- /*程序名稱:at89s52實(shí)現(xiàn)時(shí)鐘
- 程序功能:用at89s52和七段數(shù)碼管實(shí)現(xiàn)計(jì)時(shí)時(shí)鐘
- 作者 :hankjulianth
- #include"reg52.h"
- #define uchar unsigned char
- #define uint unsigned int
- uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
- uint sec,min,hour;//秒,分,時(shí)計(jì)數(shù)
- uint t1;//定義計(jì)數(shù)器
- sbit sc=P3^7;//鎖存信號(hào)
- void _init_();//初始化函數(shù)
- void timer0();//定時(shí)器T0中斷函數(shù)
- void showtime();//時(shí)間顯示函數(shù)
- void settime(uint,uint,uint)
- void main()
- t1=0;
- settime(0,0,0);
- _init_();
- while(1)
- if(t1==20)
- sec++;
- t1=0;
- if(sec==60)
- min+=1;
- sec=0;
- if(min==60)
- hour+=1;
- min=0;
- if(hour==24)
- hour=0;
- showtime();
- void _init_()
- //啟用且設(shè)置T0,定時(shí)50ms
- TH0=(65536-50000)/256;
- TL0=(65536-50000)%256;
- EA=1;
- ET0=1;
- TMOD=0x01;
- TR0=1;
- void timer0() interrupt 1
- _init_();
- t1++;
- void settime(uint i,uint j,uint k)//設(shè)置初始時(shí)間函數(shù): k : j : i
- sec=i;
- min=j;
- hour=k;
- void showtime()
- //秒鐘顯示
- sc=1;
- P0=table[sec/10];
- P2=0x06;
- sc=0;
- sc=1;
- P0=table[sec%10];
- P2=0x07;
- sc=0;
- //分鐘顯示
- sc=1;
- P0=table[min/10];
- P2=0x03;
- sc=0;
- sc=1;
- P0=table[min%10];
- P2=0x04;
- sc=0;
- //時(shí)鐘顯示
- sc=1;
- P0=table[hour/10];
- P2=0x01;
- sc=0;
- sc=1;
- P0=table[hour%10];
- P2=0x0;
- sc=0;
