a+b;
- while(1)
- D=1;
- P0=SEG7[sum/100];
- D=0;
- P0=0xff;
- V=1;
- P0=0xfe;
- V=0;
- delay(1);
- D=1;
- P0=SEG7[(sum%100)/10];
- D=0;
- P0=0xff;
- V=1;
- P0=0xfd;
- V=0;
- delay(1);
- D=1;
- P0=SEG7[sum%10];
- D=0;
- P0=0xff;
- V=1;
- P0=0xfb;
- V=0;
- delay(1);
