查看: 20633|回復(fù): 19
16×16點陣漢字橫移方法(附代碼)
ID:72243 發(fā)表于 2015-1-14 23:55 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最后由 dfyy8888 于 2015-1-18 17:35 編輯
  1. <p>//matrix.h(字模數(shù)組文件)</p><p>//使用zimoV2.2.exe取模,因為是橫向移動字幕,所以要縱向取模。</p><p>//在zimoV2.2.exe里面可以一次性取出所有字符的字模數(shù)據(jù),不用做任何修改,粘貼到數(shù)組即可使用</p><p>//可以單獨做一個頭文件,字符數(shù)不限,只要你單片機rom夠大^_^</p><p>
  2. unsigned char code matrix[]={
  3. /*--  文字:  [空字符]  --*/
  4. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  5. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  6. ////////////////////////////////////////////////////////////////////////////////
  7. /*--  文字:  《  --*/
  8. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  9. 0x00,0x00,0x00,0x00,0x01,0x02,0x04,0x09,0x12,0x24,0x48,0x90,0x20,0x40,0x00,0x00,
  10. 0x00,0x00,0x00,0x00,0x00,0x80,0x40,0x20,0x90,0x48,0x24,0x12,0x08,0x04,0x00,0x00,
  11. /*--  文字:  三  --*/
  12. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  13. 0x00,0x20,0x21,0x21,0x21,0x21,0x21,0x21,0x21,0x21,0x21,0x21,0x21,0x20,0x00,0x00,
  14. 0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x00,
  15. /*--  文字:  字  --*/
  16. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  17. 0x08,0x30,0x20,0x24,0x24,0x24,0xA4,0x64,0x25,0x26,0x24,0x20,0x20,0x28,0x30,0x00,
  18. 0x40,0x40,0x40,0x40,0x40,0x42,0x41,0xFE,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x00,
  19. /*--  文字:  經(jīng)  --*/
  20. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  21. 0x04,0x0C,0x35,0xC6,0x04,0x18,0x01,0x41,0x42,0x44,0x48,0x58,0x64,0x42,0x01,0x00,
  22. 0x44,0xE6,0x44,0x48,0x48,0x48,0x02,0x42,0x42,0x42,0x7E,0x42,0x42,0x42,0x02,0x00,
  23. /*--  文字:  》  --*/
  24. /*--  宋體12;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
  25. 0x00,0x00,0x40,0x20,0x90,0x48,0x24,0x12,0x09,0x04,0x02,0x01,0x00,0x00,0x00,0x00,
  26. 0x00,0x00,0x04,0x08,0x12,0x24,0x48,0x90,0x20,0x40,0x80,0x00,0x00,0x00,0x00,0x00,</p><p>
  27. ////////////////////////////////////////////////////////////////////////////////
  28. /*--  文字:  [空字符]  --*/
  29. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  30. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
  31. };
  32. /********************************************************************/
  33. //字幕橫向移動程序,需要改內(nèi)容時請修改matrix.h文件的字模數(shù)據(jù)即可。
  34. #include<reg51.h>
  35. #include<intrins.h>
  36. #include"matrix.h"    //字模存放頭文件
  37. sbit SDI = P3^4;
  38. sbit SCK = P3^6;
  39. sbit LCK = P3^5;
  40. void HC595_Send(unsigned char dat0,unsigned char dat1,unsigned char dat2,unsigned char dat3);
  41. main()
  42. {
  43.         unsigned char dat0, dat1, dat2, dat3, j, k, n=0;
  44.         unsigned int neg, tmp, i;
  45.         neg = 0x7FFF;
  46.         while(1)
  47.         {
  48.                 for(i=0; i<(sizeof(matrix)-31);i++)
  49.                 {
  50.                         for(k=4; k>0; k--)
  51.                         {
  52.                                 for(j=0; j<16; j++)
  53.                                 {
  54.                                         tmp = _iror_(neg,j);
  55.                                         dat0 = (unsigned char)(tmp);
