查看: 4072|回復(fù): 1
1602液晶上面一行全部是黑色的,51單片機求助啊
ID:69768 發(fā)表于 2014-12-1 16:04 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本人想學(xué)51單片機,做了一個程序,在不加定時器和主函數(shù)的時候液晶顯示正常,雖然時間不動,但是當打開定時器時加入main函數(shù)1602液晶上面一行全部是黑色的,下面一行沒反應(yīng),具體程序有,望大蝦幫助解惑。
#include<reg52.h>
sbit RS=P2^4;
sbit RW=P2^5;
sbit EN=P2^6;
sbit s1=P3^0;
sbit s2=P3^1;
sbit s3=P3^2;
uchar count,shi,fen,miao;
uchar code shijian[]="TIME  00:00:00  ";
uchar code wendu[]="TEMP  00 C ";
void delay(uint z)
    uint x,y;
for(x=z;x>0;x--)
     for(y=110;y>0;y--);
void LCD_write_com(uchar com)
  RS=0;
  RW=0;
  EN=0;
  P0=com;
  delay(5);
  EN=1;
  delay(5);
  EN=0;
void LCD_write_date(uchar date)
  RS=1;
  RW=0;
  EN=0;
  P0=date;
  delay(5);
  EN=1;
  delay(5);
  EN=0;
void LCD_init()
    uchar num;
    EN=0;
LCD_write_com(0x38);
delay(5);
LCD_write_com(0x0c);
delay(5);
LCD_write_com(0x06);
delay(5);
LCD_write_com(0x01);
LCD_write_com(0x80);
for(num=0;num<14;num++)
     LCD_write_date(shijian[num]);
  delay(5);
LCD_write_com(0x80+0x40);
for(num=0;num<11;num++)
     LCD_write_date(wendu[num]);
  delay(5);
  TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
void LCD_write_sfm(uchar add,uchar date)
    uchar shi,ge;
shi=date/10;
ge=date%10;
    LCD_write_com(0x80+add);
LCD_write_date(0x30+shi);
LCD_write_date(0x30+ge);
LCD_init;
  if(count==20)
   count=0;
   miao++;
   if(miao==60)
    miao=0;
    fen++;
    if(fen==60)
     fen=0;
     shi++;
     if(shi==24)
      shi=0;
     LCD_write_sfm(6,shi);
    LCD_write_sfm(9,fen);
   LCD_write_sfm(12,miao);
void Timer0_isr(void) interrupt 1
count++;
ID:1 發(fā)表于 2014-12-1 17:47 | 只看該作者
看這個應(yīng)該對你有幫助http://www.raoushi.com/bbs/dpj-28753-1.html
