查看: 8571|回復: 29
基于24C02和12864顯示的電子密碼鎖設計
ID:68208 發表于 2014-11-1 09:52 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
電子密碼鎖
基于24C02和12864顯示的電子密碼鎖設計.rar
104.77 KB, 下載次數: 355, 下載積分: 黑幣 -5
收藏收藏2 分享淘帖 頂 踩
函數庫名稱:12864顯示函數
設計者: 05級新本一班  易龍明
#ifndef _12864_h_
#define _12864_h_
#include<reg51.h>
#include<absacc.h>
#include<intrins.h>
#define PORT P0
uchar code Num[]={        //32×32字節的漢字取模,一個漢字72字節
0x00,0x00,0x00,0x00,0x20,0x00,0x00,0x10,
0x00,0x00,0x18,0x00,0x08,0x76,0x00,0x88,
0xF3,0x07,0xF8,0x11,0x07,0x78,0x10,0x03,
0x08,0x13,0x01,0x0C,0x9B,0x01,0xE4,0xF9,
0x01,0xFE,0x30,0x01,0x1C,0x10,0x00,0x00,
0x00,0x00,0xF0,0xFF,0xFF,0xF0,0xFF,0xFF,
0x30,0x00,0x00,0x10,0x86,0x00,0xD0,0x85,
0x00,0xF8,0x9C,0x01,0x38,0xF8,0x01,0x10,
0xF0,0x03,0x00,0x00,0x00,0x00,0x00,0x00,//紹
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x08,0x00,0x1C,0xF8,0xFF,0x3F,0xF8,
0xFF,0x0F,0x08,0x04,0x00,0xFC,0x0F,0x00,
0x3C,0x0F,0x00,0x0C,0x08,0x00,0x00,0x00,
0x00,0x20,0x00,0x00,0xE0,0xFF,0x07,0xE0,
0xFF,0x07,0x60,0x0C,0x03,0x20,0x0C,0x01,
0x20,0x0C,0x01,0x30,0x0C,0x01,0x30,0x00,
0x01,0xF0,0xFF,0x0F,0xF0,0xFF,0x07,0x20,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//陽          72
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0C,
0x00,0x00,0x1F,0x01,0x80,0x07,0x03,0x00,
0x01,0x03,0x0C,0x01,0x01,0x9C,0x09,0x01,
0xB8,0x8C,0x01,0x80,0x8C,0x41,0x86,0x8C,
0xC0,0x9E,0xA4,0xC0,0x98,0xE4,0xFF,0x80,
0xDE,0x7F,0x60,0x8E,0x00,0x7F,0xCC,0x00,
0x4F,0xC0,0x00,0x43,0xC0,0x00,0x40,0xC3,
0x00,0xC0,0xC3,0x00,0xC0,0xC1,0x00,0x80,
0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//學           144
0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x00,
0x1C,0xF0,0xFF,0x1F,0x10,0x04,0x00,0x18,
0x04,0x00,0xFC,0x0F,0x10,0x1C,0x1E,0x10,
0x08,0x00,0x08,0xE0,0x23,0x0C,0xE0,0x30,
0x07,0x40,0xF2,0x01,0x26,0xD2,0x00,0x2E,
0x12,0x00,0x2C,0xF3,0x0F,0x28,0xFB,0x1C,
0x30,0x19,0x10,0xF0,0x18,0x10,0x70,0x08,
0x10,0x70,0x00,0x18,0x60,0x00,0x1C,0x00,
0x80,0x1F,0x00,0x00,0x08,0x00,0x00,0x00,//院           216
0x00,0x00,0x00,0x00,0x10,0x00,0x00,0x08,
0x00,0x00,0x46,0x00,0x00,0x47,0x00,0xC0,
0x45,0x00,0xF0,0x64,0x1E,0x7E,0xFE,0x1F,
0x4E,0x26,0x0C,0x60,0x32,0x06,0x60,0x32,
0x42,0x00,0x00,0x40,0x30,0x86,0x21,0x70,
0xFF,0x33,0x20,0x03,0x18,0x03,0xD9,0x0F,
0xFF,0xF9,0x03,0x06,0x09,0x04,0x20,0x01,
0x0C,0xB0,0xFF,0x1B,0x1C,0xFF,0x39,0x0C,
0x00,0x70,0x08,0x00,0x00,0x00,0x00,0x00,//鎖           288
0x00,0x00,0x00,0x00,0x08,0x00,0x00,0x08,
0x00,0x00,0x08,0x10,0x00,0x08,0x10,0x10,
0x0C,0x08,0x10,0x0C,0x0E,0x10,0x84,0x03,
0xF8,0xFF,0x01,0xF8,0x3F,0x00,0x18,0x06,
0x00,0x18,0x06,0x00,0x1C,0x06,0x00,0xFC,
0xFF,0x07,0xFC,0xFF,0xFF,0x0C,0x02,0x00,
0x0C,0x03,0x00,0x0C,0x03,0x00,0x00,0x03,
