查看: 4746|回復: 1
LED16*16點陣(兩組字+時鐘)
ID:72519 發表于 2015-1-21 21:41 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. #include<reg52.h>
  2. //#include<stc12.h>
  4. #define uint unsigned int
  5. #define slie P2
  6. sbit led=P1^0;
  7. sfr IAP_CONTR = 0xC7;
  8. sbit hangsck=P1^3;
  9. sbit hangsi=P1^4;
  10. sbit hangrck=P1^5;
  11. sbit beep=P1^7;
  12. sbit dat=P2^0;
  13. sbit clk=P2^1;
  14. uchar code table[]={0xfc,0x60,0xda,0xf2,0x66,0xb6,0xbe,0xe0,0xfe,0xf6,0xee,0x3e,0x1a,0x7a,0x9e,0x8e};
  15. uchar code time[][6]={0x3e,0x51,0x49,0x45,0x3e,0x00,
  16.                      0x00,0x42,0x7f,0x40,0x00, 0x00,
  17.                      0x62,0x51,0x49,0x49,0x46, 0x00,
  18. 0x21,0x41,0x49,0x4d,0x33, 0x00,
  19. 0x18,0x14,0x12,0x7f,0x10,0x00,
  20. 0x27,0x45,0x45,0x45,0x39,0x00,
  21. 0x3c,0x4a,0x49,0x49,0x31,0x00,
  22. 0x01,0x71,0x09,0x05,0x03,0x00,
  23. 0x36,0x49,0x49,0x49,0x36,0x00,
  24. 0x46,0x49,0x49,0x29,0x1e,0x00,
  25. 0x00,0x36,0x36,0x36,0x00,0x00,
  26. } ;
  27.
  28. uchar code lie[]={0x0f,0x0e,0x0d,0x0c,0x0b,0x0a,0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x01};
  29. uint code hang8[]={           //-- 鞍 --
  30.       0x04,0x08,0xC4,0x0B,0x5F,0x0A,0xF4,0xFF,
  31.       0x5F,0x0A,0xC4,0x0B,0xA4,0x88,0x98,0x84,
  32.       0x88,0x4B,0xE9,0x30,0x8A,0x10,0x88,0x28,
  33.       0x88,0x47,0xA8,0xC0,0x98,0x00,0x00,0x00,
  34. //-- 山 --
  35.       0x00,0x00,0xF0,0x7F,0x00,0x20,0x00,0x20,
  36.       0x00,0x20,0x00,0x20,0x00,0x20,0xFF,0x3F,
  37.       0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x20,
  38.       0x00,0x20,0xF0,0x7F,0x00,0x00,0x00,0x00,
  39. //-- 寶 --
  40.       0x10,0x00,0x0C,0x40,0x44,0x40,0x44,0x42,
  41.       0x44,0x42,0x44,0x42,0x45,0x42,0xC6,0x7F,
  42.       0x44,0x42,0x44,0x4A,0x44,0x5B,0x64,0x42,
  43.       0x44,0x60,0x14,0x40,0x0C,0x00,0x00,0x00,
  44. //-- 得 --
  45.       0x40,0x04,0x20,0x02,0x10,0x01,0x8C,0xFF,
  46.       0x63,0x04,0x80,0x04,0xBE,0x0C,0xAA,0x34,
  47.       0xAA,0x04,0xAA,0x44,0xAA,0x84,0xAA,0x7F,
  48.       0xBF,0x04,0x82,0x06,0x00,0x04,0x00,0x00,
  49. //-- 鋼 --
  50.       0x80,0x00,0x40,0x02,0x70,0x02,0xCF,0x7F,
  51.       0x48,0x22,0x48,0x12,0xFE,0xFF,0x12,0x08,
  52.       0x22,0x04,0x42,0x02,0x82,0x01,0x42,0x42,
  53.       0x32,0x8C,0xFF,0x7F,0x02,0x00,0x00,0x00,
  54. //-- 鐵 --
  55.       0x80,0x00,0x40,0x02,0x70,0x02,0xCF,0x7F,
  56.       0x48,0x22,0x48,0x92,0xA0,0x40,0x9E,0x30,
  57.       0x88,0x0C,0xFF,0x03,0x88,0x0C,0x8C,0x30,
  58.       0xC8,0x40,0x80,0xC0,0x00,0x40,0x00,0x00,
  59. //-- 有 --
  60.       0x04,0x04,0x04,0x02,0x04,0x01,0x84,0x00,
  61.       0xE4,0xFF,0x3C,0x09,0x27,0x09,0x24,0x09,
  62.       0x24,0x09,0x24,0x49,0x24,0x89,0xF4,0x7F,
  63.       0x24,0x00,0x06,0x00,0x04,0x00,0x00,0x00,
  64. //-- 限 --
  65.       0x00,0x00,0xFE,0xFF,0x02,0x08,0x22,0x10,
  66.       0xDA,0x08,0x06,0x07,0x00,0x00,0xFE,0xFF,
  67.       0x92,0x42,0x92,0x24,0x92,0x08,0x92,0x14,
  68.       0xFF,0x22,0x02,0x61,0x00,0x20,0x00,0x00,
  69. //-- 公 --
  70.       0x00,0x01,0x00,0x01,0x80,0x00,0x40,0x30,
  71.       0x30,0x28,0x0C,0x24,0x00,0x23,0xC0,0x20,
  72.       0x06,0x20,0x18,0x28,0x20,0x30,0x40,0x60,
  73.       0x80,0x00,0x80,0x01,0x80,0x00,0x00,0x00,
  74. //-- 司 --
  75.       0x10,0x00,0x10,0x00,0x92,0x3F,0x92,0x10,
  76.       0x92,0x10,0x92,0x10,0x92,0x10,0x92,0x10,
  77.       0xD2,0x3F,0x9A,0x00,0x12,0x40,0x02,0x80,
  78.       0xFF,0x7F,0x02,0x00,0x00,0x00,0x00,0x00,
  79. //-- 是 --
  80.       0x00,0x01,0x00,0x81,0x00,0x41,0x00,0x21,
  81.       0x7F,0x1D,0x49,0x21,0x49,0x41,0x49,0x7F,
  82.       0x49,0x89,0x49,0x89,0x7F,0x8D,0x00,0x89,
  83.       0x00,0x81,0x80,0xC1,0x00,0x41,0x00,0x00,
  84. //-- 以 --
  85.       0x00,0x00,0xFC,0x3F,0x00,0x20,0x00,0x10,
  86.       0x00,0x08,0x02,0x84,0x0C,0x82,0x18,0x41,
  87.       0x00,0x40,0x00,0x20,0x00,0x18,0x00,0x17,
  88.       0xFE,0x20,0x00,0xC0,0x00,0x00,0x00,0x00,
  89. //-- 大 --
  90.       0x20,0x00,0x20,0x40,0x20,0x40,0x20,0x20,
  91.       0x20,0x10,0x20,0x0C,0xA0,0x03,0x7F,0x00,
  92.       0xA0,0x01,0x20,0x06,0x20,0x08,0x20,0x10,
  93.       0x20,0x20,0x30,0x60,0x20,0x20,0x00,0x00,
  94. //-- 、 --
  95.       0x00,0x00,0x00,0x00,0x00,0x04,0x00,0x0C,
  96.       0x00,0x18,0x00,0x38,0x00,0x38,0x00,0x30,
  97.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  98.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  99. //-- 中 --
  100.       0x00,0x00,0xF8,0x03,0x08,0x01,0x08,0x01,
  101.       0x08,0x01,0x08,0x01,0x08,0x01,0xFF,0xFF,
  102.       0x08,0x01,0x08,0x01,0x08,0x01,0x08,0x01,
  103.       0x08,0x01,0xFC,0x03,0x08,0x00,0x00,0x00,
  104. //-- 型 --
  105.       0x20,0x40,0x22,0x4C,0x22,0x4A,0xFE,0x49,
  106.       0x22,0x48,0x22,0x48,0xFE,0x4B,0x23,0x7E,
  107.       0x22,0x48,0x00,0x48,0xFC,0x48,0x00,0x4A,
  108.       0x00,0x4C,0xFF,0x6B,0x00,0x40,0x00,0x00,
  109. //-- 材 --
  110.       0x10,0x08,0x10,0x04,0x10,0x03,0xD0,0x00,
  111.       0xFF,0xFF,0x90,0x00,0x10,0x01,0x00,0x08,
  112.       0x10,0x04,0x10,0x42,0x90,0x81,0xFF,0x7F,
  113.       0x10,0x00,0x18,0x00,0x10,0x00,0x00,0x00,
  114. //-- 為 --
  115.       0x20,0x00,0x20,0x40,0x20,0x20,0x22,0x10,
  116.       0x24,0x08,0x2C,0x04,0x20,0x03,0xE0,0x00,
  117.       0x3F,0x02,0x20,0x04,0x20,0x4C,0x20,0x80,
  118.       0x20,0x40,0xF0,0x3F,0x20,0x00,0x00,0x00,
  119. //-- 主 --
  120.       0x00,0x40,0x08,0x40,0x08,0x41,0x08,0x41,
  121.       0x08,0x41,0x08,0x41,0x09,0x41,0xFE,0x7F,
  122.       0x08,0x41,0x08,0x41,0x08,0x41,0x88,0x41,
  123.       0x0C,0x41,0x08,0x60,0x00,0x40,0x00,0x00,
  124. //-- 導 --
  125.       0x00,0x04,0x00,0x04,0x7E,0x04,0x92,0x04,
  126.       0x92,0x14,0x92,0x24,0x92,0x04,0x92,0x04,
  127.       0x92,0x44,0x92,0x84,0x92,0x7F,0xBF,0x04,
  128.       0x82,0x04,0xE0,0x06,0x00,0x04,0x00,0x00,
  129. //-- 產 --
  130.       0x00,0x80,0x08,0x40,0x08,0x30,0x88,0x0F,
  131.       0x98,0x00,0xE8,0x00,0x89,0x00,0x8E,0x00,
  132.       0x88,0x00,0xC8,0x00,0xA8,0x00,0x98,0x00,
  133.       0xCC,0x00,0x88,0x00,0x00,0x00,0x00,0x00,
  134. //-- 品 --
  135.       0x00,0x00,0x00,0xFF,0x00,0x41,0x7E,0x41,
  136.       0x22,0x41,0x22,0x41,0xA2,0xFF,0x22,0x01,
  137.       0x22,0xFF,0x22,0x41,0x22,0x41,0x7F,0x41,
  138.       0x02,0x41,0x80,0xFF,0x00,0x01,0x00,0x00,
  139. //-- 的 --
  140.       0x00,0x00,0xF8,0x7F,0x0C,0x21,0x0B,0x21,
  141.       0x08,0x21,0x08,0x21,0xFC,0x7F,0x28,0x00,
  142.       0x90,0x00,0x0F,0x01,0x08,0x43,0x08,0x80,
  143.       0x08,0x40,0xFC,0x3F,0x08,0x00,0x00,0x00,
  144. //-- 聯 --
  145.       0x02,0x20,0x02,0x20,0xFE,0x3F,0x12,0x11,
  146.       0x12,0x11,0xFE,0xFF,0x02,0x91,0x11,0x41,
  147.       0x12,0x21,0x16,0x19,0xF0,0x07,0x14,0x19,
  148.       0x12,0x61,0x93,0xC1,0x00,0x41,0x00,0x00,
  149. //-- 合 --
  150.       0x80,0x00,0x80,0x00,0x40,0x00,0x20,0xFE,
  151.       0x50,0x42,0x48,0x42,0x44,0x42,0x43,0x42,
  152.       0x44,0x42,0x48,0x42,0x50,0x42,0x20,0xFF,
  153.       0x40,0x02,0xC0,0x00,0x40,0x00,0x00,0x00,
  154. //-- 企 --
  155.       0x80,0x40,0x80,0x40,0x40,0x40,0x20,0x40,
  156.       0x90,0x7F,0x08,0x40,0x04,0x40,0xF3,0x7F,
  157.       0x04,0x41,0x08,0x41,0x90,0x41,0x20,0x41,
  158.       0x40,0x40,0xC0,0x60,0x40,0x40,0x00,0x00,
  159. //-- 業 --
  160.       0x00,0x40,0x10,0x40,0x60,0x40,0x80,0x47,
  161.       0x00,0x40,0xFF,0x7F,0x00,0x40,0x00,0x40,
  162.       0x00,0x40,0xFF,0x7F,0x00,0x44,0x00,0x43,
  163.       0xC0,0x40,0x30,0x60,0x00,0x40,0x00,0x00,
  164. //-- , --
  165.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x46,
  166.       0x00,0x2F,0x00,0x1F,0x00,0x06,0x00,0x00,
  167.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  168.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  169. //-- 占 --
  170.       0x00,0x00,0x00,0x00,0x80,0xFF,0x80,0x40,
  171.       0x80,0x40,0x80,0x40,0xFF,0x40,0x88,0x40,
  172.       0x88,0x40,0x88,0x40,0x88,0x40,0xC8,0xFF,
  173.       0x8C,0x00,0x08,0x00,0x00,0x00,0x00,0x00,
  174. //-- 地 --
  175.       0x40,0x20,0x40,0x60,0xFE,0x3F,0x40,0x10,
  176.       0x40,0x10,0x80,0x00,0xFC,0x3F,0x40,0x40,
  177.       0x40,0x40,0xFF,0x5F,0x20,0x44,0x20,0x48,
  178.       0xF0,0x47,0x20,0x40,0x00,0x70,0x00,0x00,
  179. //-- 一 --
  180.       0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,
  181.       0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,
  182.       0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,
  183.       0x80,0x00,0xC0,0x00,0x80,0x00,0x00,0x00,
  184. //-- 百 --
  185.       0x02,0x00,0x02,0x00,0x02,0x00,0xE2,0xFF,
  186.       0x22,0x42,0x32,0x42,0x2A,0x42,0x26,0x42,
  187.       0x22,0x42,0x22,0x42,0x22,0x42,0xF2,0xFF,
  188.       0x22,0x00,0x03,0x00,0x02,0x00,0x00,0x00,
  189. //-- 四 --
  190.       0x00,0x00,0xFC,0x7F,0x04,0x20,0x04,0x28,
  191.       0x04,0x24,0xFC,0x23,0x04,0x20,0x04,0x20,
  192.       0x04,0x20,0xFC,0x21,0x04,0x22,0x04,0x22,
  193.       0x04,0x22,0xFE,0x7F,0x04,0x00,0x00,0x00,
  194. //-- 十 --
  195.       0x40,0x00,0x40,0x00,0x40,0x00,0x40,0x00,
  196.       0x40,0x00,0x40,0x00,0x40,0x00,0xFF,0xFF,
  197.       0x40,0x00,0x40,0x00,0x40,0x00,0x40,0x00,
  198.       0x40,0x00,0x60,0x00,0x40,0x00,0x00,0x00,
  199. //-- 萬 --
  200.       0x04,0x00,0x04,0x80,0x04,0x40,0x04,0x20,
  201.       0x04,0x10,0x04,0x0E,0xFC,0x01,0x44,0x00,
  202.       0x44,0x40,0x44,0x80,0x44,0x40,0xE4,0x3F,
  203.       0x44,0x00,0x06,0x00,0x04,0x00,0x00,0x00,
  204. //-- 平 --
  205.       0x00,0x01,0x02,0x01,0x02,0x01,0x1A,0x01,
  206.       0x62,0x01,0x02,0x01,0x02,0x01,0xFE,0xFF,
  207.       0x02,0x01,0x02,0x01,0x62,0x01,0x1A,0x01,
  208.       0x03,0x01,0x82,0x01,0x00,0x01,0x00,0x00,
  209. //-- 方 --
  210.       0x10,0x00,0x10,0x80,0x10,0x40,0x10,0x20,
  211.       0x10,0x18,0xF1,0x07,0x92,0x00,0x96,0x00,
  212.       0x90,0x40,0x90,0x80,0x90,0x40,0xD0,0x3F,
  213.       0x90,0x00,0x18,0x00,0x10,0x00,0x00,0x00,
  214. //-- 米 --
  215.       0x40,0x20,0x40,0x20,0x42,0x10,0x44,0x08,
  216.       0x4C,0x04,0x58,0x02,0xC0,0x01,0xFF,0xFF,
  217.       0x40,0x01,0x50,0x02,0x48,0x04,0x44,0x08,
  218.       0x46,0x10,0x60,0x30,0x40,0x10,0x00,0x00,
  219. //-- 員 --
  220.       0x00,0x00,0x00,0x80,0xC0,0x9F,0x5E,0x40,
  221.       0x52,0x40,0x52,0x20,0x52,0x10,0x52,0x0F,
  222.       0x52,0x00,0x52,0x20,0x52,0x20,0x5F,0x40,
  223.       0xE2,0x5F,0x40,0x80,0x00,0x00,0x00,0x00,
  224. //-- 工 --
  225.       0x00,0x20,0x04,0x20,0x04,0x20,0x04,0x20,
  226.       0x04,0x20,0x04,0x20,0x04,0x20,0xFC,0x3F,
  227.       0x04,0x20,0x04,0x20,0x04,0x20,0x04,0x20,
  228.       0x06,0x20,0x04,0x30,0x00,0x20,0x00,0x00,
  229. //-- 三 --
  230.       0x00,0x20,0x04,0x20,0x84,0x20,0x84,0x20,
  231.       0x84,0x20,0x84,0x20,0x84,0x20,0x84,0x20,
  232.       0x84,0x20,0x84,0x20,0x84,0x20,0xC4,0x20,
  233.       0x86,0x20,0x04,0x30,0x00,0x20,0x00,0x00,
  234. //-- 千 --
  235.       0x80,0x00,0x80,0x00,0x84,0x00,0x84,0x00,
  236.       0x84,0x00,0x84,0x00,0x84,0x00,0xFC,0xFF,
  237.       0x82,0x00,0x82,0x00,0x83,0x00,0x82,0x00,
  238.       0x80,0x00,0xC0,0x00,0x80,0x00,0x00,0x00,
  239. //-- 人 --
  240.       0x00,0x00,0x00,0x80,0x00,0x40,0x00,0x20,
  241.       0x00,0x10,0x00,0x0C,0x80,0x03,0x7F,0x00,
  242.       0x80,0x03,0x00,0x0C,0x00,0x10,0x00,0x20,
  243.       0x00,0x40,0x00,0xC0,0x00,0x40,0x00,0x00,
  244. //-- 年 --
  245.       0x00,0x04,0x20,0x04,0x10,0x04,0xCC,0x07,
  246.       0x47,0x04,0x44,0x04,0x44,0x04,0xFC,0xFF,
  247.       0x44,0x04,0x44,0x04,0x44,0x04,0x64,0x04,
  248.       0x46,0x04,0x04,0x06,0x00,0x04,0x00,0x00,
  249. //-- 各 --
  250.       0x00,0x02,0x00,0x02,0x20,0x02,0x10,0x01,
  251.       0x08,0xFD,0x97,0x44,0xA4,0x44,0x44,0x44,
  252.       0x44,0x44,0xA4,0x44,0x94,0x44,0x0C,0xFD,
  253.       0x00,0x01,0x00,0x03,0x00,0x01,0x00,0x00,
  254. //-- 產 --
  255.       0x00,0x80,0x08,0x40,0x08,0x30,0x88,0x0F,
  256.       0x98,0x00,0xE8,0x00,0x89,0x00,0x8E,0x00,
  257.       0x88,0x00,0xC8,0x00,0xA8,0x00,0x98,0x00,
  258.       0xCC,0x00,0x88,0x00,0x00,0x00,0x00,0x00,
  259. //-- 鐵 --
  260.       0x80,0x00,0x40,0x02,0x70,0x02,0xCF,0x7F,
  261.       0x48,0x22,0x48,0x92,0xA0,0x40,0x9E,0x30,
  262.       0x88,0x0C,0xFF,0x03,0x88,0x0C,0x8C,0x30,
  263.       0xC8,0x40,0x80,0xC0,0x00,0x40,0x00,0x00,
  264. //-- 、 --
  265.       0x00,0x00,0x00,0x00,0x00,0x04,0x00,0x0C,
  266.       0x00,0x18,0x00,0x38,0x00,0x38,0x00,0x30,
  267.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  268.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  269. //-- 鋼 --
  270.       0x80,0x00,0x40,0x02,0x70,0x02,0xCF,0x7F,
  271.       0x48,0x22,0x48,0x12,0xFE,0xFF,0x12,0x08,
  272.       0x22,0x04,0x42,0x02,0x82,0x01,0x42,0x42,
  273.       0x32,0x8C,0xFF,0x7F,0x02,0x00,0x00,0x00,
  274. //-- 各 --
  275.       0x00,0x02,0x00,0x02,0x20,0x02,0x10,0x01,
  276.       0x08,0xFD,0x97,0x44,0xA4,0x44,0x44,0x44,
  277.       0x44,0x44,0xA4,0x44,0x94,0x44,0x0C,0xFD,
  278.       0x00,0x01,0x00,0x03,0x00,0x01,0x00,0x00,
  279. //-- 一 --
  280.       0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,
  281.       0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,
  282.       0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,
  283.       0x80,0x00,0xC0,0x00,0x80,0x00,0x00,0x00,
  284. //-- 百 --
  285.       0x02,0x00,0x02,0x00,0x02,0x00,0xE2,0xFF,
  286.       0x22,0x42,0x32,0x42,0x2A,0x42,0x26,0x42,
  287.       0x22,0x42,0x22,0x42,0x22,0x42,0xF2,0xFF,
  288.       0x22,0x00,0x03,0x00,0x02,0x00,0x00,0x00,
  289. //-- 三 --
  290.       0x00,0x20,0x04,0x20,0x84,0x20,0x84,0x20,
  291.       0x84,0x20,0x84,0x20,0x84,0x20,0x84,0x20,
  292.       0x84,0x20,0x84,0x20,0x84,0x20,0xC4,0x20,
  293.       0x86,0x20,0x04,0x30,0x00,0x20,0x00,0x00,
  294. //-- 十 --
  295.       0x40,0x00,0x40,0x00,0x40,0x00,0x40,0x00,
  296.       0x40,0x00,0x40,0x00,0x40,0x00,0xFF,0xFF,
  297.       0x40,0x00,0x40,0x00,0x40,0x00,0x40,0x00,
  298.       0x40,0x00,0x60,0x00,0x40,0x00,0x00,0x00,
  299. //-- 萬 --
