#include "reg52.h"
sbit dula=P2^6;
sbit wela=P2^7;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
uchar num,temp;
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
/*dula=1;
P0=0x00;
dula=0;*/
wela=1;
P0=0x00;
wela=0;
P3=0xef;
temp=P3;
temp=temp&0x0f;
while(temp!=0x0f)
delay(5);
temp=P3;
temp=temp&0x0f;
while(temp!=0x0f)
temp=P3;
switch(temp)
case 0xee:num=0; break;
case 0xed:num=1; break;
case 0xeb:num=2; break;
case 0xe7:num=3; break;
dula=1;
P0=table[num];
dula=0;