0x00,0x00,0x03,0x00,0x00,0x03,0x00,0x00,
0x03,0x00,0x00,0x02,0x00,0x00,0x00,0x00,//開           360
uchar code Tab[]={        //16×16字節的漢字取模,一個漢字32個字節
0x00,0x00,0x40,0x44,0xD8,0x00,0x40,0xBC,
0x84,0x84,0x84,0xBC,0x40,0x40,0x00,0x00,
0x00,0x00,0x00,0x00,0x1F,0x28,0x24,0x11,
0x16,0x08,0x16,0x11,0x20,0x20,0x00,0x00,//設
0x00,0x00,0x40,0x44,0xD8,0x00,0x40,0x40,
0x40,0x40,0xFC,0x40,0x60,0x40,0x00,0x00,
0x00,0x00,0x00,0x00,0x1F,0x08,0x04,0x00,
0x00,0x00,0x3F,0x00,0x00,0x00,0x00,0x00,//計  +32
0x00,0x00,0x40,0x40,0x48,0x48,0x48,0xFC,
0x48,0x68,0x50,0x48,0x64,0x40,0x00,0x00,
0x00,0x00,0x04,0x04,0x02,0x3F,0x15,0x15,
0x15,0x15,0x15,0x3F,0x00,0x00,0x00,0x00,//者  +64
0x00,0xF8,0x48,0x48,0x48,0x48,0xFF,0x48,
0x48,0x48,0x48,0xFC,0x08,0x00,0x00,0x00,
0x00,0x07,0x02,0x02,0x02,0x02,0x3F,0x42,
0x42,0x42,0x42,0x47,0x40,0x70,0x00,0x00,//電   +96
0x80,0x80,0x82,0x82,0x82,0x82,0x82,0xE2,
0xA2,0x92,0x8A,0x86,0x80,0xC0,0x80,0x00,
0x00,0x00,0x00,0x00,0x00,0x40,0x80,0x7F,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//子   +128
0x10,0x4C,0x24,0x04,0xF4,0x84,0x4D,0x56,
0x24,0x24,0x14,0x84,0x24,0x54,0x0C,0x00,
0x00,0x01,0xFD,0x41,0x40,0x41,0x41,0x7F,
0x41,0x41,0x41,0x41,0xFC,0x00,0x00,0x00,//密   +160
0x02,0x82,0xF2,0x4E,0x43,0xE2,0x42,0xFA,
0x02,0x02,0x02,0xFF,0x02,0x80,0x00,0x00,
0x01,0x00,0x7F,0x20,0x20,0x7F,0x08,0x09,
0x09,0x09,0x0D,0x49,0x81,0x7F,0x01,0x00,//碼    +192
0x80,0x40,0x70,0xCF,0x48,0x48,0x00,0xE2,
0x2C,0x20,0xBF,0x20,0x28,0xF6,0x20,0x00,
0x00,0x02,0x02,0x7F,0x22,0x92,0x80,0x4F,
0x40,0x20,0x1F,0x20,0x20,0x4F,0x80,0x00,//鎖         +224
0x20,0x22,0xEC,0x00,0x20,0x22,0xAA,0xAA,
0xAA,0xBF,0xAA,0xAA,0xEB,0xA2,0x20,0x00,
0x00,0x00,0x7F,0x20,0x10,0x00,0xFF,0x0A,
0x0A,0x0A,0x4A,0x8A,0x7F,0x00,0x00,0x00,//請          256
0x88,0x68,0x1F,0xC8,0x0C,0x28,0x90,0xA8,
0xA6,0xA1,0x26,0x28,0x10,0xB0,0x10,0x00,
0x09,0x09,0x05,0xFF,0x05,0x00,0xFF,0x0A,
0x8A,0xFF,0x00,0x1F,0x80,0xFF,0x00,0x00,//輸          288
0x00,0x00,0x00,0x00,0x00,0x01,0xE2,0x1C,
0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x80,0x40,0x20,0x10,0x0C,0x03,0x00,0x00,
0x00,0x03,0x0C,0x30,0x40,0xC0,0x40,0x00,//入          320
0x00,0x00,0x33,0x33,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//: 冒號   352
0x80,0x40,0x70,0xCF,0x48,0x48,0x48,0x48,
0x7F,0x48,0x48,0x7F,0xC8,0x68,0x40,0x00,
0x00,0x02,0x02,0x7F,0x22,0x12,0x00,0xFF,
0x49,0x49,0x49,0x49,0xFF,0x01,0x00,0x00,//錯                 384
0x40,0x42,0xC4,0x0C,0x00,0x40,0x5E,0x52,
0x52,0xD2,0x52,0x52,0x5F,0x42,0x00,0x00,
0x00,0x00,0x7F,0x20,0x12,0x82,0x42,0x22,
0x1A,0x07,0x1A,0x22,0x42,0xC3,0x42,0x00,//誤            416
0x08,0x08,0x0A,0xEA,0xAA,0xAA,0xAA,0xFE,
0xAA,0xAA,0xA9,0xF9,0x29,0x0C,0x08,0x00,
0x40,0x40,0x48,0x4B,0x4A,0x4A,0x4A,0x7F,