  300.       0x04,0x00,0x04,0x80,0x04,0x40,0x04,0x20,
  301.       0x04,0x10,0x04,0x0E,0xFC,0x01,0x44,0x00,
  302.       0x44,0x40,0x44,0x80,0x44,0x40,0xE4,0x3F,
  303.       0x44,0x00,0x06,0x00,0x04,0x00,0x00,0x00,
  304. //-- 噸 --
  305.       0x00,0x00,0xFC,0x1F,0x04,0x08,0x04,0x08,
  306.       0xFE,0x1F,0x0C,0x00,0xC8,0x0F,0x08,0x04,
  307.       0x08,0x04,0xFF,0x7F,0x08,0x84,0x08,0x84,
  308.       0xCC,0x8F,0x08,0x80,0x00,0xE0,0x00,0x00,
  309. //-- , --
  310.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x46,
  311.       0x00,0x2F,0x00,0x1F,0x00,0x06,0x00,0x00,
  312.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  313.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  314. //-- 鋼 --
  315.       0x80,0x00,0x40,0x02,0x70,0x02,0xCF,0x7F,
  316.       0x48,0x22,0x48,0x12,0xFE,0xFF,0x12,0x08,
  317.       0x22,0x04,0x42,0x02,0x82,0x01,0x42,0x42,
  318.       0x32,0x8C,0xFF,0x7F,0x02,0x00,0x00,0x00,
  319. //-- 材 --
  320.       0x10,0x08,0x10,0x04,0x10,0x03,0xD0,0x00,
  321.       0xFF,0xFF,0x90,0x00,0x10,0x01,0x00,0x08,
  322.       0x10,0x04,0x10,0x42,0x90,0x81,0xFF,0x7F,
  323.       0x10,0x00,0x18,0x00,0x10,0x00,0x00,0x00,
  324. //-- 七 --
  325.       0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,
  326.       0x80,0x00,0x80,0x00,0xFF,0x3F,0x40,0x40,
  327.       0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,
  328.       0x40,0x40,0x60,0x78,0x40,0x00,0x00,0x00,
  329. //-- 十 --
  330.       0x40,0x00,0x40,0x00,0x40,0x00,0x40,0x00,
  331.       0x40,0x00,0x40,0x00,0x40,0x00,0xFF,0xFF,
  332.       0x40,0x00,0x40,0x00,0x40,0x00,0x40,0x00,
  333.       0x40,0x00,0x60,0x00,0x40,0x00,0x00,0x00,
  334. //-- 五 --
  335.       0x00,0x40,0x04,0x40,0x84,0x40,0x84,0x40,
  336.       0x84,0x78,0x84,0x47,0xFC,0x40,0x84,0x40,
  337.       0x84,0x40,0x84,0x40,0x84,0x40,0xC4,0x7F,
  338.       0x86,0x40,0x84,0x60,0x00,0x40,0x00,0x00,
  339. //-- 萬 --
  340.       0x04,0x00,0x04,0x80,0x04,0x40,0x04,0x20,
  341.       0x04,0x10,0x04,0x0E,0xFC,0x01,0x44,0x00,
  342.       0x44,0x40,0x44,0x80,0x44,0x40,0xE4,0x3F,
  343.       0x44,0x00,0x06,0x00,0x04,0x00,0x00,0x00,
  344. //-- 噸 --
  345.       0x00,0x00,0xFC,0x1F,0x04,0x08,0x04,0x08,
  346.       0xFE,0x1F,0x0C,0x00,0xC8,0x0F,0x08,0x04,
  347.       0x08,0x04,0xFF,0x7F,0x08,0x84,0x08,0x84,
  348.       0xCC,0x8F,0x08,0x80,0x00,0xE0,0x00,0x00,
  349. //-- , --
  350.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x46,
  351.       0x00,0x2F,0x00,0x1F,0x00,0x06,0x00,0x00,
  352.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  353.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  354. //-- “ --
  355.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  356.       0x00,0x00,0x00,0x00,0x60,0x00,0xF0,0x00,
  357.       0xF8,0x00,0x68,0x00,0x04,0x00,0x60,0x00,
  358.       0xF0,0x00,0xF8,0x00,0x68,0x00,0x04,0x00,
  359. //-- 寶 --
  360.       0x10,0x00,0x0C,0x40,0x44,0x40,0x44,0x42,
  361.       0x44,0x42,0x44,0x42,0x45,0x42,0xC6,0x7F,
  362.       0x44,0x42,0x44,0x4A,0x44,0x5B,0x64,0x42,
  363.       0x44,0x60,0x14,0x40,0x0C,0x00,0x00,0x00,
  364. //-- 得 --
  365.       0x40,0x04,0x20,0x02,0x10,0x01,0x8C,0xFF,
  366.       0x63,0x04,0x80,0x04,0xBE,0x0C,0xAA,0x34,
  367.       0xAA,0x04,0xAA,0x44,0xAA,0x84,0xAA,0x7F,
  368.       0xBF,0x04,0x82,0x06,0x00,0x04,0x00,0x00,
  369. //-- ” --
  370.       0x00,0x00,0x00,0x00,0x8C,0x00,0x5E,0x00,
  371.       0x3E,0x00,0x0C,0x00,0x00,0x00,0x8C,0x00,
  372.       0x5E,0x00,0x3E,0x00,0x0C,0x00,0x00,0x00,
  373.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  374. //-- 牌 --
  375.       0x00,0x40,0xFE,0x3F,0x20,0x01,0x20,0x01,
  376.       0x3F,0xFF,0x20,0x08,0x00,0x08,0xFC,0x0D,
  377.       0x26,0x0B,0xA5,0x09,0x7C,0xFF,0x24,0x09,
  378.       0x24,0x09,0xFE,0x0D,0x04,0x08,0x00,0x00,
  379. //-- 型 --
  380.       0x20,0x40,0x22,0x4C,0x22,0x4A,0xFE,0x49,
  381.       0x22,0x48,0x22,0x48,0xFE,0x4B,0x23,0x7E,
  382.       0x22,0x48,0x00,0x48,0xFC,0x48,0x00,0x4A,
  383.       0x00,0x4C,0xFF,0x6B,0x00,0x40,0x00,0x00,
  384. //-- 材 --
  385.       0x10,0x08,0x10,0x04,0x10,0x03,0xD0,0x00,
  386.       0xFF,0xFF,0x90,0x00,0x10,0x01,0x00,0x08,
  387.       0x10,0x04,0x10,0x42,0x90,0x81,0xFF,0x7F,
  388.       0x10,0x00,0x18,0x00,0x10,0x00,0x00,0x00,
  389. //-- 榮 --
  390.       0x84,0x00,0x64,0x42,0x24,0x42,0x24,0x22,
  391.       0x24,0x12,0x2F,0x0A,0x24,0x06,0xE4,0xFF,
  392.       0x24,0x06,0x2F,0x0A,0x24,0x12,0x24,0x22,
  393.       0x24,0x62,0xA6,0x22,0x64,0x00,0x00,0x00,
  394. //-- 獲 --
  395.       0x04,0x10,0x04,0x11,0x94,0x48,0x64,0x84,
  396.       0xA4,0x7F,0x1F,0x00,0x84,0x80,0x84,0x40,
  397.       0x84,0x20,0x8F,0x18,0xF4,0x07,0x84,0x18,
  398.       0x94,0x20,0xA6,0xC0,0x84,0x40,0x00,0x00,
  399. //-- 國 --
  400.       0x00,0x00,0xFE,0xFF,0x02,0x40,0x0A,0x50,
  401.       0x8A,0x50,0x8A,0x50,0x8A,0x50,0xFA,0x5F,
  402.       0x8A,0x50,0xCA,0x52,0x8E,0x54,0x0A,0x50,
  403.       0x02,0x40,0xFF,0xFF,0x02,0x00,0x00,0x00,
  404. //-- 家 --
  405.       0x10,0x00,0x0C,0x49,0x24,0x49,0xA4,0x24,
  406.       0xA4,0x24,0x64,0x52,0xA5,0x89,0x26,0x7F,
  407.       0x24,0x04,0x24,0x0A,0x24,0x11,0xA4,0x11,
  408.       0x24,0x20,0x14,0x60,0x0C,0x20,0x00,0x00,
  409. //-- “ --
  410.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  411.       0x00,0x00,0x00,0x00,0x60,0x00,0xF0,0x00,
  412.       0xF8,0x00,0x68,0x00,0x04,0x00,0x60,0x00,
  413.       0xF0,0x00,0xF8,0x00,0x68,0x00,0x04,0x00,
  414. //-- 冶 --
  415.       0x00,0x02,0x02,0x02,0x04,0x7F,0x8C,0x00,
  416.       0x40,0x00,0x40,0x00,0x60,0xFE,0x50,0x42,
  417.       0x4C,0x42,0x43,0x42,0x40,0x42,0x50,0x42,
  418.       0x60,0xFF,0x40,0x02,0x00,0x00,0x00,0x00,
  419. //-- 金 --
  420.       0x80,0x00,0x80,0x40,0x40,0x40,0x20,0x4A,
  421.       0x50,0x52,0x48,0x62,0x44,0x42,0xC3,0x7F,
  422.       0x44,0x42,0x68,0x62,0x50,0x52,0x20,0x4A,
  423.       0x40,0x60,0xC0,0x40,0x40,0x00,0x00,0x00,
  424. //-- 產 --
  425.       0x00,0x80,0x08,0x40,0x08,0x30,0x88,0x0F,
  426.       0x98,0x00,0xE8,0x00,0x89,0x00,0x8E,0x00,
  427.       0x88,0x00,0xC8,0x00,0xA8,0x00,0x98,0x00,
  428.       0xCC,0x00,0x88,0x00,0x00,0x00,0x00,0x00,
  429. //-- 品 --
  430.       0x00,0x00,0x00,0xFF,0x00,0x41,0x7E,0x41,
  431.       0x22,0x41,0x22,0x41,0xA2,0xFF,0x22,0x01,
  432.       0x22,0xFF,0x22,0x41,0x22,0x41,0x7F,0x41,
  433.       0x02,0x41,0x80,0xFF,0x00,0x01,0x00,0x00,
  434. //-- 實 --
  435.       0x10,0x02,0x0C,0x82,0x04,0x82,0x44,0x42,
  436.       0x8C,0x42,0x94,0x23,0x35,0x12,0x06,0x0E,
  437.       0xF4,0x03,0x04,0x0A,0x04,0x12,0x04,0x22,
  438.       0x04,0x42,0x14,0xC3,0x0C,0x02,0x00,0x00,
  439. //-- 物 --
  440.       0x40,0x02,0x3C,0x02,0x10,0x01,0xFF,0xFF,
  441.       0x90,0x00,0xA0,0x10,0x10,0x0C,0x1F,0x43,
  442.       0xF0,0x30,0x10,0x0E,0xF0,0x41,0x10,0x80,
  443.       0x10,0x40,0xF8,0x3F,0x10,0x00,0x00,0x00,
  444. //-- 質 --
  445.       0x00,0x40,0x00,0x30,0xFE,0x8F,0x12,0x80,
  446.       0x92,0x5F,0x92,0x40,0x92,0x20,0x92,0x10,
  447.       0xFE,0x0E,0x91,0x20,0x91,0x20,0x91,0x20,
  448.       0xD1,0x5F,0x98,0xC0,0x10,0x00,0x00,0x00,
  449. //-- 量 --
  450.       0x20,0x00,0x20,0x80,0x20,0x80,0xBE,0xAF,
  451.       0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xFF,
  452.       0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xBF,0xAF,
  453.       0x22,0x80,0x30,0x80,0x20,0x00,0x00,0x00,
  454. //-- 杯 --
  455.       0x10,0x04,0x10,0x03,0xD0,0x00,0xFF,0xFF,
  456.       0x90,0x08,0x14,0x05,0x04,0x02,0x04,0x01,
  457.       0x84,0x00,0xE4,0xFF,0x1C,0x00,0x84,0x00,
  458.       0x04,0x01,0x06,0x02,0x04,0x06,0x00,0x00,
  459. //-- 獎 --
  460.       0x00,0x82,0x42,0x82,0x64,0x42,0x10,0x42,
  461.       0x00,0x22,0xFF,0x12,0x00,0x0A,0x10,0x07,
  462.       0x08,0x0A,0x97,0x12,0x64,0x22,0x24,0x22,
  463.       0x14,0x42,0x0C,0xC3,0x00,0x42,0x00,0x00,
  464. //-- ” --
  465.       0x00,0x00,0x00,0x00,0x8C,0x00,0x5E,0x00,
  466.       0x3E,0x00,0x0C,0x00,0x00,0x00,0x8C,0x00,
  467.       0x5E,0x00,0x3E,0x00,0x0C,0x00,0x00,0x00,
  468.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  469. //-- 、 --
  470.       0x00,0x00,0x00,0x00,0x00,0x04,0x00,0x0C,
  471.       0x00,0x18,0x00,0x38,0x00,0x38,0x00,0x30,
  472.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  473.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  474. //-- 遼 --
  475.       0x00,0x00,0x21,0x40,0x22,0x20,0xE6,0x1F,
  476.       0x00,0x20,0x02,0x40,0x02,0x40,0x02,0x48,
  477.       0x02,0x50,0xF2,0x4F,0x12,0x40,0x0A,0x40,
  478.       0x06,0x40,0x02,0x60,0x00,0x20,0x00,0x00,
  479. //-- 寧 --
  480.       0x50,0x00,0x4C,0x00,0x44,0x00,0x44,0x00,
  481.       0x44,0x00,0x44,0x40,0x45,0x80,0xC6,0x7F,
  482.       0x44,0x00,0x44,0x00,0x44,0x00,0x44,0x00,
  483.       0x44,0x00,0x54,0x00,0x4C,0x00,0x00,0x00,
  484. //-- 省 --
  485.       0x00,0x02,0x00,0x02,0x20,0x01,0x18,0x01,
  486.       0x86,0xFF,0x80,0x55,0x40,0x55,0x5F,0x55,
  487.       0x20,0x55,0x20,0x55,0x12,0x55,0x04,0x55,
  488.       0x88,0xFF,0x18,0x01,0x00,0x00,0x00,0x00,
  489. //-- 名 --
  490.       0x00,0x02,0x00,0x02,0x00,0x02,0x20,0x01,
  491.       0x10,0xFF,0x9C,0x42,0xA7,0x42,0x44,0x42,
  492.       0x44,0x42,0x24,0x42,0x14,0x42,0x0C,0x42,
  493.       0x00,0xFF,0x00,0x02,0x00,0x00,0x00,0x00,
  494. //-- 牌 --
  495.       0x00,0x40,0xFE,0x3F,0x20,0x01,0x20,0x01,
  496.       0x3F,0xFF,0x20,0x08,0x00,0x08,0xFC,0x0D,
  497.       0x26,0x0B,0xA5,0x09,0x7C,0xFF,0x24,0x09,
  498.       0x24,0x09,0xFE,0x0D,0x04,0x08,0x00,0x00,
  499. //-- 產 --
  500.       0x00,0x80,0x08,0x40,0x08,0x30,0x88,0x0F,
  501.       0x98,0x00,0xE8,0x00,0x89,0x00,0x8E,0x00,
  502.       0x88,0x00,0xC8,0x00,0xA8,0x00,0x98,0x00,
  503.       0xCC,0x00,0x88,0x00,0x00,0x00,0x00,0x00,
  504. //-- 品 --
  505.       0x00,0x00,0x00,0xFF,0x00,0x41,0x7E,0x41,
  506.       0x22,0x41,0x22,0x41,0xA2,0xFF,0x22,0x01,
  507.       0x22,0xFF,0x22,0x41,0x22,0x41,0x7F,0x41,
  508.       0x02,0x41,0x80,0xFF,0x00,0x01,0x00,0x00,
  509. //-- 現 --
  510.       0x04,0x10,0x84,0x30,0x84,0x10,0xFC,0x1F,
  511.       0x86,0x88,0x84,0x88,0x00,0x40,0xFE,0x23,
  512.       0x02,0x18,0x82,0x07,0x7A,0x78,0x02,0x80,
  513.       0xFF,0x83,0x02,0x80,0x00,0xE0,0x00,0x00,
  514. //-- 廣 --
  515.       0x00,0x40,0x00,0x30,0xFC,0x0F,0x04,0x00,
  516.       0x04,0x00,0x04,0x00,0x04,0x00,0x05,0x00,
  517.       0x06,0x00,0x04,0x00,0x04,0x00,0x04,0x00,
  518.       0x04,0x00,0x06,0x00,0x04,0x00,0x00,0x00,
  519. //-- 泛 --
  520.       0x10,0x04,0x62,0x04,0x04,0xFE,0x8C,0x01,
  521.       0x00,0x20,0x44,0x10,0x44,0x10,0x44,0x28,
  522.       0x4C,0x44,0x74,0x42,0x42,0x41,0x43,0x41,
  523.       0xC2,0x40,0x40,0x60,0x00,0x20,0x00,0x00,
  524. //-- 應 --
  525.       0x00,0x40,0x00,0x30,0xFC,0x0F,0x04,0x40,
  526.       0x24,0x40,0xC4,0x40,0x04,0x4F,0x15,0x40,
  527.       0x66,0x40,0x84,0x63,0x04,0x50,0x04,0x4C,
  528.       0x84,0x43,0x76,0x60,0x04,0x40,0x00,0x00,
  529. //-- 用 --
  530.       0x00,0x80,0x00,0x60,0xFE,0x1F,0x22,0x02,
  531.       0x22,0x02,0x22,0x02,0x22,0x02,0xFE,0x7F,
  532.       0x22,0x02,0x22,0x02,0x22,0x42,0x22,0x82,
  533.       0xFF,0x7F,0x02,0x00,0x00,0x00,0x00,0x00,
  534. //-- 于 --
  535.       0x40,0x00,0x40,0x00,0x42,0x00,0x42,0x00,
  536.       0x42,0x00,0x42,0x40,0x42,0x80,0xFE,0x7F,
  537.       0x42,0x00,0x42,0x00,0x42,0x00,0x43,0x00,
  538.       0x42,0x00,0x60,0x00,0x40,0x00,0x00,0x00,
  539. //-- 重 --
  540.       0x08,0x40,0x08,0x40,0x0A,0x48,0xEA,0x4B,
  541.       0xAA,0x4A,0xAA,0x4A,0xAA,0x4A,0xFE,0x7F,
  542.       0xAA,0x4A,0xAA,0x4A,0xA9,0x4A,0xF9,0x4B,
  543.       0x29,0x48,0x0C,0x60,0x08,0x40,0x00,0x00,
  544. //-- 點 --
  545.       0x00,0x80,0x00,0x40,0xC0,0x37,0x40,0x04,
  546.       0x40,0x14,0x40,0x64,0x7F,0x04,0x48,0x14,
  547.       0x48,0x24,0x48,0x64,0x48,0x04,0xE8,0x17,
  548.       0x4C,0x20,0x08,0xC0,0x00,0x00,0x00,0x00,
  549. //-- 程 --
  550.       0x24,0x08,0x24,0x06,0xA4,0x01,0xFE,0xFF,
  551.       0xA3,0x00,0x22,0x43,0x20,0x41,0x7E,0x49,
  552.       0x42,0x49,0x42,0x49,0x42,0x7F,0x42,0x49,
  553.       0x42,0x4D,0x7F,0x69,0x02,0x41,0x00,0x00,
  554. //-- 公 --
  555.       0x00,0x01,0x00,0x01,0x80,0x00,0x40,0x30,
  556.       0x30,0x28,0x0C,0x24,0x00,0x23,0xC0,0x20,
  557.       0x06,0x20,0x18,0x28,0x20,0x30,0x40,0x60,
  558.       0x80,0x00,0x80,0x01,0x80,0x00,0x00,0x00,
  559. //-- 司 --
  560.       0x10,0x00,0x10,0x00,0x92,0x3F,0x92,0x10,
  561.       0x92,0x10,0x92,0x10,0x92,0x10,0x92,0x10,
  562.       0xD2,0x3F,0x9A,0x00,0x12,0x40,0x02,0x80,
  563.       0xFF,0x7F,0x02,0x00,0x00,0x00,0x00,0x00,
  564. //-- 是 --
  565.       0x00,0x01,0x00,0x81,0x00,0x41,0x00,0x21,
  566.       0x7F,0x1D,0x49,0x21,0x49,0x41,0x49,0x7F,
  567.       0x49,0x89,0x49,0x89,0x7F,0x8D,0x00,0x89,
  568.       0x00,0x81,0x80,0xC1,0x00,0x41,0x00,0x00,
  569. //-- 省 --
  570.       0x00,0x02,0x00,0x02,0x20,0x01,0x18,0x01,
  571.       0x86,0xFF,0x80,0x55,0x40,0x55,0x5F,0x55,
  572.       0x20,0x55,0x20,0x55,0x12,0x55,0x04,0x55,
  573.       0x88,0xFF,0x18,0x01,0x00,0x00,0x00,0x00,
  574. //-- 八 --
  575.       0x00,0x00,0x00,0x40,0x00,0x20,0x00,0x18,
  576.       0x00,0x07,0xFC,0x00,0x00,0x00,0x00,0x00,
  577.       0x00,0x00,0xFE,0x00,0x00,0x07,0x00,0x08,
  578.       0x00,0x30,0x00,0x60,0x00,0x20,0x00,0x00,
  579. //-- 十 --
  580.       0x40,0x00,0x40,0x00,0x40,0x00,0x40,0x00,
  581.       0x40,0x00,0x40,0x00,0x40,0x00,0xFF,0xFF,
  582.       0x40,0x00,0x40,0x00,0x40,0x00,0x40,0x00,
  583.       0x40,0x00,0x60,0x00,0x40,0x00,0x00,0x00,
  584. //-- 五 --
  585.       0x00,0x40,0x04,0x40,0x84,0x40,0x84,0x40,
  586.       0x84,0x78,0x84,0x47,0xFC,0x40,0x84,0x40,
  587.       0x84,0x40,0x84,0x40,0x84,0x40,0xC4,0x7F,
  588.       0x86,0x40,0x84,0x60,0x00,0x40,0x00,0x00,
  589. //-- 戶 --
  590.       0x00,0x80,0x00,0x60,0xF8,0x1F,0x88,0x00,
  591.       0x88,0x00,0x88,0x00,0x88,0x00,0x89,0x00,
  592.       0x8E,0x00,0x88,0x00,0x88,0x00,0x88,0x00,
