查看: 2845|回復: 0
共陽代碼顯示程序
ID:67560 發表于 2014-10-18 21:47 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
unsigned char get_code(uchar i)//ACSII轉換
unsigned char p;
switch (i){
   case 0: p=0xc0;break;
   case 1: p=0xf9;break;
   case 2: p=0xa4;break;
   case 3: p=0xb0;break;
   case 4: p=0x99;break;
   case 5: p=0x92;break;
   case 6: p=0x82;break;
   case 7: p=0xf8;break;
   case 8: p=0x80;break;
   case 9: p=0x90;break;
   case 10: p=0x88;break;   //A
   case 11: p=0x83;break;   //B
   case 12: p=0xc6;break;   //C
   case 13: p=0xa1;break;   //D
   case 14: p=0x86;break;    //E
   case 15: p=0x8e;break;   //F
   default :p=0xFF;break;
    return(p);
//void  pw(unsigned char c, unsigned char d,unsigned char e)
//xss[0]=get_code(c/10);
//xss[1]=get_code(c%10);
//xss[2]=get_code(d/10);
//xss[3]=get_code(d%10);
//xss[4]=get_code(e/10);
//xss[5]=get_code(e%10);
//return;
//void send(void)
//unsigned char i;
//for(i=0;i<6;i++)
//P1=P1&scan[i];
//P2=xss[i];
//delay(200);
void dis_ply(int i)
  if (i<99)
       sdz[31]=i%100/10;//十
    sdz[32]=i%10;
    sdz[31]=sdz[32]=0xff;
    xss[0]=get_code(sdz[32]);
    xss[1]=get_code(sdz[31]);
    return;