0x4A,0x4A,0x4A,0x4B,0x48,0x60,0x40,0x00,//重            448
0x40,0x44,0x54,0x65,0xC6,0x64,0xD6,0x44,
0x40,0xFC,0x44,0x42,0xC3,0x62,0x40,0x00,
0x20,0x11,0x49,0x81,0x7F,0x01,0x05,0x29,
0x18,0x07,0x00,0x00,0xFF,0x00,0x00,0x00,//新            480
0x40,0x42,0x44,0xCC,0x00,0x60,0x5E,0x48,
0xC8,0x7F,0xC8,0x48,0x4C,0x68,0x40,0x00,
0x00,0x40,0x20,0x1F,0x20,0x60,0x90,0x8C,
0x83,0x80,0x8F,0x90,0x90,0xD0,0x5C,0x00,//選             512
0x10,0x10,0x10,0xFF,0x90,0x50,0x82,0x46,
0x2A,0x92,0x2A,0x46,0x82,0x80,0x80,0x00,
0x02,0x42,0x81,0x7F,0x00,0x09,0x08,0x09,
0x09,0xFF,0x09,0x09,0x0C,0x09,0x00,0x00,//擇            544
0x80,0x82,0x82,0x82,0xFE,0x82,0x82,0x82,
0x82,0x82,0xFE,0x82,0x83,0xC2,0x80,0x00,
0x00,0x80,0x40,0x30,0x0F,0x00,0x00,0x00,
0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,//開            576
0x40,0x20,0xF8,0x07,0xF0,0xA0,0x90,0x4F,
0x54,0x24,0xD4,0x4C,0x84,0x80,0x80,0x00,
0x00,0x00,0xFF,0x00,0x0F,0x80,0x92,0x52,
0x49,0x25,0x24,0x12,0x08,0x00,0x00,0x00,//修            608
0x04,0xC4,0x44,0x44,0x44,0xFE,0x44,0x20,
0xDF,0x10,0x10,0x10,0xF0,0x18,0x10,0x00,
0x00,0x7F,0x20,0x20,0x10,0x90,0x80,0x40,
0x21,0x16,0x08,0x16,0x61,0xC0,0x40,0x00,//改           640
0x00,0x02,0x02,0xF2,0x92,0x92,0x92,0xFE,
0x92,0x92,0x92,0xFA,0x13,0x02,0x00,0x00,
0x04,0x04,0x04,0xFF,0x04,0x04,0x04,0x07,
0x04,0x44,0x84,0x7F,0x04,0x06,0x04,0x00,//再            672
0x00,0x02,0x04,0x8C,0x40,0x00,0x20,0x18,
0x17,0xD0,0x10,0x50,0x38,0x10,0x00,0x00,
0x02,0x02,0xFF,0x00,0x80,0x40,0x20,0x10,
0x0C,0x03,0x0C,0x10,0x60,0xC0,0x40,0x00,//次            704
0x04,0x84,0xE4,0x9C,0x84,0xC6,0x24,0xF0,
0x28,0x27,0xF4,0x2C,0x24,0xF0,0x20,0x00,
0x01,0x00,0x7F,0x20,0x20,0xBF,0x40,0x3F,
0x09,0x09,0x7F,0x09,0x89,0xFF,0x00,0x00,//確                 736
0x40,0x42,0x44,0xCC,0x00,0x00,0x00,0x00,
0xC0,0x3F,0xC0,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x3F,0x90,0x48,0x30,0x0E,
0x01,0x00,0x01,0x0E,0x30,0xC0,0x40,0x00,//認                 768
0x00,0x00,0xF8,0x88,0x88,0x88,0x88,0x08,
0x7F,0x88,0x0A,0x0C,0x08,0xC8,0x00,0x00,
0x40,0x20,0x1F,0x00,0x08,0x10,0x0F,0x40,
0x20,0x13,0x1C,0x24,0x43,0x80,0xF0,0x00,//成                 800
0x08,0x08,0x08,0xF8,0x0C,0x28,0x20,0x20,
0xFF,0x20,0x20,0x20,0x20,0xF0,0x20,0x00,
0x08,0x18,0x08,0x0F,0x84,0x44,0x20,0x1C,
0x03,0x20,0x40,0x80,0x40,0x3F,0x00,0x00,//功                 832
0x00,0x00,0x00,0x00,0x00,0x00,0x08,0xF8,
0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x3F,
0x3F,0x20,0x00,0x00,0x00,0x00,0x00,0x00,//1                        864
0x00,0x00,0x00,0x00,0x30,0x38,0x0C,0x04,
0x04,0x0C,0xF8,0xF0,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x20,0x30,0x38,0x2C,
0x26,0x23,0x21,0x38,0x00,0x00,0x00,0x00,//2                   896
0x00,0x00,0x00,0x08,0xF8,0xF8,0x80,0xE0,