  593.       0x88,0x00,0xFC,0x01,0x08,0x00,0x00,0x00,
  594. //-- 重 --
  595.       0x08,0x40,0x08,0x40,0x0A,0x48,0xEA,0x4B,
  596.       0xAA,0x4A,0xAA,0x4A,0xAA,0x4A,0xFE,0x7F,
  597.       0xAA,0x4A,0xAA,0x4A,0xA9,0x4A,0xF9,0x4B,
  598.       0x29,0x48,0x0C,0x60,0x08,0x40,0x00,0x00,
  599. //-- 點 --
  600.       0x00,0x80,0x00,0x40,0xC0,0x37,0x40,0x04,
  601.       0x40,0x14,0x40,0x64,0x7F,0x04,0x48,0x14,
  602.       0x48,0x24,0x48,0x64,0x48,0x04,0xE8,0x17,
  603.       0x4C,0x20,0x08,0xC0,0x00,0x00,0x00,0x00,
  604. //-- 工 --
  605.       0x00,0x20,0x04,0x20,0x04,0x20,0x04,0x20,
  606.       0x04,0x20,0x04,0x20,0x04,0x20,0xFC,0x3F,
  607.       0x04,0x20,0x04,0x20,0x04,0x20,0x04,0x20,
  608.       0x06,0x20,0x04,0x30,0x00,0x20,0x00,0x00,
  609. //-- 業 --
  610.       0x00,0x40,0x10,0x40,0x60,0x40,0x80,0x47,
  611.       0x00,0x40,0xFF,0x7F,0x00,0x40,0x00,0x40,
  612.       0x00,0x40,0xFF,0x7F,0x00,0x44,0x00,0x43,
  613.       0xC0,0x40,0x30,0x60,0x00,0x40,0x00,0x00,
  614. //-- 企 --
  615.       0x80,0x40,0x80,0x40,0x40,0x40,0x20,0x40,
  616.       0x90,0x7F,0x08,0x40,0x04,0x40,0xF3,0x7F,
  617.       0x04,0x41,0x08,0x41,0x90,0x41,0x20,0x41,
  618.       0x40,0x40,0xC0,0x60,0x40,0x40,0x00,0x00,
  619. //-- 之 --
  620.       0x00,0x00,0x10,0x20,0x10,0x10,0x10,0x10,
  621.       0x10,0x28,0x10,0x48,0x11,0x44,0x16,0x42,
  622.       0x10,0x41,0x90,0x40,0x50,0x40,0x30,0x40,
  623.       0x10,0x40,0x00,0x60,0x00,0x20,0x00,0x00,
  624. //-- 一 --
  625.       0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,
  626.       0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,
  627.       0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,
  628.       0x80,0x00,0xC0,0x00,0x80,0x00,0x00,0x00,
  629. //-- , --
  630.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x46,
  631.       0x00,0x2F,0x00,0x1F,0x00,0x06,0x00,0x00,
  632.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  633.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  634. //-- 二 --
  635.       0x00,0x10,0x00,0x10,0x08,0x10,0x08,0x10,
  636.       0x08,0x10,0x08,0x10,0x08,0x10,0x08,0x10,
  637.       0x08,0x10,0x08,0x10,0x08,0x10,0x0C,0x10,
  638.       0x08,0x10,0x00,0x18,0x00,0x10,0x00,0x00,
  639. //-- 零 --
  640.       0x10,0x04,0x0C,0x04,0x04,0x02,0x55,0x02,
  641.       0x55,0x09,0x55,0x09,0x85,0x2A,0x7F,0x4C,
  642.       0x85,0xA8,0x55,0x19,0x55,0x09,0x55,0x02,
  643.       0x04,0x02,0x14,0x04,0x0C,0x04,0x00,0x00,
  644. //-- 零 --
  645.       0x10,0x04,0x0C,0x04,0x04,0x02,0x55,0x02,
  646.       0x55,0x09,0x55,0x09,0x85,0x2A,0x7F,0x4C,
  647.       0x85,0xA8,0x55,0x19,0x55,0x09,0x55,0x02,
  648.       0x04,0x02,0x14,0x04,0x0C,0x04,0x00,0x00,
  649. //-- 九 --
  650.       0x10,0x80,0x10,0x80,0x10,0x40,0x10,0x30,
  651.       0x10,0x0C,0xFF,0x03,0x10,0x00,0x10,0x00,
  652.       0x10,0x00,0x10,0x00,0xF8,0x3F,0x10,0x40,
  653.       0x00,0x40,0x00,0x40,0x00,0x70,0x00,0x00,
  654. //-- 年 --
  655.       0x00,0x04,0x20,0x04,0x10,0x04,0xCC,0x07,
  656.       0x47,0x04,0x44,0x04,0x44,0x04,0xFC,0xFF,
  657.       0x44,0x04,0x44,0x04,0x44,0x04,0x64,0x04,
  658.       0x46,0x04,0x04,0x06,0x00,0x04,0x00,0x00,
  659. //-- 度 --
  660.       0x00,0x40,0x00,0x20,0xFC,0x9F,0x24,0x80,
  661.       0x24,0x42,0x24,0x42,0xFC,0x26,0xA5,0x2A,
  662.       0xA6,0x12,0xA4,0x2A,0xFC,0x26,0x24,0x42,
  663.       0x34,0x40,0x26,0xC0,0x04,0x40,0x00,0x00,
  664. //-- 省 --
  665.       0x00,0x02,0x00,0x02,0x20,0x01,0x18,0x01,
  666.       0x86,0xFF,0x80,0x55,0x40,0x55,0x5F,0x55,
  667.       0x20,0x55,0x20,0x55,0x12,0x55,0x04,0x55,
  668.       0x88,0xFF,0x18,0x01,0x00,0x00,0x00,0x00,
  669. //-- 企 --
  670.       0x80,0x40,0x80,0x40,0x40,0x40,0x20,0x40,
  671.       0x90,0x7F,0x08,0x40,0x04,0x40,0xF3,0x7F,
  672.       0x04,0x41,0x08,0x41,0x90,0x41,0x20,0x41,
  673.       0x40,0x40,0xC0,0x60,0x40,0x40,0x00,0x00,
  674. //-- 業 --
  675.       0x00,0x40,0x10,0x40,0x60,0x40,0x80,0x47,
  676.       0x00,0x40,0xFF,0x7F,0x00,0x40,0x00,0x40,
  677.       0x00,0x40,0xFF,0x7F,0x00,0x44,0x00,0x43,
  678.       0xC0,0x40,0x30,0x60,0x00,0x40,0x00,0x00,
  679. //-- 一 --
  680.       0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,
  681.       0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,
  682.       0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,
  683.       0x80,0x00,0xC0,0x00,0x80,0x00,0x00,0x00,
  684. //-- 百 --
  685.       0x02,0x00,0x02,0x00,0x02,0x00,0xE2,0xFF,
  686.       0x22,0x42,0x32,0x42,0x2A,0x42,0x26,0x42,
  687.       0x22,0x42,0x22,0x42,0x22,0x42,0xF2,0xFF,
  688.       0x22,0x00,0x03,0x00,0x02,0x00,0x00,0x00,
  689. //-- 強 --
  690.       0x02,0x20,0xE2,0x43,0x22,0x82,0x22,0x42,
  691.       0x7F,0x3E,0x02,0x00,0x80,0x4F,0xBE,0x44,
  692.       0x92,0x44,0x92,0x44,0xF2,0x7F,0x92,0x44,
  693.       0x92,0x44,0xBF,0x64,0x82,0xCF,0x00,0x00,
  694. //-- 中 --
  695.       0x00,0x00,0xF8,0x03,0x08,0x01,0x08,0x01,
  696.       0x08,0x01,0x08,0x01,0x08,0x01,0xFF,0xFF,
  697.       0x08,0x01,0x08,0x01,0x08,0x01,0x08,0x01,
  698.       0x08,0x01,0xFC,0x03,0x08,0x00,0x00,0x00,
  699. //-- 以 --
  700.       0x00,0x00,0xFC,0x3F,0x00,0x20,0x00,0x10,
  701.       0x00,0x08,0x02,0x84,0x0C,0x82,0x18,0x41,
  702.       0x00,0x40,0x00,0x20,0x00,0x18,0x00,0x17,
  703.       0xFE,0x20,0x00,0xC0,0x00,0x00,0x00,0x00,
  704. //-- 年 --
  705.       0x00,0x04,0x20,0x04,0x10,0x04,0xCC,0x07,
  706.       0x47,0x04,0x44,0x04,0x44,0x04,0xFC,0xFF,
  707.       0x44,0x04,0x44,0x04,0x44,0x04,0x64,0x04,
  708.       0x46,0x04,0x04,0x06,0x00,0x04,0x00,0x00,
  709. //-- 銷 --
  710.       0x40,0x02,0x20,0x02,0x58,0x02,0xCF,0x7F,
  711.       0x48,0x22,0x48,0x12,0x00,0x00,0xF2,0xFF,
  712.       0x94,0x04,0x90,0x04,0x9F,0x04,0x90,0x44,
  713.       0x94,0x84,0xFA,0x7F,0x10,0x00,0x00,0x00,
  714. //-- 售 --
  715.       0x40,0x00,0x20,0x00,0x10,0x00,0xF8,0xFF,
  716.       0x57,0x45,0x54,0x45,0x54,0x45,0x55,0x45,
  717.       0xFE,0x45,0x54,0x45,0x54,0x45,0x54,0x45,
  718.       0x56,0xFF,0x04,0x05,0x00,0x01,0x00,0x00,
  719. //-- 額 --
  720.       0x10,0x10,0x8C,0x08,0x44,0xFC,0xB5,0x4A,
  721.       0x26,0x49,0xA4,0x4A,0x74,0x7C,0x0C,0x08,
  722.       0x02,0x80,0xF2,0x4F,0x1A,0x20,0xD6,0x1F,
  723.       0x12,0x20,0xFB,0x4F,0x12,0xC0,0x00,0x00,
  724. //-- 三 --
  725.       0x00,0x20,0x04,0x20,0x84,0x20,0x84,0x20,
  726.       0x84,0x20,0x84,0x20,0x84,0x20,0x84,0x20,
  727.       0x84,0x20,0x84,0x20,0x84,0x20,0xC4,0x20,
  728.       0x86,0x20,0x04,0x30,0x00,0x20,0x00,0x00,
  729. //-- 十 --
  730.       0x40,0x00,0x40,0x00,0x40,0x00,0x40,0x00,
  731.       0x40,0x00,0x40,0x00,0x40,0x00,0xFF,0xFF,
  732.       0x40,0x00,0x40,0x00,0x40,0x00,0x40,0x00,
  733.       0x40,0x00,0x60,0x00,0x40,0x00,0x00,0x00,
  734. //-- 六 --
  735.       0x20,0x00,0x20,0x40,0x20,0x20,0x20,0x18,
  736.       0x20,0x06,0x22,0x03,0x2C,0x00,0x38,0x00,
  737.       0x20,0x00,0x20,0x01,0x20,0x02,0x20,0x0C,
  738.       0x20,0x38,0x30,0x70,0x20,0x00,0x00,0x00,
  739. //-- 億 --
  740.       0x80,0x00,0x40,0x00,0x20,0x00,0xF8,0xFF,
  741.       0x07,0x00,0x00,0x3C,0x04,0x43,0x84,0x40,
  742.       0x44,0x40,0x24,0x40,0x14,0x40,0x0C,0x40,
  743.       0x04,0x40,0x00,0x40,0x00,0x70,0x00,0x00,
  744. //-- 元 --
  745.       0x20,0x80,0x20,0x80,0x22,0x40,0x22,0x20,
  746.       0x22,0x18,0xE2,0x07,0x22,0x00,0x22,0x00,
  747.       0x22,0x00,0xE2,0x3F,0x22,0x40,0x23,0x40,
  748.       0x22,0x40,0x30,0x40,0x20,0x70,0x00,0x00,
  749. //-- 名 --
  750.       0x00,0x02,0x00,0x02,0x00,0x02,0x20,0x01,
  751.       0x10,0xFF,0x9C,0x42,0xA7,0x42,0x44,0x42,
  752.       0x44,0x42,0x24,0x42,0x14,0x42,0x0C,0x42,
  753.       0x00,0xFF,0x00,0x02,0x00,0x00,0x00,0x00,
  754. //-- 列 --
  755.       0x00,0x01,0x82,0x40,0x62,0x20,0x9E,0x10,
  756.       0x12,0x09,0x12,0x06,0x92,0x01,0x73,0x00,
  757.       0x02,0x00,0x00,0x00,0xFC,0x0F,0x00,0x40,
  758.       0x00,0x80,0xFF,0x7F,0x00,0x00,0x00,0x00,
  759. //-- 第 --
  760.       0x10,0x00,0x08,0x40,0x94,0x47,0x97,0x24,
  761.       0x9C,0x24,0x96,0x14,0x94,0x0C,0xF8,0xFF,
  762.       0x97,0x04,0x94,0x04,0x9C,0x24,0x94,0x44,
  763.       0xF6,0x44,0x04,0x3E,0x00,0x04,0x00,0x00,
  764. //-- 七 --
  765.       0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,
  766.       0x80,0x00,0x80,0x00,0xFF,0x3F,0x40,0x40,
  767.       0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,
  768.       0x40,0x40,0x60,0x78,0x40,0x00,0x00,0x00,
  769. //-- 十 --
  770.       0x40,0x00,0x40,0x00,0x40,0x00,0x40,0x00,
  771.       0x40,0x00,0x40,0x00,0x40,0x00,0xFF,0xFF,
  772.       0x40,0x00,0x40,0x00,0x40,0x00,0x40,0x00,
  773.       0x40,0x00,0x60,0x00,0x40,0x00,0x00,0x00,
  774. //-- 二 --
  775.       0x00,0x10,0x00,0x10,0x08,0x10,0x08,0x10,
  776.       0x08,0x10,0x08,0x10,0x08,0x10,0x08,0x10,
  777.       0x08,0x10,0x08,0x10,0x08,0x10,0x0C,0x10,
  778.       0x08,0x10,0x00,0x18,0x00,0x10,0x00,0x00,
  779. //-- 位 --
  780.       0x80,0x00,0x40,0x00,0x20,0x00,0xF8,0xFF,
  781.       0x07,0x20,0x10,0x20,0xD0,0x20,0x10,0x23,
  782.       0x11,0x2C,0x16,0x20,0x10,0x38,0x10,0x27,
  783.       0xD8,0x20,0x10,0x30,0x00,0x20,0x00,0x00,
  784. //-- , --
  785.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x46,
  786.       0x00,0x2F,0x00,0x1F,0x00,0x06,0x00,0x00,
  787.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  788.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  789. //-- 公 --
  790.       0x00,0x01,0x00,0x01,0x80,0x00,0x40,0x30,
  791.       0x30,0x28,0x0C,0x24,0x00,0x23,0xC0,0x20,
  792.       0x06,0x20,0x18,0x28,0x20,0x30,0x40,0x60,
  793.       0x80,0x00,0x80,0x01,0x80,0x00,0x00,0x00,
  794. //-- 司 --
  795.       0x10,0x00,0x10,0x00,0x92,0x3F,0x92,0x10,
  796.       0x92,0x10,0x92,0x10,0x92,0x10,0x92,0x10,
  797.       0xD2,0x3F,0x9A,0x00,0x12,0x40,0x02,0x80,
  798.       0xFF,0x7F,0x02,0x00,0x00,0x00,0x00,0x00,
  799. //-- 連 --
  800.       0x40,0x40,0x42,0x20,0xCC,0x1F,0x00,0x20,
  801.       0x04,0x44,0x44,0x44,0x64,0x44,0x5C,0x44,
  802.       0x47,0x44,0xF4,0x7F,0x44,0x44,0x64,0x44,
  803.       0x46,0x46,0x04,0x64,0x00,0x20,0x00,0x00,
  804. //-- 續 --
  805.       0x20,0x22,0x30,0x63,0xAC,0x22,0x63,0x12,
  806.       0x30,0x12,0x20,0x14,0x24,0x85,0x64,0x46,
  807.       0xA4,0x24,0x3F,0x1C,0xE4,0x17,0x26,0x24,
  808.       0xA4,0x44,0x60,0xC6,0x00,0x04,0x00,0x00,
  809. //-- 多 --
  810.       0x00,0x00,0x00,0x81,0x20,0x91,0x10,0x89,
  811.       0x98,0x44,0xA4,0x44,0x47,0x4A,0x24,0x31,
  812.       0xE4,0x11,0x14,0x11,0x0C,0x09,0x04,0x05,
  813.       0x00,0x03,0x00,0x01,0x00,0x00,0x00,0x00,
  814. //-- 年 --
  815.       0x00,0x04,0x20,0x04,0x10,0x04,0xCC,0x07,
  816.       0x47,0x04,0x44,0x04,0x44,0x04,0xFC,0xFF,
  817.       0x44,0x04,0x44,0x04,0x44,0x04,0x64,0x04,
  818.       0x46,0x04,0x04,0x06,0x00,0x04,0x00,0x00,
  819. //-- 成 --
  820.       0x00,0x40,0x00,0x20,0xF8,0x1F,0x88,0x00,
  821.       0x88,0x08,0x88,0x10,0x88,0x0F,0x08,0x40,
  822.       0x7F,0x20,0x88,0x13,0x0A,0x1C,0x0C,0x24,
  823.       0x08,0x43,0xC8,0x80,0x00,0xF0,0x00,0x00,
  824. //-- 為 --
  825.       0x20,0x00,0x20,0x40,0x20,0x20,0x22,0x10,
  826.       0x24,0x08,0x2C,0x04,0x20,0x03,0xE0,0x00,
  827.       0x3F,0x02,0x20,0x04,0x20,0x4C,0x20,0x80,
  828.       0x20,0x40,0xF0,0x3F,0x20,0x00,0x00,0x00,
  829. //-- 鞍 --
  830.       0x04,0x08,0xC4,0x0B,0x5F,0x0A,0xF4,0xFF,
  831.       0x5F,0x0A,0xC4,0x0B,0xA4,0x88,0x98,0x84,
  832.       0x88,0x4B,0xE9,0x30,0x8A,0x10,0x88,0x28,
  833.       0x88,0x47,0xA8,0xC0,0x98,0x00,0x00,0x00,
  834. //-- 山 --
  835.       0x00,0x00,0xF0,0x7F,0x00,0x20,0x00,0x20,
  836.       0x00,0x20,0x00,0x20,0x00,0x20,0xFF,0x3F,
  837.       0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x20,
  838.       0x00,0x20,0xF0,0x7F,0x00,0x00,0x00,0x00,
  839. //-- 市 --
  840.       0x08,0x00,0x08,0x00,0xC8,0x3F,0x48,0x00,
  841.       0x48,0x00,0x48,0x00,0x49,0x00,0xFA,0xFF,
  842.       0x48,0x00,0x48,0x00,0x48,0x10,0x48,0x20,
  843.       0xE8,0x1F,0x4C,0x00,0x08,0x00,0x00,0x00,
  844. //-- 民 --
  845.       0x00,0x00,0xFE,0xFF,0x22,0x41,0x22,0x21,
  846.       0x22,0x11,0x22,0x01,0xE2,0x03,0x22,0x0D,
  847.       0x22,0x11,0x22,0x21,0x22,0x41,0x3F,0x41,
  848.       0x82,0x81,0x00,0x81,0x00,0xE0,0x00,0x00,
  849. //-- 營 --
  850.       0x40,0x00,0x34,0x00,0x14,0x00,0x14,0xF8,
  851.       0xD4,0x4B,0x5F,0x4A,0x54,0x4A,0x54,0x4A,
  852.       0x54,0x4A,0x5F,0x4A,0xD4,0x4B,0x14,0xF8,
  853.       0x16,0x00,0x54,0x00,0x30,0x00,0x00,0x00,
  854. //-- 企 --
  855.       0x80,0x40,0x80,0x40,0x40,0x40,0x20,0x40,
  856.       0x90,0x7F,0x08,0x40,0x04,0x40,0xF3,0x7F,
  857.       0x04,0x41,0x08,0x41,0x90,0x41,0x20,0x41,
  858.       0x40,0x40,0xC0,0x60,0x40,0x40,0x00,0x00,
  859. //-- 業 --
  860.       0x00,0x40,0x10,0x40,0x60,0x40,0x80,0x47,
  861.       0x00,0x40,0xFF,0x7F,0x00,0x40,0x00,0x40,
  862.       0x00,0x40,0xFF,0x7F,0x00,0x44,0x00,0x43,
  863.       0xC0,0x40,0x30,0x60,0x00,0x40,0x00,0x00,
  864. //-- 納 --
  865.       0x20,0x22,0x30,0x63,0xAC,0x22,0x63,0x12,
  866.       0x30,0x12,0x00,0x00,0xF8,0xFF,0x08,0x04,
  867.       0x08,0x03,0xFF,0x00,0x08,0x01,0x08,0x46,
  868.       0x08,0x80,0xFC,0x7F,0x08,0x00,0x00,0x00,
  869. //-- 稅 --
  870.       0x24,0x04,0x24,0x02,0xA4,0x01,0xFE,0xFF,
  871.       0xA3,0x00,0x22,0x01,0x00,0x80,0xF2,0x43,
  872.       0x14,0x31,0x18,0x0F,0x10,0x01,0x18,0x3F,
  873.       0x14,0x41,0xF2,0x43,0x00,0x70,0x00,0x00,
  874. //-- 狀 --
  875.       0x00,0x08,0x08,0x0C,0x30,0x02,0x00,0x01,
  876.       0xFF,0xFF,0x20,0x40,0x20,0x20,0x20,0x1C,
  877.       0x20,0x03,0xFF,0x00,0x20,0x03,0x22,0x0C,
  878.       0x24,0x30,0x30,0x60,0x20,0x20,0x00,0x00,
  879. //-- 元 --
  880.       0x20,0x80,0x20,0x80,0x22,0x40,0x22,0x20,
  881.       0x22,0x18,0xE2,0x07,0x22,0x00,0x22,0x00,
  882.       0x22,0x00,0xE2,0x3F,0x22,0x40,0x23,0x40,
  883.       0x22,0x40,0x30,0x40,0x20,0x70,0x00,0x00,
  884. //-- , --
  885.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x46,
