//基于單片機串行口的電子鐘的設計
//請大家幫忙看一下,提提建議!
//我采用的是74HC595芯片。程序如下:
//基于單片機串行口的電子鐘的設計 //利用74HC595 //下面有幾個不太明白的地方,請高手指點指點!! #include <reg52.h> #include <intrins.h> #include <stdio.h>
#define uchar unsigned char #define uint unsigned int #define NOP _nop_()
sbit SDA=P1^1; sbit SHIFT=P1^2; sbit ST=P1^0; sbit P0_0=P1^3; sbit P0_1=P1^4; sbit P0_2=P1^5; sbit P0_3=P1^6; sbit P1_7=P1^7; //共陽極數碼管 uchar duan[] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf,0x0c}; uchar wei[] = {0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01,0x80};
//我想在P2口接pnp三極管,是否要改變位碼。我自己改成 {0xfe,0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd}這個口,發現P2口搞電平時就通了!
//如果我仿真的時候不接三極管,實物制作的時候加上會不會出現問題。
uchar dispbuf[]={0,0,16,0,0,16,0,0};
void key(void);
uchar i; uchar second; uchar minite; uchar hour; uchar mstcnt; uchar V=0;
void Init( ) { P1_7=0; TMOD=0x01; TH0=(65536-50000)/256; TL0=(65536-50000)%256; TR0=0; ET0=1; EA=1; SDA = 0; SHIFT = 0; ST = 0; }
void delay(uint m) { while(m--); }
void display(uchar dat) { uchar ii; uchar sdata=dat; for(ii=0;ii<8;ii++) { if(sdata&0x80) SDA=1; else SDA = 0; sdata<<=1; SHIFT =0; NOP; NOP; SHIFT = 1; NOP; NOP; } ST = 1; NOP; NOP; ST = 0; }
void main() { Init(); while(1) { delay(360); P2 = wei[8]; display(duan[11]); if(P0_0==0) { while(1) { key(); for(i=0;i<8;i++) { delay(360); P2 = wei; display(duan[dispbuf]); } } } } }
void key(void) {
dispbuf[2]=10; dispbuf[5]=10;
if(P0_0==0) { delay(50); if(P0_0==0) { V++; if(V==2) { V=0; } switch(V) { case 0:TR0=0;break; case 1:TR0=1;break; } } }
if(P0_1==0) { delay(50); if(P0_1==0) { second++; if(second==60) { second=0; } dispbuf[0]=second%10; dispbuf[1]=second/10; while(P0_1==0); } }
if(P0_2==0) { delay(100); if(P0_2==0) { minite++; if(minite==60) { minite=0; } dispbuf[3]=minite%10; dispbuf[4]=minite/10; while(P0_2==0); } } if(P0_3==0) { delay(50); if(P0_3==0) { hour++; if(hour==24) { hour=0; } dispbuf[6]=hour%10; dispbuf[7]=hour/10; while(P0_3==0); } } }
void t0(void) interrupt 1 using 0 {
TH0=(65536-50000)/256; TL0=(65536-50000)%256; mstcnt++; if(mstcnt==15) { mstcnt=0; second++;
if(second==60) { second=0; minite++;
if(minite==60) { minite=0; hour++;
if(hour==24) { hour=0; } } } dispbuf[0]=second%10; dispbuf[1]=second/10; dispbuf[3]=minite%10; dispbuf[4]=minite/10; dispbuf[6]=hour%10; dispbuf[7]=hour/10; } } |