0x78,0x18,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x08,0x0F,0x0F,0x00,0x03,
0x0F,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,//k        928
0x00,0x00,0x00,0x00,0x08,0xF8,0xF8,0x08,
0x00,0x00,0x00,0x00,0x08,0x0F,0x0F,0x08,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//i       960
0x00,0x00,0x00,0x08,0xF8,0xF8,0x08,0x18,
0xF0,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x08,0x0F,0x0F,0x08,0x0C,
0x07,0x03,0x00,0x00,0x00,0x00,0x00,0x00,//d       992
uchar code star[]={0x00,0x08,0x2A,0x1C,0x1C,0x2A,0x08,0x00,};//輸入密碼時顯示的符號,而不顯示真正的密碼
sbit CS1=P1^0;
sbit CS2=P1^1;
sbit RS=P1^2;
sbit RW=P1^3;
sbit E=P1^4;
sbit bflag=P0^7;
//**************************************************************************驅動函數
void Left()
CS1=0;
CS2=1;
void Right()
CS1=1;
CS2=0;
void Busy_12864()
                          do{E=0;
                             RS=0;
                             RW=1;
                                 PORT=0xff;
                                 E=1;
                                 E=0;}while(bflag);
void Wreg(uchar c)
                         Busy_12864();
                         RS=0;
                         RW=0;
                         PORT=c;
                         E=1;
                         E=0;
void Wdata(uchar c)
                         Busy_12864();
                         RS=1;
                         RW=0;
                         PORT=c;
                         E=1;
                         E=0;
void Pagefirst(uchar c)
                                  uchar i;
                                  i=c;
                                  c=i|0xb8;
                                  Busy_12864();
                                  Wreg(c);
void Linefirst(uchar c)
                                   uchar i;
                                   i=c;
                                   c=i|0x40;
                                   Busy_12864();
                                   Wreg(c);
void Ready_12864()                                 //清屏函數
   uint i,j;
   Left();
   Wreg(0x3f);
   Right();
   Wreg(0x3f);
   Left();
   for(i=0;i<8;i++)
                 Pagefirst(i);
                 Linefirst(0x00);
                 for(j=0;j<64;j++)
                  Wdata(0x00);
    Right();
    for(i=0;i<8;i++)
                 Pagefirst(i);
                 Linefirst(0x00);
                 for(j=0;j<64;j++)
                  Wdata(0x00);
void Display(uchar *s,uchar page,uchar line)                  //16×16的漢字顯示函數 ,下半排列取模
                                    uchar i,j;
                                        Pagefirst(page);
                                        Linefirst(line);
                                        for(i=0;i<16;i++)