  886.       0x00,0x2F,0x00,0x1F,0x00,0x06,0x00,0x00,
  887.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  888.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  889. //-- 近 --
  890.       0x40,0x00,0x42,0x40,0x44,0x20,0xCC,0x1F,
  891.       0x00,0x20,0x00,0x48,0xFC,0x87,0x44,0x80,
  892.       0x44,0x80,0x44,0x80,0xC4,0xBF,0x42,0x80,
  893.       0x63,0x80,0x42,0xC0,0x00,0x40,0x00,0x00,
  894. //-- 四 --
  895.       0x00,0x00,0xFC,0x7F,0x04,0x20,0x04,0x28,
  896.       0x04,0x24,0xFC,0x23,0x04,0x20,0x04,0x20,
  897.       0x04,0x20,0xFC,0x21,0x04,0x22,0x04,0x22,
  898.       0x04,0x22,0xFE,0x7F,0x04,0x00,0x00,0x00,
  899. //-- 年 --
  900.       0x00,0x04,0x20,0x04,0x10,0x04,0xCC,0x07,
  901.       0x47,0x04,0x44,0x04,0x44,0x04,0xFC,0xFF,
  902.       0x44,0x04,0x44,0x04,0x44,0x04,0x64,0x04,
  903.       0x46,0x04,0x04,0x06,0x00,0x04,0x00,0x00,
  904. //-- 榮 --
  905.       0x84,0x00,0x64,0x42,0x24,0x42,0x24,0x22,
  906.       0x24,0x12,0x2F,0x0A,0x24,0x06,0xE4,0xFF,
  907.       0x24,0x06,0x2F,0x0A,0x24,0x12,0x24,0x22,
  908.       0x24,0x62,0xA6,0x22,0x64,0x00,0x00,0x00,
  909. //-- 登 --
  910.       0x00,0x01,0x00,0x41,0x82,0x40,0x4A,0x40,
  911.       0x72,0x4F,0x52,0x59,0x4E,0x69,0x40,0x49,
  912.       0x47,0x69,0x58,0x59,0xE4,0x4F,0x52,0x41,
  913.       0x88,0x60,0x80,0x41,0x80,0x00,0x00,0x00,
  914. //-- 中 --
  915.       0x00,0x00,0xF8,0x03,0x08,0x01,0x08,0x01,
  916.       0x08,0x01,0x08,0x01,0x08,0x01,0xFF,0xFF,
  917.       0x08,0x01,0x08,0x01,0x08,0x01,0x08,0x01,
  918.       0x08,0x01,0xFC,0x03,0x08,0x00,0x00,0x00,
  919. //-- 國 --
  920.       0x00,0x00,0xFE,0xFF,0x02,0x40,0x0A,0x50,
  921.       0x8A,0x50,0x8A,0x50,0x8A,0x50,0xFA,0x5F,
  922.       0x8A,0x50,0xCA,0x52,0x8E,0x54,0x0A,0x50,
  923.       0x02,0x40,0xFF,0xFF,0x02,0x00,0x00,0x00,
  924. //-- 私 --
  925.       0x24,0x08,0x24,0x04,0x24,0x02,0xA4,0x01,
  926.       0xFE,0xFF,0xA3,0x00,0x32,0x21,0x20,0x38,
  927.       0x00,0x27,0xF0,0x20,0x0F,0x20,0x00,0x20,
  928.       0x00,0x28,0x00,0x30,0x00,0x60,0x00,0x00,
  929. //-- 營 --
  930.       0x40,0x00,0x34,0x00,0x14,0x00,0x14,0xF8,
  931.       0xD4,0x4B,0x5F,0x4A,0x54,0x4A,0x54,0x4A,
  932.       0x54,0x4A,0x5F,0x4A,0xD4,0x4B,0x14,0xF8,
  933.       0x16,0x00,0x54,0x00,0x30,0x00,0x00,0x00,
  934. //-- 企 --
  935.       0x80,0x40,0x80,0x40,0x40,0x40,0x20,0x40,
  936.       0x90,0x7F,0x08,0x40,0x04,0x40,0xF3,0x7F,
  937.       0x04,0x41,0x08,0x41,0x90,0x41,0x20,0x41,
  938.       0x40,0x40,0xC0,0x60,0x40,0x40,0x00,0x00,
  939. //-- 業 --
  940.       0x00,0x40,0x10,0x40,0x60,0x40,0x80,0x47,
  941.       0x00,0x40,0xFF,0x7F,0x00,0x40,0x00,0x40,
  942.       0x00,0x40,0xFF,0x7F,0x00,0x44,0x00,0x43,
  943.       0xC0,0x40,0x30,0x60,0x00,0x40,0x00,0x00,
  944. //-- 納 --
  945.       0x20,0x22,0x30,0x63,0xAC,0x22,0x63,0x12,
  946.       0x30,0x12,0x00,0x00,0xF8,0xFF,0x08,0x04,
  947.       0x08,0x03,0xFF,0x00,0x08,0x01,0x08,0x46,
  948.       0x08,0x80,0xFC,0x7F,0x08,0x00,0x00,0x00,
  949. //-- 稅 --
  950.       0x24,0x04,0x24,0x02,0xA4,0x01,0xFE,0xFF,
  951.       0xA3,0x00,0x22,0x01,0x00,0x80,0xF2,0x43,
  952.       0x14,0x31,0x18,0x0F,0x10,0x01,0x18,0x3F,
  953.       0x14,0x41,0xF2,0x43,0x00,0x70,0x00,0x00,
  954. //-- 百 --
  955.       0x02,0x00,0x02,0x00,0x02,0x00,0xE2,0xFF,
  956.       0x22,0x42,0x32,0x42,0x2A,0x42,0x26,0x42,
  957.       0x22,0x42,0x22,0x42,0x22,0x42,0xF2,0xFF,
  958.       0x22,0x00,0x03,0x00,0x02,0x00,0x00,0x00,
  959. //-- 強 --
  960.       0x02,0x20,0xE2,0x43,0x22,0x82,0x22,0x42,
  961.       0x7F,0x3E,0x02,0x00,0x80,0x4F,0xBE,0x44,
  962.       0x92,0x44,0x92,0x44,0xF2,0x7F,0x92,0x44,
  963.       0x92,0x44,0xBF,0x64,0x82,0xCF,0x00,0x00,
  964. //-- 排 --
  965.       0x10,0x02,0x10,0x42,0x10,0x81,0xFF,0x7F,
  966.       0x90,0x08,0x58,0x08,0x88,0x08,0x88,0x08,
  967.       0xFF,0xFF,0x00,0x00,0xFF,0xFF,0x88,0x08,
  968.       0xC8,0x08,0x8C,0x0C,0x08,0x08,0x00,0x00,
  969. //-- 行 --
  970.       0x00,0x02,0x10,0x01,0x88,0x00,0xC4,0xFF,
  971.       0x23,0x00,0x40,0x00,0x42,0x00,0x42,0x00,
  972.       0x42,0x00,0x42,0x40,0x42,0x80,0xC2,0x7F,
  973.       0x43,0x00,0x62,0x00,0x40,0x00,0x00,0x00,
  974. //-- 榜 --
  975.       0x10,0x04,0x10,0x03,0xD0,0x00,0xFF,0xFF,
  976.       0x90,0x00,0x10,0x81,0x60,0x41,0x24,0x21,
  977.       0x2C,0x1F,0x75,0x05,0xA6,0x45,0x34,0x85,
  978.       0x2E,0x7D,0x64,0x01,0x20,0x01,0x00,0x00,
  979. //-- 前 --
  980.       0x08,0x00,0x08,0x00,0xE8,0xFF,0x29,0x09,
  981.       0x2A,0x49,0x2E,0x89,0xE8,0x7F,0x08,0x00,
  982.       0x08,0x00,0xCC,0x0F,0x0A,0x40,0x0B,0x80,
  983.       0xE8,0x7F,0x0C,0x00,0x08,0x00,0x00,0x00,
  984. //-- 十 --
  985.       0x40,0x00,0x40,0x00,0x40,0x00,0x40,0x00,
  986.       0x40,0x00,0x40,0x00,0x40,0x00,0xFF,0xFF,
  987.       0x40,0x00,0x40,0x00,0x40,0x00,0x40,0x00,
  988.       0x40,0x00,0x60,0x00,0x40,0x00,0x00,0x00,
  989. //-- 位 --
  990.       0x80,0x00,0x40,0x00,0x20,0x00,0xF8,0xFF,
  991.       0x07,0x20,0x10,0x20,0xD0,0x20,0x10,0x23,
  992.       0x11,0x2C,0x16,0x20,0x10,0x38,0x10,0x27,
  993.       0xD8,0x20,0x10,0x30,0x00,0x20,0x00,0x00,
  994. //-- 。 --
  995.       0x00,0x00,0x00,0x38,0x00,0x7C,0x00,0x44,
  996.       0x00,0x44,0x00,0x7C,0x00,0x38,0x00,0x00,
  997.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  998.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  999. };
  1000. uchar code hang9[]={   //--   --
  1001.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1002.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1003.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1004.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1005. //-- 《 --
  1006.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1007.       0x80,0x01,0x60,0x06,0x18,0x18,0x80,0x01,
  1008.       0x60,0x06,0x18,0x18,0x00,0x00,0x00,0x00,
  1009.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1010. //-- 史 --
  1011.       0x00,0x80,0x00,0x80,0xF8,0x41,0x88,0x40,
  1012.       0x88,0x22,0x88,0x14,0x88,0x08,0xFF,0x17,
  1013.       0x88,0x10,0x88,0x20,0x88,0x20,0x88,0x40,
  1014.       0xFC,0x41,0x08,0xC0,0x00,0x40,0x00,0x00,
  1015. //-- 記 --
  1016.       0x40,0x00,0x40,0x00,0x42,0x00,0xCC,0x7F,
  1017.       0x00,0x20,0x04,0x10,0x84,0x3F,0x84,0x40,
  1018.       0x84,0x40,0x84,0x40,0x84,0x40,0x84,0x40,
  1019.       0xFE,0x41,0x04,0x40,0x00,0x78,0x00,0x00,
  1020. //-- 》 --
  1021.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1022.       0x00,0x00,0x00,0x00,0x18,0x18,0x60,0x06,
  1023.       0x80,0x01,0x18,0x18,0x60,0x06,0x80,0x01,
  1024.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1025. //-- 是 --
  1026.       0x00,0x01,0x00,0x81,0x00,0x41,0x00,0x21,
  1027.       0x7F,0x1D,0x49,0x21,0x49,0x41,0x49,0x7F,
  1028.       0x49,0x89,0x49,0x89,0x7F,0x8D,0x00,0x89,
  1029.       0x00,0x81,0x80,0xC1,0x00,0x41,0x00,0x00,
  1030. //-- 由 --
  1031.       0x00,0x00,0xF0,0xFF,0x10,0x42,0x10,0x42,
  1032.       0x10,0x42,0x10,0x42,0x10,0x42,0xFF,0x7F,
  1033.       0x10,0x42,0x10,0x42,0x10,0x42,0x10,0x42,
  1034.       0x10,0x42,0xF8,0xFF,0x10,0x00,0x00,0x00,
  1035. //-- 司 --
  1036.       0x10,0x00,0x10,0x00,0x92,0x3F,0x92,0x10,
  1037.       0x92,0x10,0x92,0x10,0x92,0x10,0x92,0x10,
  1038.       0xD2,0x3F,0x9A,0x00,0x12,0x40,0x02,0x80,
  1039.       0xFF,0x7F,0x02,0x00,0x00,0x00,0x00,0x00,
  1040. //-- 馬 --
  1041.       0x00,0x08,0x00,0x08,0x02,0x08,0x02,0x08,
  1042.       0xFA,0x09,0x02,0x09,0x02,0x09,0x02,0x09,
  1043.       0x02,0x09,0x02,0x09,0xFF,0x4D,0x02,0x89,
  1044.       0x00,0x41,0x80,0x3F,0x00,0x01,0x00,0x00,
  1045. //-- 遷 --
  1046.       0x40,0x00,0x42,0x40,0x44,0x20,0xCC,0x1F,
  1047.       0x00,0x20,0x40,0x40,0x44,0x40,0x44,0x40,
  1048.       0x44,0x40,0xFC,0x5F,0x42,0x40,0x43,0x40,
  1049.       0x62,0x40,0x40,0x60,0x00,0x20,0x00,0x00,
  1050. //-- 撰 --
  1051.       0x10,0x02,0x10,0x42,0x10,0x81,0xFF,0x7F,
  1052.       0x90,0x10,0x3E,0x92,0x52,0x52,0xD2,0x3F,
  1053.       0x5E,0x12,0x60,0x12,0x3E,0x12,0xD2,0x3F,
  1054.       0x52,0x52,0x5F,0xDA,0x62,0x10,0x00,0x00,
  1055. //-- 寫 --
  1056.       0x08,0x00,0x06,0x08,0x02,0x08,0x02,0x08,
  1057.       0xFA,0x09,0x22,0x09,0x22,0x09,0x22,0x09,
  1058.       0x22,0x09,0x22,0x4D,0x32,0x89,0x22,0x41,
  1059.       0x82,0x3F,0x0A,0x01,0x06,0x00,0x00,0x00,
  1060. //-- 的 --
  1061.       0x00,0x00,0xF8,0x7F,0x0C,0x21,0x0B,0x21,
  1062.       0x08,0x21,0x08,0x21,0xFC,0x7F,0x28,0x00,
  1063.       0x90,0x00,0x0F,0x01,0x08,0x43,0x08,0x80,
  1064.       0x08,0x40,0xFC,0x3F,0x08,0x00,0x00,0x00,
  1065. //-- 中 --
  1066.       0x00,0x00,0xF8,0x03,0x08,0x01,0x08,0x01,
  1067.       0x08,0x01,0x08,0x01,0x08,0x01,0xFF,0xFF,
  1068.       0x08,0x01,0x08,0x01,0x08,0x01,0x08,0x01,
  1069.       0x08,0x01,0xFC,0x03,0x08,0x00,0x00,0x00,
  1070. //-- 國 --
  1071.       0x00,0x00,0xFE,0xFF,0x02,0x40,0x0A,0x50,
  1072.       0x8A,0x50,0x8A,0x50,0x8A,0x50,0xFA,0x5F,
  1073.       0x8A,0x50,0xCA,0x52,0x8E,0x54,0x0A,0x50,
  1074.       0x02,0x40,0xFF,0xFF,0x02,0x00,0x00,0x00,
  1075. //-- 第 --
  1076.       0x10,0x00,0x08,0x40,0x94,0x47,0x97,0x24,
  1077.       0x9C,0x24,0x96,0x14,0x94,0x0C,0xF8,0xFF,
  1078.       0x97,0x04,0x94,0x04,0x9C,0x24,0x94,0x44,
  1079.       0xF6,0x44,0x04,0x3E,0x00,0x04,0x00,0x00,
  1080. //-- 一 --
  1081.       0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,
  1082.       0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,
  1083.       0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,
  1084.       0x80,0x00,0xC0,0x00,0x80,0x00,0x00,0x00,
  1085. //-- 部 --
  1086.       0x80,0x00,0x88,0x00,0xA8,0x7E,0xC9,0x22,
  1087.       0x8A,0x22,0xC8,0x22,0xAC,0x7F,0x88,0x02,
  1088.       0x80,0x00,0xFE,0xFF,0x02,0x08,0x42,0x10,
  1089.       0xB2,0x20,0x0E,0x11,0x00,0x0E,0x00,0x00,
  1090. //-- 紀 --
  1091.       0x20,0x22,0x20,0x66,0x30,0x23,0xAC,0x12,
  1092.       0x63,0x12,0x30,0x12,0x04,0x00,0x84,0x3F,
  1093.       0x84,0x40,0x84,0x40,0x84,0x40,0x84,0x40,
  1094.       0x84,0x40,0xFE,0x41,0x04,0x70,0x00,0x00,
  1095. //-- 傳 --
  1096.       0x80,0x00,0x40,0x00,0x20,0x00,0xF8,0xFF,
  1097.       0x47,0x00,0x48,0x00,0x48,0x02,0x48,0x0B,
  1098.       0xC8,0x12,0x7F,0x62,0x48,0xD2,0x48,0x0A,
  1099.       0x4C,0x06,0x68,0x02,0x40,0x00,0x00,0x00,
  1100. //-- 體 --
  1101.       0x40,0x00,0x20,0x00,0xF8,0xFF,0x07,0x08,
  1102.       0x10,0x06,0x90,0x01,0x70,0x04,0x10,0x04,
  1103.       0xFF,0xFF,0x10,0x04,0x70,0x04,0x90,0x01,
  1104.       0x18,0x06,0x10,0x0C,0x00,0x04,0x00,0x00,
  1105. //-- 通 --
  1106.       0x40,0x00,0x42,0x40,0x44,0x20,0xCC,0x1F,
  1107.       0x00,0x20,0x00,0x40,0xF1,0xBF,0x91,0x84,
  1108.       0x95,0x84,0xF9,0xBF,0x95,0x94,0x93,0xA4,
  1109.       0xF9,0x9F,0x10,0xC0,0x00,0x40,0x00,0x00,
  1110. //-- 史 --
  1111.       0x00,0x80,0x00,0x80,0xF8,0x41,0x88,0x40,
  1112.       0x88,0x22,0x88,0x14,0x88,0x08,0xFF,0x17,
  1113.       0x88,0x10,0x88,0x20,0x88,0x20,0x88,0x40,
  1114.       0xFC,0x41,0x08,0xC0,0x00,0x40,0x00,0x00,
  1115. //-- 。 --
  1116.       0x00,0x00,0x00,0x38,0x00,0x7C,0x00,0x44,
  1117.       0x00,0x44,0x00,0x7C,0x00,0x38,0x00,0x00,
  1118.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1119.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00 ,
  1120. //-- 記 --
  1121.       0x40,0x00,0x40,0x00,0x42,0x00,0xCC,0x7F,
  1122.       0x00,0x20,0x04,0x10,0x84,0x3F,0x84,0x40,
  1123.       0x84,0x40,0x84,0x40,0x84,0x40,0x84,0x40,
  1124.       0xFE,0x41,0x04,0x40,0x00,0x78,0x00,0x00,
  1125. //-- 載 --
  1126.       0xA0,0x20,0xA4,0x24,0xA4,0x27,0xE4,0x24,
  1127.       0xBF,0xFE,0xA4,0x14,0xA6,0x94,0xA4,0x50,
  1128.       0x20,0x20,0xFF,0x13,0x20,0x1C,0x22,0x24,
  1129.       0x2C,0x43,0x20,0x80,0x20,0xE0,0x00,0x00,
  1130. //-- 了 --
  1131.       0x00,0x00,0x02,0x00,0x02,0x00,0x02,0x00,
  1132.       0x02,0x00,0x02,0x40,0x02,0x80,0xE2,0x7F,
  1133.       0x22,0x00,0x12,0x00,0x0A,0x00,0x06,0x00,
  1134.       0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1135. //-- 上 --
  1136.       0x00,0x40,0x00,0x40,0x00,0x40,0x00,0x40,
  1137.       0x00,0x40,0x00,0x40,0x00,0x40,0xFF,0x7F,
  1138.       0x20,0x40,0x20,0x40,0x20,0x40,0x30,0x40,
  1139.       0x20,0x40,0x00,0x60,0x00,0x40,0x00,0x00,
  1140. //-- 自 --
  1141.       0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0xFF,
  1142.       0x48,0x44,0x4C,0x44,0x4A,0x44,0x49,0x44,
  1143.       0x48,0x44,0x48,0x44,0x48,0x44,0xFC,0xFF,
  1144.       0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1145. //-- 古 --
  1146.       0x10,0x00,0x10,0x00,0x10,0x00,0x10,0xFF,
  1147.       0x10,0x41,0x10,0x41,0x10,0x41,0xFF,0x41,
  1148.       0x10,0x41,0x10,0x41,0x10,0x41,0x90,0xFF,
  1149.       0x10,0x01,0x18,0x00,0x10,0x00,0x00,0x00,
  1150. //-- 傳 --
  1151.       0x80,0x00,0x40,0x00,0x20,0x00,0xF8,0xFF,
  1152.       0x47,0x00,0x48,0x00,0x48,0x02,0x48,0x0B,
  1153.       0xC8,0x12,0x7F,0x62,0x48,0xD2,0x48,0x0A,
  1154.       0x4C,0x06,0x68,0x02,0x40,0x00,0x00,0x00,
  1155. //-- 說 --
  1156.       0x40,0x00,0x40,0x00,0x42,0x00,0xCC,0x7F,
  1157.       0x00,0x20,0x00,0x90,0xF2,0x43,0x14,0x31,
  1158.       0x18,0x0F,0x10,0x01,0x18,0x3F,0x14,0x41,
  1159.       0xF2,0x43,0x00,0x40,0x00,0x70,0x00,0x00,
  1160. //-- 中 --
  1161.       0x00,0x00,0xF8,0x03,0x08,0x01,0x08,0x01,
  1162.       0x08,0x01,0x08,0x01,0x08,0x01,0xFF,0xFF,
  1163.       0x08,0x01,0x08,0x01,0x08,0x01,0x08,0x01,
  1164.       0x08,0x01,0xFC,0x03,0x08,0x00,0x00,0x00,
  1165. //-- 的 --
  1166.       0x00,0x00,0xF8,0x7F,0x0C,0x21,0x0B,0x21,
  1167.       0x08,0x21,0x08,0x21,0xFC,0x7F,0x28,0x00,
  1168.       0x90,0x00,0x0F,0x01,0x08,0x43,0x08,0x80,
  1169.       0x08,0x40,0xFC,0x3F,0x08,0x00,0x00,0x00,
  1170. //-- 黃 --
  1171.       0x20,0x00,0x20,0x80,0x24,0x80,0xA4,0x5F,
  1172.       0xA4,0x4A,0xBF,0x2A,0xA4,0x0A,0xE4,0x0F,
  1173.       0xA4,0x0A,0xBF,0x2A,0xA4,0x2A,0xE6,0x4F,
  1174.       0xA4,0x40,0x30,0x80,0x20,0x00,0x00,0x00,
  1175. //-- 帝 --