  56.                                         dat1 = (unsigned char)(tmp>>8);
  57.                                         if((i+n)/16%2!=0) n+=16;
  58.                                         dat3 = (unsigned char)(*(matrix+i+n));
  59.                                         dat2 = (unsigned char)(*(matrix+i+n+16));
  60.                                         HC595_Send(dat0,dat1,dat2,dat3);
  61.                                         n++;
  62.                                 }
  63.                                 n=0;
  64.                         }
  65.                         if(i/16%2!=0) i+=16;
  66.                 }
  67.         }
  68. }
  69. //下面這個子函數(shù)如果把形參改成指針(即數(shù)組),速度會很慢,所以把四個for循環(huán)都寫出來了
  70. void HC595_Send(unsigned char dat0,unsigned char dat1,unsigned char dat2,unsigned char dat3)
  71. {
  72.         unsigned char i;
  73.         SCK = 1;
  74.         LCK = 1;
  75.         for(i=0;i<8;i++)
  76.         {
  77.                 SDI = dat0&0x01;
  78.                 dat0 >>= 1;
  79.                 SCK = 0;
  80.                 SCK = 1;
  81.         }
  82.         for(i=0;i<8;i++)
  83.         {
  84.                 SDI = dat1&0x01;
  85.                 dat1 >>= 1;
  86.                 SCK = 0;
  87.                 SCK = 1;
  88.         }
  89.         for(i=0;i<8;i++)
  90.         {
  91.                 SDI = dat2&0x01;
  92.                 dat2 >>= 1;
  93.                 SCK = 0;
  94.                 SCK = 1;
  95.         }
  96.         for(i=0;i<8;i++)
  97.         {
  98.                 SDI = dat3&0x01;
  99.                 dat3 >>= 1;
  100.                 SCK = 0;
  101.                 SCK = 1;
  102.         }
  103.         LCK = 0;
  104.         LCK = 1;
  105. }</p>
附:電路圖(采用4片74HC595,橫列各兩片,JP595短路帽短接)
參與人數(shù) 2黑幣 +55 收起 理由
zzqy + 5 很給力!
admin + 50 共享資料的積分獎勵!
收藏收藏12 分享淘帖 頂 踩
ID:72243 發(fā)表于 2015-1-14 23:57 | 只看該作者
第一次在這兒發(fā)帖,有點亂
ID:51269 發(fā)表于 2015-1-15 12:08 來自觸屏版 | 只看該作者
樓主太謙虛了,我覺得很好,圖文并茂的,而且程序的結(jié)構(gòu)很清晰。是我們學(xué)習(xí)的理想資料。有時間的話我把你的電路做成硬件來測試一下
ID:72415 發(fā)表于 2015-1-18 00:18 | 只看該作者
嗯,好東西,學(xué)校一個比賽就是做這種類似的
ID:32773 發(fā)表于 2015-2-18 22:52 | 只看該作者
學(xué)習(xí)
ID:72050 發(fā)表于 2015-4-28 17:09 | 只看該作者
這個很有用
ID:78850 發(fā)表于 2015-5-4 17:11 | 只看該作者
這個不錯,只是只有16*16的嗎?
ID:78298 發(fā)表于 2015-5-5 12:10 | 只看該作者
新人回帖賺幣。
ID:29438 發(fā)表于 2015-5-7 13:03 | 只看該作者
好東西,謝謝!
ID:78813 發(fā)表于 2015-5-9 09:35 | 只看該作者
樓主好人!
ID:82652 發(fā)表于 2015-6-10 20:14 | 只看該作者
謝謝樓主,我最近在做這樣的課設(shè)
。萬分感謝
ID:87330 發(fā)表于 2015-7-31 11:44 | 只看該作者
為什么我的顯示是亂碼?
無效樓層,該帖已經(jīng)被刪除
14#
ID:85435 發(fā)表于 2015-8-1 20:29 | 只看該作者
在學(xué)習(xí)光立方程序
ID:140435 發(fā)表于 2016-9-25 20:43 | 只看該作者
為什么會有l(wèi)ed亂跳的現(xiàn)象
ID:205447 發(fā)表于 2017-6-1 16:02 | 只看該作者
剛好課設(shè)需要,學(xué)習(xí)下,謝謝樓主
ID:211119 發(fā)表于 2017-6-17 20:05 | 只看該作者
這個有仿真程序嗎
ID:265704 發(fā)表于 2017-12-24 14:24 | 只看該作者
感謝樓主分享
ID:495804 發(fā)表于 2020-3-11 20:33 | 只看該作者
謝謝樓主分享
ID:685726 發(fā)表于 2020-3-12 00:18 | 只看該作者
挺完整的,如果能補充595的使用方法和8x8點陣如何連接成更大的點陣就好了
無效樓層,該帖已經(jīng)被刪除
22#
ID:905511 發(fā)表于 2023-12-19 23:40 | 只看該作者
沒想到快9年了,還是那么經(jīng)典