                                        {  Wdata(*s);
                                           s++;
                                         Pagefirst(page+1);
                                        Linefirst(line);
                                        for(j=0;j<16;j++)
                                        {  Wdata(*s);
                                           s++;
void Display_32(uchar *s,uchar page,uchar line)             //24×24的漢字顯示函數,下上排列取模
   uchar i,j;
   for(i=0;i<24;i++)
      for(j=0;j<3;j++)
             Pagefirst(page+j);
                 Linefirst(line+i);
                 Wdata(*s);
                 s++;
void star_12864(uchar *s,uchar page,uchar line)                     //com=10,18,26,,.在顯示屏上寫入星號,代表密碼
   uchar i;
   Pagefirst(page);
   Linefirst(line);
   for(i=0;i<8;i++)
   {Wdata(*s);
    s++;}
void point_12864(uchar page,uchar line)                                                //在顯示屏上畫一條線
     uchar i;
     Pagefirst(page);
         Linefirst(line);
         for(i=0;i<56;i++)
            Wdata(0x1e);
void Init_12864()        //初始化,顯示實驗名稱
        Ready_12864();        //邵陽學院
        Left();
        Display_32(Num,0x00,16);
        Display_32(Num+72,0x00,40);
        point_12864(0x03,8);
        Display(Tab,0x04,16);
        Display(Tab+32,0x04,32);
        Display(Tab+64,0x04,48);
        Display(Tab+96,0x06,16);
        Display(Tab+128,0x06,32);
        Display(Tab+160,0x06,48);
        Right();
        Display_32(Num+144,0x00,0);
        Display_32(Num+216,0x00,24);
        point_12864(0x03,0);
        Display(Tab+352,0x04,0);
        Display(Tab+928,0x04,4);
        Display(Tab+960,0x04,18);
        Display(Tab+992,0x04,30);
        Display(Tab+192,0x06,0);
        Display(Tab+224,0x06,16);
void System()                                                 //在顯示屏上顯示初始字幕:請輸入密碼
   Ready_12864();
   Left();
   Display(Tab+256,0x02,16);
   Display(Tab+288,0x02,32);
   Display(Tab+320,0x02,48);
   point_12864(0x04,8);
   Right();
   Display(Tab+160,0x02,0);
   Display(Tab+192,0x02,16);
   Display(Tab+352,0x02,32);
   point_12864(0x04,0);
void error()                                   //密碼錯誤,重新輸入密碼
   Ready_12864();
   Left();
   Display(Tab+160,0x02,32);
   Display(Tab+192,0x02,48);
   Display(Tab+448,0x04,16);
   Display(Tab+480,0x04,32);
   Display(Tab+288,0x04,48);
   Right();
   Display(Tab+384,0x02,0);
   Display(Tab+416,0x02,16);
   Display(Tab+320,0x04,0);
   Display(Tab+160,0x04,16);
   Display(Tab+192,0x04,32);
void true()                                         //請選擇  1 開鎖 2 修改密碼
   Ready_12864();
   Left();
   Display(Tab+256,0x00,0);
   Display(Tab+512,0x00,16);
   Display(Tab+544,0x00,32);