  1176.       0x80,0x00,0x60,0x00,0x24,0x00,0x24,0x3F,
  1177.       0x2C,0x01,0x34,0x01,0x25,0x01,0xE6,0xFF,
  1178.       0x24,0x01,0x34,0x11,0x2C,0x21,0xA6,0x1F,
  1179.       0x24,0x01,0xA0,0x00,0x60,0x00,0x00,0x00,
  1180. //-- 時 --
  1181.       0x00,0x00,0xFC,0x3F,0x84,0x10,0x84,0x10,
  1182.       0x84,0x10,0xFE,0x3F,0x14,0x00,0x10,0x00,
  1183.       0x90,0x00,0x10,0x23,0x10,0x40,0x10,0x80,
  1184.       0xFF,0x7F,0x10,0x00,0x10,0x00,0x00,0x00,
  1185. //-- 代 --
  1186.       0x80,0x00,0x40,0x00,0x20,0x00,0xF8,0xFF,
  1187.       0x47,0x00,0x40,0x00,0x40,0x00,0x40,0x00,
  1188.       0x7F,0x00,0xA0,0x03,0x22,0x0C,0x2C,0x30,
  1189.       0x20,0x40,0x30,0x80,0x20,0xF0,0x00,0x00,
  1190. //-- , --
  1191.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x46,
  1192.       0x00,0x2F,0x00,0x1F,0x00,0x06,0x00,0x00,
  1193.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1194.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1195. //-- 下 --
  1196.       0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,
  1197.       0x02,0x00,0x02,0x00,0xFE,0xFF,0x02,0x00,
  1198.       0x22,0x00,0x42,0x00,0x82,0x00,0x82,0x01,
  1199.       0x02,0x00,0x03,0x00,0x02,0x00,0x00,0x00,
  1200. //-- 至 --
  1201.       0x00,0x40,0x02,0x40,0x42,0x44,0x62,0x44,
  1202.       0x52,0x44,0x4A,0x44,0x46,0x44,0xC2,0x7F,
  1203.       0x42,0x44,0x42,0x44,0x52,0x44,0x62,0x46,
  1204.       0xC3,0x44,0x02,0x60,0x00,0x40,0x00,0x00,
  1205. //-- 漢 --
  1206.       0x10,0x04,0x22,0x04,0x64,0x7E,0x0C,0x01,
  1207.       0x80,0x80,0x04,0x40,0x74,0x20,0x84,0x11,
  1208.       0x04,0x0A,0x04,0x04,0x04,0x0B,0xC4,0x10,
  1209.       0x3E,0x60,0x04,0xC0,0x00,0x40,0x00,0x00,
  1210. //-- 武 --
  1211.       0x20,0x20,0x20,0x60,0x24,0x3F,0x24,0x20,
  1212.       0x24,0x20,0xE4,0x1F,0x26,0x11,0x24,0x11,
  1213.       0x20,0x10,0xFF,0x03,0x20,0x1C,0x22,0x20,
  1214.       0x2C,0x40,0x20,0x80,0x20,0xE0,0x00,0x00,
  1215. //-- 帝 --
  1216.       0x80,0x00,0x60,0x00,0x24,0x00,0x24,0x3F,
  1217.       0x2C,0x01,0x34,0x01,0x25,0x01,0xE6,0xFF,
  1218.       0x24,0x01,0x34,0x11,0x2C,0x21,0xA6,0x1F,
  1219.       0x24,0x01,0xA0,0x00,0x60,0x00,0x00,0x00,
  1220. //-- 元 --
  1221.       0x20,0x80,0x20,0x80,0x22,0x40,0x22,0x20,
  1222.       0x22,0x18,0xE2,0x07,0x22,0x00,0x22,0x00,
  1223.       0x22,0x00,0xE2,0x3F,0x22,0x40,0x23,0x40,
  1224.       0x22,0x40,0x30,0x40,0x20,0x70,0x00,0x00,
  1225. //-- 狩 --
  1226.       0x22,0x04,0x14,0x42,0x08,0x81,0x94,0x40,
  1227.       0xE2,0x3F,0x91,0x00,0x8C,0x00,0x84,0x02,
  1228.       0x84,0x0C,0x85,0x40,0x86,0x80,0xF4,0x7F,
  1229.       0x84,0x00,0xD4,0x00,0x8C,0x00,0x00,0x00,
  1230. //-- 年 --
  1231.       0x00,0x04,0x20,0x04,0x10,0x04,0xCC,0x07,
  1232.       0x47,0x04,0x44,0x04,0x44,0x04,0xFC,0xFF,
  1233.       0x44,0x04,0x44,0x04,0x44,0x04,0x64,0x04,
  1234.       0x46,0x04,0x04,0x06,0x00,0x04,0x00,0x00,
  1235. //-- 間 --
  1236.       0x00,0x00,0xF8,0xFF,0x01,0x00,0x02,0x00,
  1237.       0xF6,0x3F,0x10,0x11,0x12,0x11,0x12,0x11,
  1238.       0x12,0x11,0x12,0x11,0xFA,0x3F,0x12,0x40,
  1239.       0x02,0x80,0xFF,0x7F,0x02,0x00,0x00,0x00,
  1240. //-- 共 --
  1241.       0x00,0x04,0x10,0x04,0x10,0x84,0x10,0x44,
  1242.       0xFF,0x27,0x10,0x34,0x10,0x04,0x10,0x04,
  1243.       0x10,0x04,0x10,0x14,0xFF,0x27,0x10,0x64,
  1244.       0x18,0xC4,0x10,0x06,0x00,0x04,0x00,0x00,
  1245. //-- 三 --
  1246.       0x00,0x20,0x04,0x20,0x84,0x20,0x84,0x20,
  1247.       0x84,0x20,0x84,0x20,0x84,0x20,0x84,0x20,
  1248.       0x84,0x20,0x84,0x20,0x84,0x20,0xC4,0x20,
  1249.       0x86,0x20,0x04,0x30,0x00,0x20,0x00,0x00,
  1250. //-- 千 --
  1251.       0x80,0x00,0x80,0x00,0x84,0x00,0x84,0x00,
  1252.       0x84,0x00,0x84,0x00,0x84,0x00,0xFC,0xFF,
  1253.       0x82,0x00,0x82,0x00,0x83,0x00,0x82,0x00,
  1254.       0x80,0x00,0xC0,0x00,0x80,0x00,0x00,0x00,
  1255. //-- 多 --
  1256.       0x00,0x00,0x00,0x81,0x20,0x91,0x10,0x89,
  1257.       0x98,0x44,0xA4,0x44,0x47,0x4A,0x24,0x31,
  1258.       0xE4,0x11,0x14,0x11,0x0C,0x09,0x04,0x05,
  1259.       0x00,0x03,0x00,0x01,0x00,0x00,0x00,0x00,
  1260. //-- 的 --
  1261.       0x00,0x00,0xF8,0x7F,0x0C,0x21,0x0B,0x21,
  1262.       0x08,0x21,0x08,0x21,0xFC,0x7F,0x28,0x00,
  1263.       0x90,0x00,0x0F,0x01,0x08,0x43,0x08,0x80,
  1264.       0x08,0x40,0xFC,0x3F,0x08,0x00,0x00,0x00,
  1265. //-- 歷 --
  1266.       0x00,0x40,0x00,0x30,0xFE,0x0F,0x42,0x80,
  1267.       0x42,0x40,0x42,0x20,0x42,0x18,0xFE,0x07,
  1268.       0x42,0x00,0x42,0x20,0x42,0x40,0x42,0x80,
  1269.       0x43,0x40,0xE2,0x3F,0x40,0x00,0x00,0x00,
  1270. //-- 史 --
  1271.       0x00,0x80,0x00,0x80,0xF8,0x41,0x88,0x40,
  1272.       0x88,0x22,0x88,0x14,0x88,0x08,0xFF,0x17,
  1273.       0x88,0x10,0x88,0x20,0x88,0x20,0x88,0x40,
  1274.       0xFC,0x41,0x08,0xC0,0x00,0x40,0x00,0x00,
  1275. //-- ( --
  1276.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1277.       0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x01,
  1278.       0xE0,0x07,0x38,0x1C,0x08,0x10,0x04,0x20,
  1279.       0x02,0x40,0x00,0x00,0x00,0x00,0x00,0x00,
  1280. //-- 哲 --
  1281.       0x04,0x00,0x24,0x00,0x24,0x01,0x24,0xFE,
  1282.       0xFF,0x45,0x14,0x44,0x14,0x45,0xC0,0x44,
  1283.       0x3E,0x44,0x12,0x44,0x12,0x44,0xF2,0xFF,
  1284.       0x11,0x04,0x19,0x00,0x10,0x00,0x00,0x00,
  1285. //-- 學 --
  1286.       0x40,0x04,0x30,0x04,0x11,0x04,0x96,0x04,
  1287.       0x90,0x04,0x90,0x44,0x91,0x84,0x96,0x7E,
  1288.       0x90,0x06,0x90,0x05,0x98,0x04,0x14,0x04,
  1289.       0x13,0x04,0x50,0x06,0x30,0x04,0x00,0x00,
  1290. //-- 、 --
  1291.       0x00,0x00,0x00,0x00,0x00,0x04,0x00,0x0C,
  1292.       0x00,0x18,0x00,0x38,0x00,0x38,0x00,0x30,
  1293.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1294.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1295. //-- 政 --
  1296.       0x04,0x10,0xC4,0x3F,0x04,0x10,0xFC,0x1F,
  1297.       0x44,0x08,0x46,0x08,0x44,0x88,0x20,0x40,
  1298.       0xD8,0x20,0x0F,0x1B,0x08,0x04,0x08,0x1B,
  1299.       0xF8,0x60,0x0C,0xC0,0x08,0x40,0x00,0x00,
  1300. //-- 治 --
  1301.       0x10,0x04,0x22,0x04,0x64,0xFE,0x0C,0x01,
  1302.       0x80,0x00,0x20,0x00,0x30,0xFF,0x2C,0x41,
  1303.       0x23,0x41,0x20,0x41,0x20,0x41,0x28,0x41,
  1304.       0xB0,0xFF,0x20,0x01,0x00,0x00,0x00,0x00,
  1305. //-- 經 --
  1306.       0x20,0x24,0x30,0x66,0x2C,0x25,0xA3,0x14,
  1307.       0x60,0x14,0x30,0x54,0x82,0x40,0x82,0x42,
  1308.       0x42,0x42,0x22,0x42,0x12,0x7E,0x1A,0x42,
  1309.       0x26,0x42,0x42,0x62,0xC0,0x40,0x00,0x00,
  1310. //-- 濟 --
  1311.       0x10,0x04,0x22,0x04,0x64,0xFE,0x0C,0x01,
  1312.       0x80,0x00,0x84,0x40,0x84,0x20,0x4C,0x1F,
  1313.       0x55,0x00,0x26,0x00,0x54,0x00,0x4C,0xFF,
  1314.       0x84,0x00,0x86,0x01,0x84,0x00,0x00,0x00,
  1315. //-- 軍 --
  1316.       0x08,0x08,0x06,0x08,0x12,0x09,0x92,0x09,
  1317.       0x52,0x09,0x32,0x09,0x1E,0x09,0xD2,0xFF,
  1318.       0x12,0x09,0x12,0x09,0x12,0x09,0x9A,0x09,
  1319.       0x12,0x09,0x0A,0x0C,0x06,0x08,0x00,0x00,
  1320. //-- 事 --
  1321.       0x04,0x04,0x04,0x04,0x74,0x15,0x54,0x15,
  1322.       0x54,0x15,0x54,0x55,0x54,0x95,0xFF,0x7F,
  1323.       0x54,0x15,0x54,0x15,0x54,0x15,0x54,0x15,
  1324.       0x74,0x3F,0x06,0x04,0x04,0x04,0x00,0x00,
  1325. //-- 等 --
  1326.       0x00,0x01,0x08,0x01,0x44,0x09,0x47,0x09,
  1327.       0x4C,0x19,0x56,0x29,0x44,0x09,0xF8,0x49,
  1328.       0x44,0x89,0x47,0x7F,0x4C,0x09,0x54,0x0D,
  1329.       0x46,0x09,0x04,0x01,0x00,0x01,0x00,0x00,
  1330. //-- ) --
  1331.       0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x40,
  1332.       0x04,0x20,0x08,0x10,0x38,0x1C,0xE0,0x07,
  1333.       0x80,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
  1334.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1335. //-- 。 --
  1336.       0x00,0x00,0x00,0x38,0x00,0x7C,0x00,0x44,
  1337.       0x00,0x44,0x00,0x7C,0x00,0x38,0x00,0x00,
  1338.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1339.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1340. //-- 《 --
  1341.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1342.       0x80,0x01,0x60,0x06,0x18,0x18,0x80,0x01,
  1343.       0x60,0x06,0x18,0x18,0x00,0x00,0x00,0x00,
  1344.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1345. //-- 史 --
  1346.       0x00,0x80,0x00,0x80,0xF8,0x41,0x88,0x40,
  1347.       0x88,0x22,0x88,0x14,0x88,0x08,0xFF,0x17,
  1348.       0x88,0x10,0x88,0x20,0x88,0x20,0x88,0x40,
  1349.       0xFC,0x41,0x08,0xC0,0x00,0x40,0x00,0x00,
  1350. //-- 記 --
  1351.       0x40,0x00,0x40,0x00,0x42,0x00,0xCC,0x7F,
  1352.       0x00,0x20,0x04,0x10,0x84,0x3F,0x84,0x40,
  1353.       0x84,0x40,0x84,0x40,0x84,0x40,0x84,0x40,
  1354.       0xFE,0x41,0x04,0x40,0x00,0x78,0x00,0x00,
  1355. //-- 》 --
  1356.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1357.       0x00,0x00,0x00,0x00,0x18,0x18,0x60,0x06,
  1358.       0x80,0x01,0x18,0x18,0x60,0x06,0x80,0x01,
  1359.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1360. //-- 最 --
  1361.       0x40,0x20,0x40,0x20,0xC0,0x3F,0x5F,0x15,
  1362.       0x55,0x15,0x55,0x15,0xD5,0xFF,0x55,0x81,
  1363.       0x55,0x47,0x55,0x29,0x55,0x11,0x5F,0x29,
  1364.       0x40,0x65,0x60,0xC3,0x40,0x40,0x00,0x00,
  1365. //-- 初 --
  1366.       0x10,0x02,0x10,0x01,0x91,0x00,0xD6,0xFF,
  1367.       0x30,0x01,0x98,0x82,0x00,0x40,0x08,0x20,
  1368.       0x08,0x18,0xF8,0x07,0x08,0x40,0x08,0x80,
  1369.       0x08,0x40,0xFC,0x3F,0x08,0x00,0x00,0x00,
  1370. //-- 沒 --
  1371.       0x10,0x04,0x21,0x04,0x62,0xFE,0x06,0x01,
  1372.       0x00,0x80,0x40,0x80,0xA0,0x41,0x9E,0x46,
  1373.       0x82,0x28,0x82,0x10,0x82,0x28,0x9F,0x46,
  1374.       0xA2,0xC1,0x20,0x40,0x20,0x40,0x00,0x00,
  1375. //-- 有 --
  1376.       0x04,0x04,0x04,0x02,0x04,0x01,0x84,0x00,
  1377.       0xE4,0xFF,0x3C,0x09,0x27,0x09,0x24,0x09,
  1378.       0x24,0x09,0x24,0x49,0x24,0x89,0xF4,0x7F,
  1379.       0x24,0x00,0x06,0x00,0x04,0x00,0x00,0x00,
  1380. //-- 固 --
  1381.       0x00,0x00,0xFE,0xFF,0x02,0x40,0x12,0x40,
  1382.       0x92,0x5F,0x92,0x48,0x92,0x48,0xFE,0x48,
  1383.       0x92,0x48,0x92,0x48,0xDA,0x5F,0x92,0x40,
  1384.       0x02,0x40,0xFF,0xFF,0x02,0x00,0x00,0x00,
  1385. //-- 定 --
  1386.       0x10,0x80,0x0C,0x40,0x04,0x20,0x24,0x1F,
  1387.       0x24,0x20,0x24,0x40,0x25,0x40,0xE6,0x7F,
  1388.       0x24,0x42,0x24,0x42,0x34,0x43,0x24,0x42,
  1389.       0x04,0x40,0x14,0x60,0x0C,0x20,0x00,0x00,
  1390. //-- 書 --
  1391.       0x00,0x01,0x08,0x01,0x08,0x01,0x08,0x01,
  1392.       0x08,0x01,0x08,0x01,0xFF,0xFF,0x08,0x01,
  1393.       0x08,0x01,0x08,0x01,0xF8,0x21,0x02,0x41,
  1394.       0x04,0x21,0x0C,0x1F,0x00,0x00,0x00,0x00,
  1395. //-- 名 --
  1396.       0x00,0x02,0x00,0x02,0x00,0x02,0x20,0x01,
  1397.       0x10,0xFF,0x9C,0x42,0xA7,0x42,0x44,0x42,
  1398.       0x44,0x42,0x24,0x42,0x14,0x42,0x0C,0x42,
  1399.       0x00,0xFF,0x00,0x02,0x00,0x00,0x00,0x00,
  1400. //-- , --
  1401.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x46,
  1402.       0x00,0x2F,0x00,0x1F,0x00,0x06,0x00,0x00,
  1403.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1404.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1405. //-- 或 --
  1406.       0x08,0x00,0x08,0x20,0xC8,0x2F,0x48,0x24,
  1407.       0x48,0x24,0x48,0x14,0xE8,0x97,0x48,0x90,
  1408.       0x08,0x40,0xFF,0x27,0x08,0x18,0x09,0x26,
  1409.       0xCA,0x41,0x08,0x80,0x08,0x70,0x00,0x00,
  1410. //-- 稱 --
  1411.       0x20,0x10,0x24,0x08,0x24,0x06,0xA4,0x01,
  1412.       0xFE,0xFF,0xA3,0x00,0x22,0x11,0x10,0x0C,
  1413.       0x1C,0x43,0x13,0x80,0xD0,0x7F,0x10,0x00,
  1414.       0x50,0x01,0x30,0x06,0x10,0x0C,0x00,0x00,
  1415. //-- “ --
  1416.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1417.       0x00,0x00,0x00,0x00,0x60,0x00,0xF0,0x00,
  1418.       0xF8,0x00,0x68,0x00,0x04,0x00,0x60,0x00,
  1419.       0xF0,0x00,0xF8,0x00,0x68,0x00,0x04,0x00,
  1420. //-- 太 --
  1421.       0x20,0x40,0x20,0x40,0x20,0x20,0x20,0x20,
  1422.       0x20,0x10,0x20,0x0C,0x20,0x0B,0xFF,0x30,
  1423.       0x20,0x03,0x20,0x0C,0x20,0x10,0x20,0x10,
  1424.       0x20,0x20,0x30,0x60,0x20,0x20,0x00,0x00,
  1425. //-- 史 --
  1426.       0x00,0x80,0x00,0x80,0xF8,0x41,0x88,0x40,
  1427.       0x88,0x22,0x88,0x14,0x88,0x08,0xFF,0x17,
  1428.       0x88,0x10,0x88,0x20,0x88,0x20,0x88,0x40,
  1429.       0xFC,0x41,0x08,0xC0,0x00,0x40,0x00,0x00,
  1430. //-- 公 --
  1431.       0x00,0x01,0x00,0x01,0x80,0x00,0x40,0x30,
  1432.       0x30,0x28,0x0C,0x24,0x00,0x23,0xC0,0x20,
  1433.       0x06,0x20,0x18,0x28,0x20,0x30,0x40,0x60,
  1434.       0x80,0x00,0x80,0x01,0x80,0x00,0x00,0x00,
  1435. //-- 書 --
  1436.       0x00,0x01,0x08,0x01,0x08,0x01,0x08,0x01,
  1437.       0x08,0x01,0x08,0x01,0xFF,0xFF,0x08,0x01,
  1438.       0x08,0x01,0x08,0x01,0xF8,0x21,0x02,0x41,
  1439.       0x04,0x21,0x0C,0x1F,0x00,0x00,0x00,0x00,
  1440. //-- ” --
  1441.       0x00,0x00,0x00,0x00,0x8C,0x00,0x5E,0x00,
  1442.       0x3E,0x00,0x0C,0x00,0x00,0x00,0x8C,0x00,
  1443.       0x5E,0x00,0x3E,0x00,0x0C,0x00,0x00,0x00,
  1444.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1445. //-- , --
  1446.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x46,
  1447.       0x00,0x2F,0x00,0x1F,0x00,0x06,0x00,0x00,
  1448.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1449. //-- 或 --
  1450.       0x08,0x00,0x08,0x20,0xC8,0x2F,0x48,0x24,
  1451.       0x48,0x24,0x48,0x14,0xE8,0x97,0x48,0x90,
  1452.       0x08,0x40,0xFF,0x27,0x08,0x18,0x09,0x26,
  1453.       0xCA,0x41,0x08,0x80,0x08,0x70,0x00,0x00,
  1454. //-- 稱 --
  1455.       0x20,0x10,0x24,0x08,0x24,0x06,0xA4,0x01,
  1456.       0xFE,0xFF,0xA3,0x00,0x22,0x11,0x10,0x0C,
  1457.       0x1C,0x43,0x13,0x80,0xD0,0x7F,0x10,0x00,
  1458.       0x50,0x01,0x30,0x06,0x10,0x0C,0x00,0x00,
  1459. //-- “ --
  1460.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1461.       0x00,0x00,0x00,0x00,0x60,0x00,0xF0,0x00,
  1462.       0xF8,0x00,0x68,0x00,0x04,0x00,0x60,0x00,
  1463.       0xF0,0x00,0xF8,0x00,0x68,0x00,0x04,0x00,
  1464. //-- 太 --
  1465.       0x20,0x40,0x20,0x40,0x20,0x20,0x20,0x20,
  1466.       0x20,0x10,0x20,0x0C,0x20,0x0B,0xFF,0x30,
  1467.       0x20,0x03,0x20,0x0C,0x20,0x10,0x20,0x10,
  1468.       0x20,0x20,0x30,0x60,0x20,0x20,0x00,0x00,
  1469. //-- 史 --
  1470.       0x00,0x80,0x00,0x80,0xF8,0x41,0x88,0x40,
  1471.       0x88,0x22,0x88,0x14,0x88,0x08,0xFF,0x17,
  1472.       0x88,0x10,0x88,0x20,0x88,0x20,0x88,0x40,
  1473.       0xFC,0x41,0x08,0xC0,0x00,0x40,0x00,0x00,
  1474. //-- 公 --
  1475.       0x00,0x01,0x00,0x01,0x80,0x00,0x40,0x30,
  1476.       0x30,0x28,0x0C,0x24,0x00,0x23,0xC0,0x20,
  1477.       0x06,0x20,0x18,0x28,0x20,0x30,0x40,0x60,
  1478.       0x80,0x00,0x80,0x01,0x80,0x00,0x00,0x00,
  1479. //-- 傳 --
  1480.       0x80,0x00,0x40,0x00,0x20,0x00,0xF8,0xFF,
  1481.       0x47,0x00,0x48,0x00,0x48,0x02,0x48,0x0B,
  1482.       0xC8,0x12,0x7F,0x62,0x48,0xD2,0x48,0x0A,
  1483.       0x4C,0x06,0x68,0x02,0x40,0x00,0x00,0x00,
  1484. //-- ” --
  1485.       0x00,0x00,0x00,0x00,0x8C,0x00,0x5E,0x00,
  1486.       0x3E,0x00,0x0C,0x00,0x00,0x00,0x8C,0x00,
  1487.       0x5E,0x00,0x3E,0x00,0x0C,0x00,0x00,0x00,
  1488.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1489. //-- , --
  1490.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x46,
  1491.       0x00,0x2F,0x00,0x1F,0x00,0x06,0x00,0x00,
  1492.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1493.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1494. //-- 也 --
  1495.       0x80,0x00,0x80,0x00,0x80,0x00,0xF8,0x3F,
  1496.       0x40,0x40,0x40,0x40,0x40,0x40,0xFF,0x4F,
  1497.       0x20,0x40,0x20,0x42,0x10,0x44,0xF0,0x43,
  1498.       0x00,0x40,0x00,0x40,0x00,0x78,0x00,0x00,
  1499. //-- 省 --
  1500.       0x00,0x02,0x00,0x02,0x20,0x01,0x18,0x01,
  1501.       0x86,0xFF,0x80,0x55,0x40,0x55,0x5F,0x55,
  1502.       0x20,0x55,0x20,0x55,0x12,0x55,0x04,0x55,
  1503.       0x88,0xFF,0x18,0x01,0x00,0x00,0x00,0x00,
  1504.       0x88,0xFF,0x18,0x01,0x00,0x00,0x00,0x00,
  1505. //-- 稱 --
  1506.       0x20,0x10,0x24,0x08,0x24,0x06,0xA4,0x01,
  1507.       0xFE,0xFF,0xA3,0x00,0x22,0x11,0x10,0x0C,
  1508.       0x1C,0x43,0x13,0x80,0xD0,0x7F,0x10,0x00,
  1509.       0x50,0x01,0x30,0x06,0x10,0x0C,0x00,0x00,
  1510. //-- “ --
  1511.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1512.       0x00,0x00,0x00,0x00,0x60,0x00,0xF0,0x00,
  1513.       0xF8,0x00,0x68,0x00,0x04,0x00,0x60,0x00,
  1514.       0xF0,0x00,0xF8,0x00,0x68,0x00,0x04,0x00,
  1515. //-- 太 --
  1516.       0x20,0x40,0x20,0x40,0x20,0x20,0x20,0x20,
  1517.       0x20,0x10,0x20,0x0C,0x20,0x0B,0xFF,0x30,
  1518.       0x20,0x03,0x20,0x0C,0x20,0x10,0x20,0x10,
  1519.       0x20,0x20,0x30,0x60,0x20,0x20,0x00,0x00,
  1520. //-- 史 --
  1521.       0x00,0x80,0x00,0x80,0xF8,0x41,0x88,0x40,
  1522.       0x88,0x22,0x88,0x14,0x88,0x08,0xFF,0x17,
  1523.       0x88,0x10,0x88,0x20,0x88,0x20,0x88,0x40,
  1524.       0xFC,0x41,0x08,0xC0,0x00,0x40,0x00,0x00,
  1525. //-- 公 --
  1526.       0x00,0x01,0x00,0x01,0x80,0x00,0x40,0x30,
  1527.       0x30,0x28,0x0C,0x24,0x00,0x23,0xC0,0x20,
  1528.       0x06,0x20,0x18,0x28,0x20,0x30,0x40,0x60,
  1529.       0x80,0x00,0x80,0x01,0x80,0x00,0x00,0x00,
  1530. //-- ” --
  1531.       0x00,0x00,0x00,0x00,0x8C,0x00,0x5E,0x00,
  1532.       0x3E,0x00,0x0C,0x00,0x00,0x00,0x8C,0x00,
  1533.       0x5E,0x00,0x3E,0x00,0x0C,0x00,0x00,0x00,
  1534.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1535. //-- 。 --
  1536.       0x00,0x00,0x00,0x38,0x00,0x7C,0x00,0x44,
  1537.       0x00,0x44,0x00,0x7C,0x00,0x38,0x00,0x00,
  1538.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1539.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1540. //-- 記 --
  1541.       0x40,0x00,0x40,0x00,0x42,0x00,0xCC,0x7F,
  1542.       0x00,0x20,0x04,0x10,0x84,0x3F,0x84,0x40,
  1543.       0x84,0x40,0x84,0x40,0x84,0x40,0x84,0x40,
  1544.       0xFE,0x41,0x04,0x40,0x00,0x78,0x00,0x00,
  1545. //-- 本 --
  1546.       0x00,0x10,0x10,0x10,0x10,0x08,0x10,0x04,
  1547.       0x10,0x0B,0xF0,0x08,0x10,0x08,0xFF,0xFF,
  1548.       0x10,0x08,0xF0,0x08,0x10,0x0B,0x10,0x04,
  1549.       0x18,0x08,0x10,0x18,0x00,0x08,0x00,0x00,
  1550. //-- 是 --
  1551.       0x00,0x01,0x00,0x81,0x00,0x41,0x00,0x21,
  1552.       0x7F,0x1D,0x49,0x21,0x49,0x41,0x49,0x7F,
  1553.       0x49,0x89,0x49,0x89,0x7F,0x8D,0x00,0x89,
  1554.       0x00,0x81,0x80,0xC1,0x00,0x41,0x00,0x00,
  1555. //-- 古 --
  1556.       0x10,0x00,0x10,0x00,0x10,0x00,0x10,0xFF,
  1557.       0x10,0x41,0x10,0x41,0x10,0x41,0xFF,0x41,
  1558.       0x10,0x41,0x10,0x41,0x10,0x41,0x90,0xFF,
  1559.       0x10,0x01,0x18,0x00,0x10,0x00,0x00,0x00,
  1560. //-- 代 --
  1561.       0x80,0x00,0x40,0x00,0x20,0x00,0xF8,0xFF,
  1562.       0x47,0x00,0x40,0x00,0x40,0x00,0x40,0x00,
  1563.       0x7F,0x00,0xA0,0x03,0x22,0x0C,0x2C,0x30,
  1564.       0x20,0x40,0x30,0x80,0x20,0xF0,0x00,0x00,
  1565. //-- 書 --
  1566.       0x00,0x01,0x08,0x01,0x08,0x01,0x08,0x01,
  1567.       0x08,0x01,0x08,0x01,0xFF,0xFF,0x08,0x01,
  1568.       0x08,0x01,0x08,0x01,0xF8,0x21,0x02,0x41,
  1569.       0x04,0x21,0x0C,0x1F,0x00,0x00,0x00,0x00,
  1570. //-- 通 --
  1571.       0x40,0x00,0x42,0x40,0x44,0x20,0xCC,0x1F,
  1572.       0x00,0x20,0x00,0x40,0xF1,0xBF,0x91,0x84,
  1573.       0x95,0x84,0xF9,0xBF,0x95,0x94,0x93,0xA4,
  1574.       0xF9,0x9F,0x10,0xC0,0x00,0x40,0x00,0x00,
  1575. //-- , --
  1576.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x46,
  1577.       0x00,0x2F,0x00,0x1F,0x00,0x06,0x00,0x00,
  1578.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1579.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1580. //-- 從 --
  1581.       0x00,0x80,0x00,0x40,0x00,0x30,0x00,0x0C,
  1582.       0xFE,0x03,0x00,0x84,0x00,0x48,0x00,0x30,
  1583.       0x00,0x18,0x80,0x07,0x7E,0x00,0x80,0x07,
  1584.       0x00,0x38,0x00,0xE0,0x00,0x40,0x00,0x00,
  1585. //-- 三 --
  1586.       0x00,0x20,0x04,0x20,0x84,0x20,0x84,0x20,
  1587.       0x84,0x20,0x84,0x20,0x84,0x20,0x84,0x20,
  1588.       0x84,0x20,0x84,0x20,0x84,0x20,0xC4,0x20,
  1589.       0x86,0x20,0x04,0x30,0x00,0x20,0x00,0x00,
  1590. //-- 國 --
  1591.       0x00,0x00,0xFE,0xFF,0x02,0x40,0x0A,0x50,
  1592.       0x8A,0x50,0x8A,0x50,0x8A,0x50,0xFA,0x5F,
  1593.       0x8A,0x50,0xCA,0x52,0x8E,0x54,0x0A,0x50,
  1594.       0x02,0x40,0xFF,0xFF,0x02,0x00,0x00,0x00,
  1595. //-- 時 --
  1596.       0x00,0x00,0xFC,0x3F,0x84,0x10,0x84,0x10,
  1597.       0x84,0x10,0xFE,0x3F,0x14,0x00,0x10,0x00,
  1598.       0x90,0x00,0x10,0x23,0x10,0x40,0x10,0x80,
  1599.       0xFF,0x7F,0x10,0x00,0x10,0x00,0x00,0x00,
  1600. //-- 期 --
  1601.       0x00,0x84,0x08,0x44,0xFF,0x37,0xA8,0x04,
  1602.       0xA8,0x04,0xA8,0x14,0xFF,0xA7,0x08,0x44,
  1603.       0x00,0x24,0xFE,0x1F,0x22,0x02,0x22,0x42,
  1604.       0x22,0x82,0xFF,0x7F,0x02,0x00,0x00,0x00,
  1605. //-- 開 --
  1606.       0x80,0x00,0x82,0x80,0x82,0x40,0x82,0x30,
  1607.       0xFE,0x0F,0x82,0x00,0x82,0x00,0x82,0x00,
  1608.       0x82,0x00,0x82,0x00,0xFE,0xFF,0x82,0x00,
  1609.       0x83,0x00,0xC2,0x00,0x80,0x00,0x00,0x00,
  1610. //-- 始 --
  1611.       0x10,0x40,0x10,0x22,0xF0,0x15,0x1F,0x08,
  1612.       0x10,0x16,0xF0,0x61,0x40,0x00,0x60,0xFE,
  1613.       0x58,0x42,0x47,0x42,0x40,0x42,0x40,0x42,
  1614.       0x50,0x42,0x60,0xFF,0xC0,0x02,0x00,0x00,
  1615. //-- , --
  1616.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x46,
  1617.       0x00,0x2F,0x00,0x1F,0x00,0x06,0x00,0x00,
  1618.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1619.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1620. //-- “ --
  1621.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1622.       0x00,0x00,0x00,0x00,0x60,0x00,0xF0,0x00,
  1623.       0xF8,0x00,0x68,0x00,0x04,0x00,0x60,0x00,
  1624.       0xF0,0x00,0xF8,0x00,0x68,0x00,0x04,0x00,
  1625. //-- 史 --
  1626.       0x00,0x80,0x00,0x80,0xF8,0x41,0x88,0x40,
  1627.       0x88,0x22,0x88,0x14,0x88,0x08,0xFF,0x17,
  1628.       0x88,0x10,0x88,0x20,0x88,0x20,0x88,0x40,
  1629.       0xFC,0x41,0x08,0xC0,0x00,0x40,0x00,0x00,
  1630. //-- 記 --
  1631.       0x40,0x00,0x40,0x00,0x42,0x00,0xCC,0x7F,
  1632.       0x00,0x20,0x04,0x10,0x84,0x3F,0x84,0x40,
  1633.       0x84,0x40,0x84,0x40,0x84,0x40,0x84,0x40,
  1634.       0xFE,0x41,0x04,0x40,0x00,0x78,0x00,0x00,
  1635. //-- ” --
  1636.       0x00,0x00,0x00,0x00,0x8C,0x00,0x5E,0x00,
  1637.       0x3E,0x00,0x0C,0x00,0x00,0x00,0x8C,0x00,
  1638.       0x5E,0x00,0x3E,0x00,0x0C,0x00,0x00,0x00,
  1639.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1640. //-- 由 --
  1641.       0x00,0x00,0xF0,0xFF,0x10,0x42,0x10,0x42,
  1642.       0x10,0x42,0x10,0x42,0x10,0x42,0xFF,0x7F,
  1643.       0x10,0x42,0x10,0x42,0x10,0x42,0x10,0x42,
  1644.       0x10,0x42,0xF8,0xFF,0x10,0x00,0x00,0x00,
  1645. //-- 史 --
  1646.       0x00,0x80,0x00,0x80,0xF8,0x41,0x88,0x40,
  1647.       0x88,0x22,0x88,0x14,0x88,0x08,0xFF,0x17,
  1648.       0x88,0x10,0x88,0x20,0x88,0x20,0x88,0x40,
  1649.       0xFC,0x41,0x08,0xC0,0x00,0x40,0x00,0x00,
  1650. //-- 書 --
  1651.       0x00,0x01,0x08,0x01,0x08,0x01,0x08,0x01,
  1652.       0x08,0x01,0x08,0x01,0xFF,0xFF,0x08,0x01,
  1653.       0x08,0x01,0x08,0x01,0xF8,0x21,0x02,0x41,
  1654.       0x04,0x21,0x0C,0x1F,0x00,0x00,0x00,0x00,
  1655. //-- 的 --
  1656.       0x00,0x00,0xF8,0x7F,0x0C,0x21,0x0B,0x21,
  1657.       0x08,0x21,0x08,0x21,0xFC,0x7F,0x28,0x00,
  1658.       0x90,0x00,0x0F,0x01,0x08,0x43,0x08,0x80,
  1659.       0x08,0x40,0xFC,0x3F,0x08,0x00,0x00,0x00,
  1660. //-- 通 --
  1661.       0x40,0x00,0x42,0x40,0x44,0x20,0xCC,0x1F,
  1662.       0x00,0x20,0x00,0x40,0xF1,0xBF,0x91,0x84,
  1663.       0x95,0x84,0xF9,0xBF,0x95,0x94,0x93,0xA4,
  1664.       0xF9,0x9F,0x10,0xC0,0x00,0x40,0x00,0x00,
  1665. //-- 稱 --
  1666.       0x20,0x10,0x24,0x08,0x24,0x06,0xA4,0x01,
  1667.       0xFE,0xFF,0xA3,0x00,0x22,0x11,0x10,0x0C,
  1668.       0x1C,0x43,0x13,0x80,0xD0,0x7F,0x10,0x00,
  1669.       0x50,0x01,0x30,0x06,0x10,0x0C,0x00,0x00,
  1670. //-- 逐 --
  1671.       0x40,0x40,0x42,0x20,0xCC,0x1F,0x00,0x20,
  1672.       0x22,0x49,0x22,0x49,0x92,0x44,0x5A,0x52,
  1673.       0x36,0x61,0xE2,0x5F,0x42,0x41,0x22,0x42,
  1674.       0x33,0x4C,0x02,0x60,0x00,0x20,0x00,0x00,
  1675. //-- 漸 --
  1676.       0x20,0x04,0x42,0x04,0xCC,0xFE,0x00,0x09,
  1677.       0xC8,0x18,0xB8,0x08,0x8F,0x08,0xE8,0xFF,
  1678.       0x88,0x44,0x88,0x24,0xFC,0x1F,0x44,0x00,
  1679.       0xC2,0xFF,0x62,0x00,0x40,0x00,0x00,0x00,
  1680. //-- 成 --
  1681.       0x00,0x40,0x00,0x20,0xF8,0x1F,0x88,0x00,
  1682.       0x88,0x08,0x88,0x10,0x88,0x0F,0x08,0x40,
  1683.       0x7F,0x20,0x88,0x13,0x0A,0x1C,0x0C,0x24,
  1684.       0x08,0x43,0xC8,0x80,0x00,0xF0,0x00,0x00,
  1685. //-- 為 --
  1686.       0x20,0x00,0x20,0x40,0x20,0x20,0x22,0x10,
  1687.       0x24,0x08,0x2C,0x04,0x20,0x03,0xE0,0x00,
  1688.       0x3F,0x02,0x20,0x04,0x20,0x4C,0x20,0x80,
  1689.       0x20,0x40,0xF0,0x3F,0x20,0x00,0x00,0x00,
  1690. //-- “ --
  1691.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1692.       0x00,0x00,0x00,0x00,0x60,0x00,0xF0,0x00,
  1693.       0xF8,0x00,0x68,0x00,0x04,0x00,0x60,0x00,
  1694.       0xF0,0x00,0xF8,0x00,0x68,0x00,0x04,0x00,
  1695. //-- 太 --
  1696.       0x20,0x40,0x20,0x40,0x20,0x20,0x20,0x20,
  1697.       0x20,0x10,0x20,0x0C,0x20,0x0B,0xFF,0x30,
  1698.       0x20,0x03,0x20,0x0C,0x20,0x10,0x20,0x10,
  1699.       0x20,0x20,0x30,0x60,0x20,0x20,0x00,0x00,
  1700. //-- 史 --
  1701.       0x00,0x80,0x00,0x80,0xF8,0x41,0x88,0x40,
  1702.       0x88,0x22,0x88,0x14,0x88,0x08,0xFF,0x17,
  1703.       0x88,0x10,0x88,0x20,0x88,0x20,0x88,0x40,
  1704.       0xFC,0x41,0x08,0xC0,0x00,0x40,0x00,0x00,
  1705. //-- 公 --
  1706.       0x00,0x01,0x00,0x01,0x80,0x00,0x40,0x30,
  1707.       0x30,0x28,0x0C,0x24,0x00,0x23,0xC0,0x20,
  1708.       0x06,0x20,0x18,0x28,0x20,0x30,0x40,0x60,
  1709.       0x80,0x00,0x80,0x01,0x80,0x00,0x00,0x00,
  1710. //-- 書 --
  1711.       0x00,0x01,0x08,0x01,0x08,0x01,0x08,0x01,
  1712.       0x08,0x01,0x08,0x01,0xFF,0xFF,0x08,0x01,
  1713.       0x08,0x01,0x08,0x01,0xF8,0x21,0x02,0x41,
  1714.       0x04,0x21,0x0C,0x1F,0x00,0x00,0x00,0x00,
  1715. //-- ” --
  1716.       0x00,0x00,0x00,0x00,0x8C,0x00,0x5E,0x00,
  1717.       0x3E,0x00,0x0C,0x00,0x00,0x00,0x8C,0x00,
  1718.       0x5E,0x00,0x3E,0x00,0x0C,0x00,0x00,0x00,
  1719.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1720. //-- 的 --
  1721.       0x00,0x00,0xF8,0x7F,0x0C,0x21,0x0B,0x21,
  1722.       0x08,0x21,0x08,0x21,0xFC,0x7F,0x28,0x00,
  1723.       0x90,0x00,0x0F,0x01,0x08,0x43,0x08,0x80,
  1724.       0x08,0x40,0xFC,0x3F,0x08,0x00,0x00,0x00,
  1725. //-- 專 --
  1726.       0x40,0x00,0x40,0x00,0x48,0x00,0x48,0x00,
  1727.       0x48,0x02,0xC8,0x23,0x78,0x22,0x4F,0x42,
  1728.       0x48,0x62,0x48,0x92,0x48,0x0A,0x4C,0x06,
  1729.       0x48,0x02,0x60,0x00,0x40,0x00,0x00,0x00,
  1730. //-- 稱 --
  1731.       0x20,0x10,0x24,0x08,0x24,0x06,0xA4,0x01,
  1732.       0xFE,0xFF,0xA3,0x00,0x22,0x11,0x10,0x0C,
  1733.       0x1C,0x43,0x13,0x80,0xD0,0x7F,0x10,0x00,
  1734.       0x50,0x01,0x30,0x06,0x10,0x0C,0x00,0x00,
  1735. //-- 。 --
  1736.       0x00,0x00,0x00,0x38,0x00,0x7C,0x00,0x44,
  1737.       0x00,0x44,0x00,0x7C,0x00,0x38,0x00,0x00,
  1738.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1739.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1740. //-- 《 --
  1741.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1742.       0x80,0x01,0x60,0x06,0x18,0x18,0x80,0x01,
  1743.       0x60,0x06,0x18,0x18,0x00,0x00,0x00,0x00,
  1744.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1745. //-- 史 --
  1746.       0x00,0x80,0x00,0x80,0xF8,0x41,0x88,0x40,
  1747.       0x88,0x22,0x88,0x14,0x88,0x08,0xFF,0x17,
  1748.       0x88,0x10,0x88,0x20,0x88,0x20,0x88,0x40,
  1749.       0xFC,0x41,0x08,0xC0,0x00,0x40,0x00,0x00,
  1750. //-- 記 --
  1751.       0x40,0x00,0x40,0x00,0x42,0x00,0xCC,0x7F,