   Display(Tab+352,0x00,48);
   Display(Tab+864,0x03,0);
   Display(Tab+576,0x03,16);
   Display(Tab+224,0x03,32);
   Display(Tab+896,0x06,0);
   Display(Tab+608,0x06,16);
   Display(Tab+640,0x06,32);
   Right();
void unlock()                                        //開鎖畫面
   Ready_12864();
   Left();
   Display_32(Num+288,0x03,20);
   point_12864(0x02,8);
   point_12864(0x06,8);
   Right();
   Display_32(Num+360,0x03,20);
   point_12864(0x02,0);
   point_12864(0x06,0);
void again()                                  //請再次輸入密碼
   Ready_12864();
   Left();
   Display(Tab+672,0x00,16);
   Display(Tab+704,0x00,32);
   Display(Tab+288,0x00,48);
   Right();
   Display(Tab+320,0x00,0);
   Display(Tab+160,0x00,16);
   Display(Tab+192,0x00,32);
void repeat()                                        //密碼確認錯誤,請重新修改密碼
   Ready_12864();
   Left();
   Display(Tab+160,0x02,16);
   Display(Tab+192,0x02,32);
   Display(Tab+736,0x02,48);
   Display(Tab+256,0x04,16);
   Display(Tab+448,0x04,32);
   Display(Tab+480,0x04,48);
   Right();
   Display(Tab+768,0x02,0);
   Display(Tab+384,0x02,16);
   Display(Tab+416,0x02,32);
   Display(Tab+608,0x04,0);
   Display(Tab+640,0x04,16);
   Display(Tab+160,0x04,32);
   Display(Tab+192,0x04,48);
void succeed()                                                //修改密碼成功
   Ready_12864();
   Left();
   Display(Tab+608,0x02,16);
   Display(Tab+640,0x02,32);
   Display(Tab+160,0x02,48);
   Right();
   Display(Tab+192,0x02,0);
   Display(Tab+800,0x02,16);
   Display(Tab+832,0x02,32);
#endif
ID:67678 發表于 2014-11-2 00:56 | 只看該作者
好資料啊
ID:68288 發表于 2014-11-2 22:34 | 只看該作者
很好。。。謝謝
挺給力的
ID:61200 發表于 2014-11-28 09:18 | 只看該作者
完美啊
ID:72142 發表于 2015-1-13 14:49 | 只看該作者
有不有匯編語言
ID:72128 發表于 2015-1-13 16:59 | 只看該作者
很好資料
正需要,謝謝
ID:72128 發表于 2015-1-13 17:00 | 只看該作者
很好的資料
正需要
ID:72268 發表于 2015-1-15 19:15 | 只看該作者
不錯!!!。。。。。。。。。。。。。。。。!
ID:75610 發表于 2015-4-21 12:25 | 只看該作者
謝謝分享,學習一下
ID:80736 發表于 2015-5-21 17:15 | 只看該作者
感謝分享啊
ID:80736 發表于 2015-5-21 17:42 | 只看該作者
感謝分享
ID:80736 發表于 2015-5-21 17:45 | 只看該作者
感謝分享
ID:82937 發表于 2015-6-17 21:02 | 只看該作者
大聲求教啊////
ID:82937 發表于 2015-6-17 21:03 | 只看該作者
大神求教啊////
ID:82937 發表于 2015-6-17 21:07 | 只看該作者
求抱大腿啊啊
ID:69536 發表于 2015-6-19 17:26 | 只看該作者
沒事的時候,DIY一個學習一下C51,謝謝
ID:84881 發表于 2015-7-6 11:43 | 只看該作者
來這里看看
ID:44267 發表于 2015-9-7 08:26 | 只看該作者
樓主有原理圖嘛
ID:90685 發表于 2015-9-25 07:45 來自觸屏版 | 只看該作者
黑小子哪里的我兩很有緣那。
ID:97070 發表于 2015-11-25 18:12 | 只看該作者
有仿真和程序嗎?
ID:106737 發表于 2016-3-1 11:11 | 只看該作者
有仿真和程序嗎?
ID:139963 發表于 2016-9-20 21:11 | 只看該作者
學習了
ID:192116 發表于 2017-5-11 14:33 | 只看該作者
wang215322 發表于 2015-4-21 12:25
謝謝分享,學習一下
謝謝分享
ID:57831 發表于 2017-11-30 19:25 | 只看該作者
感謝分享啊
ID:622581 發表于 2019-10-12 01:58 | 只看該作者
幫助很大呀