  1752.       0x00,0x20,0x04,0x10,0x84,0x3F,0x84,0x40,
  1753.       0x84,0x40,0x84,0x40,0x84,0x40,0x84,0x40,
  1754.       0xFE,0x41,0x04,0x40,0x00,0x78,0x00,0x00,
  1755. //-- 》 --
  1756.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1757.       0x00,0x00,0x00,0x00,0x18,0x18,0x60,0x06,
  1758.       0x80,0x01,0x18,0x18,0x60,0x06,0x80,0x01,
  1759.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1760. //-- 與 --
  1761.       0x00,0x08,0x00,0x08,0x00,0x08,0xFF,0x08,
  1762.       0x88,0x08,0x88,0x08,0x88,0x08,0x88,0x08,
  1763.       0x88,0x08,0x88,0x4C,0x88,0x88,0x88,0x40,
  1764.       0xCC,0x3F,0x88,0x00,0x00,0x00,0x00,0x00,
  1765. //-- 后 --
  1766.       0x00,0x40,0x00,0x30,0xFC,0x0F,0x24,0x00,
  1767.       0x24,0x00,0x24,0xFF,0x24,0x41,0x24,0x41,
  1768.       0x24,0x41,0x22,0x41,0x22,0x41,0x23,0x41,
  1769.       0xA2,0xFF,0x30,0x01,0x20,0x00,0x00,0x00,
  1770. //-- 來 --
  1771.       0x00,0x21,0x08,0x21,0x28,0x11,0x48,0x11,
  1772.       0xC8,0x09,0x08,0x05,0x08,0x03,0xFF,0xFF,
  1773.       0x08,0x03,0x88,0x05,0x48,0x09,0x68,0x19,
  1774.       0x0C,0x11,0x88,0x31,0x00,0x11,0x00,0x00,
  1775. //-- 的 --
  1776.       0x00,0x00,0xF8,0x7F,0x0C,0x21,0x0B,0x21,
  1777.       0x08,0x21,0x08,0x21,0xFC,0x7F,0x28,0x00,
  1778.       0x90,0x00,0x0F,0x01,0x08,0x43,0x08,0x80,
  1779.       0x08,0x40,0xFC,0x3F,0x08,0x00,0x00,0x00,
  1780. //-- 漢 --
  1781.       0x10,0x04,0x22,0x04,0x64,0x7E,0x0C,0x01,
  1782.       0x80,0x80,0x04,0x40,0x74,0x20,0x84,0x11,
  1783.       0x04,0x0A,0x04,0x04,0x04,0x0B,0xC4,0x10,
  1784.       0x3E,0x60,0x04,0xC0,0x00,0x40,0x00,0x00,
  1785. //-- 書 --
  1786.       0x00,0x01,0x08,0x01,0x08,0x01,0x08,0x01,
  1787.       0x08,0x01,0x08,0x01,0xFF,0xFF,0x08,0x01,
  1788.       0x08,0x01,0x08,0x01,0xF8,0x21,0x02,0x41,
  1789.       0x04,0x21,0x0C,0x1F,0x00,0x00,0x00,0x00,
  1790. //-- ( --
  1791.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1792.       0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x01,
  1793.       0xE0,0x07,0x38,0x1C,0x08,0x10,0x04,0x20,
  1794.       0x02,0x40,0x00,0x00,0x00,0x00,0x00,0x00,
  1795. //-- 班 --
  1796.       0x84,0x20,0x84,0x60,0xFC,0x3F,0x84,0x10,
  1797.       0x06,0x92,0xF4,0x41,0x00,0x38,0xFF,0x07,
  1798.       0x00,0x40,0x84,0x40,0x84,0x40,0xFC,0x7F,
  1799.       0x84,0x40,0x86,0x60,0x04,0x40,0x00,0x00,
  1800. //-- 固 --
  1801.       0x00,0x00,0xFE,0xFF,0x02,0x40,0x12,0x40,
  1802.       0x92,0x5F,0x92,0x48,0x92,0x48,0xFE,0x48,
  1803.       0x92,0x48,0x92,0x48,0xDA,0x5F,0x92,0x40,
  1804.       0x02,0x40,0xFF,0xFF,0x02,0x00,0x00,0x00,
  1805. //-- ) --
  1806.       0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x40,
  1807.       0x04,0x20,0x08,0x10,0x38,0x1C,0xE0,0x07,
  1808.       0x80,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
  1809.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1810. //-- 、 --
  1811.       0x00,0x00,0x00,0x00,0x00,0x04,0x00,0x0C,
  1812.       0x00,0x18,0x00,0x38,0x00,0x38,0x00,0x30,
  1813.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1814.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1815. //-- 《 --
  1816.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1817.       0x80,0x01,0x60,0x06,0x18,0x18,0x80,0x01,
  1818.       0x60,0x06,0x18,0x18,0x00,0x00,0x00,0x00,
  1819.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1820. //-- 后 --
  1821.       0x00,0x40,0x00,0x30,0xFC,0x0F,0x24,0x00,
  1822.       0x24,0x00,0x24,0xFF,0x24,0x41,0x24,0x41,
  1823.       0x24,0x41,0x22,0x41,0x22,0x41,0x23,0x41,
  1824.       0xA2,0xFF,0x30,0x01,0x20,0x00,0x00,0x00,
  1825. //-- 漢 --
  1826.       0x10,0x04,0x22,0x04,0x64,0x7E,0x0C,0x01,
  1827.       0x80,0x80,0x04,0x40,0x74,0x20,0x84,0x11,
  1828.       0x04,0x0A,0x04,0x04,0x04,0x0B,0xC4,0x10,
  1829.       0x3E,0x60,0x04,0xC0,0x00,0x40,0x00,0x00,
  1830. //-- 書 --
  1831.       0x00,0x01,0x08,0x01,0x08,0x01,0x08,0x01,
  1832.       0x08,0x01,0x08,0x01,0xFF,0xFF,0x08,0x01,
  1833.       0x08,0x01,0x08,0x01,0xF8,0x21,0x02,0x41,
  1834.       0x04,0x21,0x0C,0x1F,0x00,0x00,0x00,0x00,
  1835. //-- 》 --
  1836.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1837.       0x00,0x00,0x00,0x00,0x18,0x18,0x60,0x06,
  1838.       0x80,0x01,0x18,0x18,0x60,0x06,0x80,0x01,
  1839.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1840. //-- ( --
  1841.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1842.       0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x01,
  1843.       0xE0,0x07,0x38,0x1C,0x08,0x10,0x04,0x20,
  1844.       0x02,0x40,0x00,0x00,0x00,0x00,0x00,0x00,
  1845. //-- 范 --
  1846.       0x04,0x04,0x44,0x04,0x94,0xFD,0x24,0x04,
  1847.       0x6F,0x02,0x04,0x00,0xE4,0x3F,0x24,0x40,
  1848.       0x24,0x40,0x24,0x42,0x2F,0x44,0xF4,0x43,
  1849.       0x24,0x40,0x06,0x40,0x04,0x70,0x00,0x00,
  1850. //-- 曄 --
  1851.       0x00,0x00,0xFC,0x3F,0x84,0x10,0x84,0x10,
  1852.       0xFE,0x3F,0x24,0x04,0x10,0x04,0xFC,0x05,
  1853.       0x43,0x04,0x20,0xFF,0x7F,0x04,0x88,0x04,
  1854.       0x84,0x04,0x86,0x06,0xE0,0x04,0x00,0x00,
  1855. //-- 、 --
  1856.       0x00,0x00,0x00,0x00,0x00,0x04,0x00,0x0C,
  1857.       0x00,0x18,0x00,0x38,0x00,0x38,0x00,0x30,
  1858.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1859.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1860. //-- 司 --
  1861.       0x10,0x00,0x10,0x00,0x92,0x3F,0x92,0x10,
  1862.       0x92,0x10,0x92,0x10,0x92,0x10,0x92,0x10,
  1863.       0xD2,0x3F,0x9A,0x00,0x12,0x40,0x02,0x80,
  1864.       0xFF,0x7F,0x02,0x00,0x00,0x00,0x00,0x00,
  1865. //-- 馬 --
  1866.       0x00,0x08,0x00,0x08,0x02,0x08,0x02,0x08,
  1867.       0xFA,0x09,0x02,0x09,0x02,0x09,0x02,0x09,
  1868.       0x02,0x09,0x02,0x09,0xFF,0x4D,0x02,0x89,
  1869.       0x00,0x41,0x80,0x3F,0x00,0x01,0x00,0x00,
  1870. //-- 彪 --
  1871.       0x00,0x40,0x00,0x20,0xF8,0x9F,0x48,0x40,
  1872.       0x48,0x3E,0xFF,0x02,0xAA,0x02,0xAB,0x3E,
  1873.       0xDA,0x40,0x08,0x62,0x10,0x51,0x88,0x48,
  1874.       0x44,0x44,0x66,0x46,0x00,0x70,0x00,0x00,
  1875. //-- 、 --
  1876.       0x00,0x00,0x00,0x00,0x00,0x04,0x00,0x0C,
  1877.       0x00,0x18,0x00,0x38,0x00,0x38,0x00,0x30,
  1878.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1879.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1880. //-- 《 --
  1881.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1882.       0x80,0x01,0x60,0x06,0x18,0x18,0x80,0x01,
  1883.       0x60,0x06,0x18,0x18,0x00,0x00,0x00,0x00,
  1884.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1885. //-- 三 --
  1886.       0x00,0x20,0x04,0x20,0x84,0x20,0x84,0x20,
  1887.       0x84,0x20,0x84,0x20,0x84,0x20,0x84,0x20,
  1888.       0x84,0x20,0x84,0x20,0x84,0x20,0xC4,0x20,
  1889.       0x86,0x20,0x04,0x30,0x00,0x20,0x00,0x00,
  1890. //-- 國 --
  1891.       0x00,0x00,0xFE,0xFF,0x02,0x40,0x0A,0x50,
  1892.       0x8A,0x50,0x8A,0x50,0x8A,0x50,0xFA,0x5F,
  1893.       0x8A,0x50,0xCA,0x52,0x8E,0x54,0x0A,0x50,
  1894.       0x02,0x40,0xFF,0xFF,0x02,0x00,0x00,0x00,
  1895. //-- 志 --
  1896.       0x08,0x20,0x08,0x18,0x88,0x00,0x88,0x3C,
  1897.       0x88,0x40,0x88,0x40,0x88,0x42,0xFF,0x44,
  1898.       0x88,0x4C,0x88,0x40,0x88,0x40,0xC8,0x70,
  1899.       0x88,0x00,0x0C,0x08,0x08,0x30,0x00,0x00,
  1900. //-- 》 --
  1901.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1902.       0x00,0x00,0x00,0x00,0x18,0x18,0x60,0x06,
  1903.       0x80,0x01,0x18,0x18,0x60,0x06,0x80,0x01,
  1904.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1905. //-- ( --
  1906.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1907.       0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x01,
  1908.       0xE0,0x07,0x38,0x1C,0x08,0x10,0x04,0x20,
  1909.       0x02,0x40,0x00,0x00,0x00,0x00,0x00,0x00,
  1910. //-- 陳 --
  1911.       0x00,0x00,0xFE,0xFF,0x22,0x04,0x5A,0x08,
  1912.       0x86,0x07,0x08,0x20,0x88,0x11,0x48,0x0D,
  1913.       0x38,0x41,0x0F,0x81,0xE8,0x7F,0x08,0x01,
  1914.       0x88,0x05,0x0C,0x19,0x08,0x30,0x00,0x00,
  1915. //-- 壽 --
  1916.       0x40,0x20,0x44,0x10,0x54,0x08,0x54,0x06,
  1917.       0xD4,0x01,0x74,0x02,0x5F,0x0A,0x54,0x32,
  1918.       0x54,0x02,0x54,0x42,0x54,0x82,0xD4,0x7F,
  1919.       0x56,0x02,0x44,0x03,0x40,0x02,0x00,0x00,
  1920. //-- ) --
  1921.       0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x40,
  1922.       0x04,0x20,0x08,0x10,0x38,0x1C,0xE0,0x07,
  1923.       0x80,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
  1924.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1925. //-- 合 --
  1926.       0x80,0x00,0x80,0x00,0x40,0x00,0x20,0xFE,
  1927.       0x50,0x42,0x48,0x42,0x44,0x42,0x43,0x42,
  1928.       0x44,0x42,0x48,0x42,0x50,0x42,0x20,0xFF,
  1929.       0x40,0x02,0xC0,0x00,0x40,0x00,0x00,0x00,
  1930. //-- 稱 --
  1931.       0x20,0x10,0x24,0x08,0x24,0x06,0xA4,0x01,
  1932.       0xFE,0xFF,0xA3,0x00,0x22,0x11,0x10,0x0C,
  1933.       0x1C,0x43,0x13,0x80,0xD0,0x7F,0x10,0x00,
  1934.       0x50,0x01,0x30,0x06,0x10,0x0C,0x00,0x00,
  1935. //-- “ --
  1936.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1937.       0x00,0x00,0x00,0x00,0x60,0x00,0xF0,0x00,
  1938.       0xF8,0x00,0x68,0x00,0x04,0x00,0x60,0x00,
  1939.       0xF0,0x00,0xF8,0x00,0x68,0x00,0x04,0x00,
  1940. //-- 前 --
  1941.       0x08,0x00,0x08,0x00,0xE8,0xFF,0x29,0x09,
  1942.       0x2A,0x49,0x2E,0x89,0xE8,0x7F,0x08,0x00,
  1943.       0x08,0x00,0xCC,0x0F,0x0A,0x40,0x0B,0x80,
  1944.       0xE8,0x7F,0x0C,0x00,0x08,0x00,0x00,0x00,
  1945. //-- 四 --
  1946.       0x00,0x00,0xFC,0x7F,0x04,0x20,0x04,0x28,
  1947.       0x04,0x24,0xFC,0x23,0x04,0x20,0x04,0x20,
  1948.       0x04,0x20,0xFC,0x21,0x04,0x22,0x04,0x22,
  1949.       0x04,0x22,0xFE,0x7F,0x04,0x00,0x00,0x00,
  1950. //-- 史 --
  1951.       0x00,0x80,0x00,0x80,0xF8,0x41,0x88,0x40,
  1952.       0x88,0x22,0x88,0x14,0x88,0x08,0xFF,0x17,
  1953.       0x88,0x10,0x88,0x20,0x88,0x20,0x88,0x40,
  1954.       0xFC,0x41,0x08,0xC0,0x00,0x40,0x00,0x00,
  1955. //-- ” --
  1956.       0x00,0x00,0x00,0x00,0x8C,0x00,0x5E,0x00,
  1957.       0x3E,0x00,0x0C,0x00,0x00,0x00,0x8C,0x00,
  1958.       0x5E,0x00,0x3E,0x00,0x0C,0x00,0x00,0x00,
  1959.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1960. //-- 。 --
  1961.       0x00,0x00,0x00,0x38,0x00,0x7C,0x00,0x44,
  1962.       0x00,0x44,0x00,0x7C,0x00,0x38,0x00,0x00,
  1963.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1964.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  1965. //-- 劉 --
  1966.       0x08,0x40,0x28,0x20,0x49,0x10,0x8A,0x09,
  1967.       0x0E,0x06,0x88,0x09,0x78,0x30,0x0C,0x60,
  1968.       0x08,0x00,0x00,0x00,0xFC,0x0F,0x00,0x40,
  1969.       0x00,0x80,0xFF,0x7F,0x00,0x00,0x00,0x00,
  1970. //-- 向 --
  1971.       0x00,0x00,0xF8,0xFF,0x08,0x00,0x08,0x00,
  1972.       0xCC,0x1F,0x4A,0x08,0x49,0x08,0x48,0x08,
  1973.       0x48,0x08,0x48,0x08,0xE8,0x1F,0x48,0x40,
  1974.       0x08,0x80,0xFC,0x7F,0x08,0x00,0x00,0x00,
  1975. //-- 等 --
  1976.       0x00,0x01,0x08,0x01,0x44,0x09,0x47,0x09,
  1977.       0x4C,0x19,0x56,0x29,0x44,0x09,0xF8,0x49,
  1978.       0x44,0x89,0x47,0x7F,0x4C,0x09,0x54,0x0D,
  1979.       0x46,0x09,0x04,0x01,0x00,0x01,0x00,0x00,
  1980. //-- 人 --
  1981.       0x00,0x00,0x00,0x80,0x00,0x40,0x00,0x20,
  1982.       0x00,0x10,0x00,0x0C,0x80,0x03,0x7F,0x00,
  1983.       0x80,0x03,0x00,0x0C,0x00,0x10,0x00,0x20,
  1984.       0x00,0x40,0x00,0xC0,0x00,0x40,0x00,0x00,
  1985. //-- 認 --
  1986.       0x40,0x00,0x42,0x00,0x44,0x00,0xCC,0x3F,
  1987.       0x00,0x90,0x00,0x48,0x00,0x30,0x00,0x0E,
  1988.       0xC0,0x01,0x3F,0x00,0xC0,0x01,0x00,0x0E,
  1989.       0x00,0x30,0x00,0xC0,0x00,0x40,0x00,0x00,
  1990. //-- 為 --
  1991.       0x20,0x00,0x20,0x40,0x20,0x20,0x22,0x10,
  1992.       0x24,0x08,0x2C,0x04,0x20,0x03,0xE0,0x00,
  1993.       0x3F,0x02,0x20,0x04,0x20,0x4C,0x20,0x80,
  1994.       0x20,0x40,0xF0,0x3F,0x20,0x00,0x00,0x00,
  1995. //-- 此 --
  1996.       0x00,0x20,0x00,0x60,0xF8,0x3F,0x00,0x20,
  1997.       0x00,0x20,0xFF,0x1F,0x40,0x10,0x40,0x10,
  1998.       0x00,0x00,0xFF,0x3F,0x40,0x40,0x20,0x40,
  1999.       0x10,0x40,0x18,0x40,0x00,0x70,0x00,0x00,
  2000. //-- 書 --
  2001.       0x00,0x01,0x08,0x01,0x08,0x01,0x08,0x01,
  2002.       0x08,0x01,0x08,0x01,0xFF,0xFF,0x08,0x01,
  2003.       0x08,0x01,0x08,0x01,0xF8,0x21,0x02,0x41,
  2004.       0x04,0x21,0x0C,0x1F,0x00,0x00,0x00,0x00,
  2005. //-- 善 --
  2006.       0x00,0x02,0x44,0x02,0x54,0x02,0x54,0xFA,
  2007.       0xD5,0x4A,0x56,0x4B,0x54,0x4A,0xFC,0x4B,
  2008.       0x54,0x4A,0x56,0x4B,0xD5,0x4A,0x54,0xFE,
  2009.       0x56,0x0A,0x44,0x03,0x00,0x02,0x00,0x00,
  2010. //-- 序 --
  2011.       0x00,0x40,0x00,0x30,0xFC,0x0F,0x04,0x00,
  2012.       0x14,0x01,0x14,0x01,0x14,0x41,0x55,0x81,
  2013.       0x96,0x7F,0x54,0x01,0x34,0x01,0x14,0x05,
  2014.       0x16,0x03,0x04,0x01,0x00,0x00,0x00,0x00,
  2015. //-- 事 --
  2016.       0x04,0x04,0x04,0x04,0x74,0x15,0x54,0x15,
  2017.       0x54,0x15,0x54,0x55,0x54,0x95,0xFF,0x7F,
  2018.       0x54,0x15,0x54,0x15,0x54,0x15,0x54,0x15,
  2019.       0x74,0x3F,0x06,0x04,0x04,0x04,0x00,0x00,
  2020. //-- 理 --
  2021.       0x44,0x10,0x44,0x30,0xFC,0x1F,0x46,0x08,
  2022.       0x44,0x48,0x00,0x48,0xFE,0x44,0x92,0x44,
  2023.       0x92,0x44,0xFE,0x7F,0x92,0x44,0x92,0x46,
  2024.       0xFF,0x44,0x02,0x60,0x00,0x40,0x00,0x00,
  2025. //-- , --
  2026.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x46,
  2027.       0x00,0x2F,0x00,0x1F,0x00,0x06,0x00,0x00,
  2028.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  2029.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  2030. //-- 辯 --
  2031.       0x80,0x04,0x88,0x84,0xE9,0x44,0x8E,0x3F,
  2032.       0xF8,0x04,0xA8,0x04,0x22,0x00,0xEC,0x7F,
  2033.       0x00,0x20,0x88,0x14,0xE9,0x04,0x8E,0xFF,
  2034.       0xF8,0x04,0x88,0x04,0x80,0x00,0x00,0x00,
  2035. //-- 而 --
  2036.       0x02,0x00,0xE2,0xFF,0x22,0x00,0x22,0x00,
  2037.       0x22,0x00,0xF2,0x7F,0x2E,0x00,0x22,0x00,
  2038.       0x22,0x00,0xE2,0x7F,0x22,0x00,0x22,0x40,
  2039.       0x22,0x80,0xF3,0x7F,0x22,0x00,0x00,0x00,
  2040. //-- 不 --
  2041.       0x02,0x00,0x02,0x08,0x02,0x04,0x02,0x02,
  2042.       0x02,0x01,0x82,0x00,0x42,0x00,0xF2,0xFF,
  2043.       0x0E,0x00,0x42,0x00,0x82,0x00,0x02,0x01,
  2044.       0x02,0x03,0x03,0x06,0x02,0x00,0x00,0x00,
  2045. //-- 華 --
  2046.       0x00,0x04,0x40,0x04,0x20,0x04,0x10,0x04,
  2047.       0xFC,0x05,0x03,0x04,0x40,0x04,0x20,0xFF,
  2048.       0x10,0x04,0xFF,0x04,0x08,0x05,0x04,0x05,
  2049.       0x06,0x05,0xC0,0x05,0x00,0x04,0x00,0x00,
  2050. //-- , --
  2051.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x46,
  2052.       0x00,0x2F,0x00,0x1F,0x00,0x06,0x00,0x00,
  2053.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  2054.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  2055. //-- 質 --
  2056.       0x00,0x40,0x00,0x30,0xFE,0x8F,0x12,0x80,
  2057.       0x92,0x5F,0x92,0x40,0x92,0x20,0x92,0x10,
  2058.       0xFE,0x0E,0x91,0x20,0x91,0x20,0x91,0x20,
  2059.       0xD1,0x5F,0x98,0xC0,0x10,0x00,0x00,0x00,
  2060. //-- 而 --
  2061.       0x02,0x00,0xE2,0xFF,0x22,0x00,0x22,0x00,
  2062.       0x22,0x00,0xF2,0x7F,0x2E,0x00,0x22,0x00,
  2063.       0x22,0x00,0xE2,0x7F,0x22,0x00,0x22,0x40,
  2064.       0x22,0x80,0xF3,0x7F,0x22,0x00,0x00,0x00,
  2065. //-- 不 --
  2066.       0x02,0x00,0x02,0x08,0x02,0x04,0x02,0x02,
  2067.       0x02,0x01,0x82,0x00,0x42,0x00,0xF2,0xFF,
  2068.       0x0E,0x00,0x42,0x00,0x82,0x00,0x02,0x01,
  2069.       0x02,0x03,0x03,0x06,0x02,0x00,0x00,0x00,
  2070. //-- 俚 --
  2071.       0x80,0x00,0x40,0x00,0x20,0x00,0xF8,0xFF,
  2072.       0x07,0x40,0xFC,0x4B,0x24,0x49,0x24,0x49,
  2073.       0x24,0x49,0xFC,0x7F,0x24,0x49,0x24,0x49,
  2074.       0x24,0x49,0xFE,0x6B,0x04,0x40,0x00,0x00,
  2075. //-- ” --
  2076.       0x00,0x00,0x00,0x00,0x8C,0x00,0x5E,0x00,
  2077.       0x3E,0x00,0x0C,0x00,0x00,0x00,0x8C,0x00,
  2078.       0x5E,0x00,0x3E,0x00,0x0C,0x00,0x00,0x00,
  2079.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  2080. //-- 。 --
  2081.       0x00,0x00,0x00,0x38,0x00,0x7C,0x00,0x44,
  2082.       0x00,0x44,0x00,0x7C,0x00,0x38,0x00,0x00,
  2083.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  2084.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  2085.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  2086. //-- 與 --
  2087.       0x00,0x08,0x00,0x08,0x00,0x08,0xFF,0x08,
  2088.       0x88,0x08,0x88,0x08,0x88,0x08,0x88,0x08,
  2089.       0x88,0x08,0x88,0x4C,0x88,0x88,0x88,0x40,
  2090.       0xCC,0x3F,0x88,0x00,0x00,0x00,0x00,0x00,
  2091. //-- 司 --
  2092.       0x10,0x00,0x10,0x00,0x92,0x3F,0x92,0x10,
  2093.       0x92,0x10,0x92,0x10,0x92,0x10,0x92,0x10,
  2094.       0xD2,0x3F,0x9A,0x00,0x12,0x40,0x02,0x80,
  2095.       0xFF,0x7F,0x02,0x00,0x00,0x00,0x00,0x00,
  2096. //-- 馬 --
  2097.       0x00,0x08,0x00,0x08,0x02,0x08,0x02,0x08,
  2098.       0xFA,0x09,0x02,0x09,0x02,0x09,0x02,0x09,
  2099.       0x02,0x09,0x02,0x09,0xFF,0x4D,0x02,0x89,
  2100.       0x00,0x41,0x80,0x3F,0x00,0x01,0x00,0x00,
  2101. //-- 光 --
  2102.       0x40,0x00,0x40,0x80,0x42,0x40,0x44,0x20,
  2103.       0x58,0x18,0xC0,0x07,0x40,0x00,0x7F,0x00,
  2104.       0x40,0x00,0xC0,0x3F,0x50,0x40,0x48,0x40,
  2105.       0x46,0x40,0x64,0x40,0x40,0x70,0x00,0x00,
  2106. //-- 的 --
  2107.       0x00,0x00,0xF8,0x7F,0x0C,0x21,0x0B,0x21,
  2108.       0x08,0x21,0x08,0x21,0xFC,0x7F,0x28,0x00,
  2109.       0x90,0x00,0x0F,0x01,0x08,0x43,0x08,0x80,
  2110.       0x08,0x40,0xFC,0x3F,0x08,0x00,0x00,0x00,
  2111. //-- 《 --
  2112.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  2113.       0x80,0x01,0x60,0x06,0x18,0x18,0x80,0x01,
  2114.       0x60,0x06,0x18,0x18,0x00,0x00,0x00,0x00,
  2115.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  2116. //-- 資 --
  2117.       0x20,0x00,0x21,0x00,0xF6,0x80,0x10,0x9F,
  2118.       0x08,0x41,0x90,0x41,0x88,0x21,0x47,0x1D,
  2119.       0x24,0x21,0x1C,0x21,0x24,0x41,0x44,0x5F,
  2120.       0x94,0x80,0x8C,0x01,0x80,0x00,0x00,0x00,
  2121. //-- 治 --
  2122.       0x10,0x04,0x22,0x04,0x64,0xFE,0x0C,0x01,
  2123.       0x80,0x00,0x20,0x00,0x30,0xFF,0x2C,0x41,
  2124.       0x23,0x41,0x20,0x41,0x20,0x41,0x28,0x41,
  2125.       0xB0,0xFF,0x20,0x01,0x00,0x00,0x00,0x00,
  2126. //-- 通 --
  2127.       0x40,0x00,0x42,0x40,0x44,0x20,0xCC,0x1F,
  2128.       0x00,0x20,0x00,0x40,0xF1,0xBF,0x91,0x84,
  2129.       0x95,0x84,0xF9,0xBF,0x95,0x94,0x93,0xA4,
  2130.       0xF9,0x9F,0x10,0xC0,0x00,0x40,0x00,0x00,
  2131. //-- 鑒 --
  2132.       0x00,0x04,0x00,0x42,0x3E,0x42,0x00,0x49,
  2133.       0x00,0x5B,0xBF,0x6A,0x90,0x4A,0x68,0x7E,
  2134.       0x84,0x4A,0x8F,0x6A,0x14,0x5B,0x34,0x49,
  2135.       0x06,0x62,0x04,0x46,0x00,0x02,0x00,0x00,
  2136. //-- 》 --
  2137.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  2138.       0x00,0x00,0x00,0x00,0x18,0x18,0x60,0x06,
  2139.       0x80,0x01,0x18,0x18,0x60,0x06,0x80,0x01,
  2140.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  2141. //-- 并 --
  2142.       0x00,0x01,0x00,0x01,0x08,0x81,0x09,0x41,
  2143.       0x0A,0x31,0xFE,0x0F,0x08,0x01,0x08,0x01,
  2144.       0x08,0x01,0x0C,0x01,0xFA,0xFF,0x0B,0x01,
  2145.       0x08,0x01,0x88,0x01,0x00,0x01,0x00,0x00,
  2146. //-- 稱 --
  2147.       0x20,0x10,0x24,0x08,0x24,0x06,0xA4,0x01,
  2148.       0xFE,0xFF,0xA3,0x00,0x22,0x11,0x10,0x0C,
  2149.       0x1C,0x43,0x13,0x80,0xD0,0x7F,0x10,0x00,
  2150.       0x50,0x01,0x30,0x06,0x10,0x0C,0x00,0x00,
  2151. //-- “ --
  2152.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  2153.       0x00,0x00,0x00,0x00,0x60,0x00,0xF0,0x00,
  2154.       0xF8,0x00,0x68,0x00,0x04,0x00,0x60,0x00,
  2155.       0xF0,0x00,0xF8,0x00,0x68,0x00,0x04,0x00,
  2156. //-- 史 --
  2157.       0x00,0x80,0x00,0x80,0xF8,0x41,0x88,0x40,
  2158.       0x88,0x22,0x88,0x14,0x88,0x08,0xFF,0x17,
  2159.       0x88,0x10,0x88,0x20,0x88,0x20,0x88,0x40,
  2160.       0xFC,0x41,0x08,0xC0,0x00,0x40,0x00,0x00,
  2161. //-- 學 --
  2162.       0x40,0x04,0x30,0x04,0x11,0x04,0x96,0x04,
  2163.       0x90,0x04,0x90,0x44,0x91,0x84,0x96,0x7E,
  2164.       0x90,0x06,0x90,0x05,0x98,0x04,0x14,0x04,
  2165.       0x13,0x04,0x50,0x06,0x30,0x04,0x00,0x00,
  2166. //-- 雙 --
  2167.       0x04,0x40,0x34,0x30,0xC4,0x0C,0x04,0x03,
  2168.       0xC4,0x0C,0x3C,0xB0,0x00,0x80,0x04,0x40,
  2169.       0x7C,0x20,0x84,0x13,0x04,0x0C,0x04,0x1A,
  2170.       0xC4,0x61,0x3E,0xC0,0x04,0x40,0x00,0x00,
  2171. //-- 璧 --
  2172.       0x80,0x40,0x40,0x42,0xFF,0x4A,0x95,0x4A,
  2173.       0x95,0x4A,0x95,0x4A,0xF7,0x4A,0x12,0x7E,
  2174.       0x56,0x4A,0x5A,0x5A,0xF3,0x6B,0x5A,0x4A,
  2175.       0x56,0x4A,0x12,0x62,0x10,0x40,0x00,0x00,
  2176. //-- ” --
  2177.       0x00,0x00,0x00,0x00,0x8C,0x00,0x5E,0x00,
  2178.       0x3E,0x00,0x0C,0x00,0x00,0x00,0x8C,0x00,
  2179.       0x5E,0x00,0x3E,0x00,0x0C,0x00,0x00,0x00,
  2180.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  2181.       };
  2182. char tiao=3,menu=0;
  2183. int nn,n1;
  2184. int mm=0;
  2185. uchar aa=0,bb=0,cc=0,key=0,dian,miao=0,fen=0,shi=0,aj,zf=0;
  2186. void delay(uint n)
  2187. {
  2188. uchar x=0,y=0;
  2189.     for(x=n;x>0;x--)
  2190.        for(y=110;y>0;y--);
  2191. }
  2192. void fbeep()
  2193. {
  2194. beep=0;
  2195. delay(1);
  2196. beep=1;
  2197. delay(1);
  2198. beep=0;
  2199. }
  2200. void scankey()
  2201. {
  2202.
  2203.           uchar temp=0,i=0;
  2204.     P0=0xef;
  2205.     temp=P0;
  2206.     temp=temp&0x0f;
  2207.     if(temp!=0x0f)
  2208.     {
  2209.        delay(5);
  2210.        temp=P0;
  2211.        temp=temp&0x0f;
  2212.        if(temp!=0x0f)
  2213.        {
  2214.                  temp=P0;
  2215.           switch(temp)
  2216.           {
  2217. case 0xee:  key=1; break;
  2218.              case 0xed:  key=2; break;
  2219.              case 0xeb:  key=3; break;
  2220.              case 0xe7:  key=4; break;
  2221.           }
  2222.          while((temp!=0x0f)&(i<200,i++))
  2223.          {
  2224.               temp=P0;
  2225.             temp=temp&0x0f;
  2226.          }          fbeep();
  2227.        }
  2228.     }
  2229.     P0=0xdf;
  2230.     temp=P0;
  2231.     temp=temp&0x0f;
  2232.     if(temp!=0x0f)
  2233.     {
  2234.       delay(5); temp=P0;
  2235.       temp=temp&0x0f;
  2236.       if(temp!=0x0f)
  2237.      {
  2238.             temp=P0;
  2239.         switch(temp)
  2240.        {
  2241.            case 0xde: key=5; break;
  2242.            case 0xdd: key=6; break;
  2243.            case 0xdb: key=7; break;
  2244.            case 0xd7: key=8; break;
  2245.        }
  2246.     if(zf==4)
  2247. {
  2248. while(temp!=0x0f)
  2249.          {
  2250.               temp=P0;
  2251.             temp=temp&0x0f;
  2252.          }
  2253.    fbeep();
  2254.   if(key==5) menu=~menu;
  2255. //        if(menu>0)
  2256. //          {
  2257.     if((key==6)&menu) fen=fen+1;
  2258.     if((key==7)&menu) fen=fen-1;
  2259. //           }
  2260. }
  2261.       else
  2262.     {  i=0;
  2263.   while        ((temp!=0x0f)&(i<200,i++))
  2264.          {
  2265.               temp=P0;
  2266.             temp=temp&0x0f;
  2267.          }         fbeep();
  2268.         }
  2269. }
  2270.     }
  2271.     P0=0xbf; temp=P0;
  2272.     temp=temp&0x0f;
  2273.     if(temp!=0x0f)
  2274.     {
  2275.        temp=P0;
  2276.       temp=temp&0x0f;delay(5);
  2277.      if(temp!=0x0f)
  2278.      {
  2279.         temp=P0;
  2280.        switch(temp)
  2281.        {
  2282.           case 0xbe: key=9; break;
  2283.           case 0xbd: key=10; break;
  2284.           case 0xbb: key=11; break;
  2285.           case 0xb7: key=12; break;
  2286.        }          i=0;
  2287.         while((temp!=0x0f)&(i<200,i++))
  2288.          {
  2289.               temp=P0;
  2290.             temp=temp&0x0f;
  2291.          }         fbeep();
  2292.      }
  2293.     }
  2294.
  2295. }
  2296. void init()
  2297. {
  2298.
  2299.     TMOD=0X21;
  2300.     EA=1;
  2301.     ET0=1;
  2302. ET1=1;
  2303.     TR0=1;
  2304. TR1=1;
  2305.     beep=0;
  2306.     hangsck=0;
  2307.     hangrck=0;
  2308.     TH0=(65535-15535)/256;
  2309.     TL0=(65535-15535)%256;
  2310. TH1=0X38;
  2311. TL1=0X38;
  2312. }
  2313. void sendlie(uchar a)
  2314. {
  2315. uchar temp=0;
  2316.     temp=a;
  2317.     slie=temp;
  2318. }
  2319. void sendhang(uchar b,uchar d)
  2320. {
  2321. uchar i=0,temp;
  2322.            temp=b;
  2323.    for(i=8;i>0;i--)
  2324.     {
  2325. hangsi=(bit)(d&0x80);
  2326.          d<<=1; hangsck=0;delay(1);
  2327.          hangsck=1;
  2328.     }
  2329.      for(i=8;i>0;i--)
  2330.     {
  2331.         hangsi=(bit)(temp&0x80);
  2332.         temp<<=1;hangsck=0;delay(1);
  2333.         hangsck=1;
  2334.      }
  2335.     hangrck=0;
  2336.     delay(1);
  2337.      hangrck=1;
  2338. }
  2339. void sentime_fm()
  2340. {         uchar i=0;
  2341. uchar  c=0,d=0,e=0,f=0,g=0,h=0,ushi, dshi, uge, dge;
  2342. ushi=fen/10;
  2343. dshi=miao/10;
  2344. uge=fen%10;
  2345. dge=miao%10;
  2346. for(i=0;i<6;i++)
  2347. {
  2348. sendhang(time[ushi][i],time[dshi][i]);        sendlie(0x11);
  2349.     sendlie(lie[i]);
  2350. }
  2351. for(;i<12;i++)
  2352. {
  2353.
  2354. sendhang(time[uge][c++],time[dge][d++]); sendlie(0x11);
  2355. sendlie(lie[i]);
  2356. }
  2357. for(;i<16;i++)
  2358. {
  2359.
  2360. sendhang(time[10][g++],0x00);sendlie(0x11);
  2361. sendlie(lie[i]);
  2362. }
  2363. }
  2364. void sentime_sf()
  2365. {         uchar i=0;
  2366. uchar  c=0,d=0,e=0,f=0,g=0,h=0,ushi, dshi, uge, dge;
  2367. ushi=shi/10;
  2368. dshi=fen/10;
  2369. uge=shi%10;
  2370. dge=fen%10;
  2371. for(i=0;i<6;i++)
  2372. {
  2373. sendhang(time[ushi][i],time[dshi][i]);        sendlie(0x11);
  2374.     sendlie(lie[i]);
  2375. }
  2376. for(;i<12;i++)
  2377. {
  2378.
  2379. sendhang(time[uge][c++],time[dge][d++]); sendlie(0x11);
  2380. sendlie(lie[i]);
  2381. }
  2382. for(;i<16;i++)
  2383. {
  2384.    if(dian)
  2385. {
  2386.             sendhang(time[10][g++],0x00);sendlie(0x11);
  2387.         sendlie(lie[i]);
  2388. }
  2389. }
  2390. }
  2391.
  2392. void main()
  2393. {  uchar ab=0,sz=0;uint gs=0;
  2394. init();
  2395.            zf=2;
  2396.     P0=0xff;
  2397.   while(1)
  2398. {
  2399.      scankey();
  2400.      if(key==1)
  2401.    {
  2402.      TR0=0;TR1=0;
  2403. }
  2404.      if(key==2)
  2405.   {
  2406.     TR0=1;TR1=1;
  2407.   }
  2408.      if(key==3)tiao=1;
  2409.      if(key==4)tiao=2;
  2410.      if(key==5)tiao=3;
  2411.      if(key==6)tiao=4;
  2412.      if(key==7)tiao=5;
  2413.      if(key==8)zf=1;
  2414.      if(key==9)zf=2;
  2415. if(key==12)zf=4;
  2416. if(key==11)zf=3 ;
  2417. // if(key==12)IAP_CONTR=0x20;
  2418. if(key==10)zf=5;
  2419.   if(zf==1)
  2420.   { for(bb=0;bb<16;bb++)
  2421.     {
  2422.      sendhang(hang9[n1+ab++],hang9[n1+ab++]);
  2423.
  2424.   sendlie(lie[bb]);
  2425.      if(ab>=32)ab=0;
  2426.      //delay(5);
  2427.      }
  2428.            gs=sizeof(hang9)/sizeof(hang9[0]);
  2429.     if(n1>gs-32)n1=0;
  2430.    }
  2431. if(zf==2)
  2432.   { for(bb=0;bb<16;bb++)
  2433.     {
  2434.       sendhang(hang8[n1+ab++],hang8[n1+ab++]);
  2435.
  2436.    sendlie(lie[bb]);
  2437.        if(ab>=32)ab=0;
  2438.       // delay(5);
  2439.      }
  2440. gs=sizeof(hang8)/sizeof(hang8[0]);
  2441.     if(n1>gs-32)n1=0;
  2442.
  2443.    }
  2444.   if(zf==3)
  2445.   {
  2446.
  2447.           sentime_fm();
  2448.   }
  2449.   if(zf==4)
  2450.   {
  2451.            led=~led;
  2452.           sentime_sf();
  2453.   }
  2454.
  2455. }
  2456. }
  2457. void time0()interrupt 1 using 0
  2458. {
ID:157813 發表于 2016-12-26 17:01 | 只看該作者
為了打廣告我以為是服
