只需一步,快速開(kāi)始
查看: 4812|回復(fù): 0
編程和繪制原理圖完成數(shù)字電路設(shè)計(jì)
ID:262 發(fā)表于 2014-10-17 18:51 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
1.針對(duì)開(kāi)發(fā)板晶振頻率分頻1H在脈沖
Library ieee;
Use ieee.std_logic_1164.all;
Use ieee.std_logic_unsigned.all;
Entity pinlv1Hz is
Port(clk:in std_logic;
     CP:OUT std_logic);
end;
Architecture dd of pinlv1Hz is
signal q:std_logic_vector(24 downto 0);
SIGNAL C:std_logic;
begin
process(clk)
  begin
    if clk'event and clk='1' then q<=q+1;
      if q=9999999 then q<="0000000000000000000000000";C<=not C;
    end if;
end if;
end process;
CP<=C;
end;
綜合無(wú)誤后點(diǎn)file--creat/Update/Creat Symbol files for  current file生成元件符號(hào)
2.編輯60s計(jì)數(shù)器
Library ieee;
Entity court60 is
     q:out std_logic_vector(6 downto 0));
end;
Architecture dd of court60 is
signal qq:std_logic_vector(6 downto 0);
begin
process(clk)
  begin
    if clk'event and clk='1' then qq<=qq+1;
      if qq=59 then qq<="0000000";
    end if;
end if;
end process;
q<=qq;
end;
3。創(chuàng)造一個(gè)除法器宏模塊
創(chuàng)造一個(gè)除法器宏模塊完成60進(jìn)制分各位十進(jìn)制,是為6進(jìn)制
4。編輯一個(gè)6位寬和四位寬總線變兩個(gè)4單根線的程序輸出程序
Library ieee;
entity zx64 is
Port(q:in std_logic_vector(6 downto 0);
     qq:in std_logic_vector(3 downto 0);
   x0,x1,x2,x3:buffer std_logic;
     y0,y1,y2,y3:out std_logic);
end;
Architecture dd of zx64 is
begin
y0<=q(0);
y1<=q(1);
y2<=q(2);
y3<=q(3);
x0<=qq(0);
x1<=qq(1);
x2<=qq(2);
x3<=qq(3);
end;
5.便兩位分時(shí)現(xiàn)實(shí)程序
Library ieee;
Entity fenshi is
Port(clk,a0,a1,a2,a3,b0,b1,b2,b3:in std_logic;
     y0,y1,y2,y3,w0,w1:out std_logic);
end;
Architecture dd of fenshi is
signal q:std_logic_vector(7 downto 0);
begin
process(clk,a0,a1,a2,a3,b0,b1,b2,b3)
  begin
  if q<128 then
      y0<=a0;y1<=a1;y2<=a2;y3<=a3;w0<='0';w1<='1';
   y0<=b0;y1<=b1;y2<=b2;y3<=b3;w0<='1';w1<='0';
   end if;
   end if;
  end process;
end;
6。編寫(xiě)一個(gè)7段顯示碼程序顯示二進(jìn)制位10進(jìn)制
Library ieee;
entity diaplay is
Port(q0,q1,q2,q3:in std_logic;
      y6,y5,y4,y3,y2,y1,y0:out std_logic);
end;
Architecture dzb of diaplay is
signal qq:std_logic_vector(3 downto 0);
signal  Q: std_logic_vector(6 downto 0);
begin
qq<=q3&q2&q1&q0;
process(qq)
begin
   case qq is
      when "0000"=>Q<="0000001";     --段碼顯示開(kāi)發(fā)板共陽(yáng)極,所以0顯示,1不顯示。
      when "0001"=>Q<="1001111" ;
      when "0010"=>Q<="0010010" ;
      when "0011"=>Q<="0000110" ;
      when "0100"=>Q<="1001100" ;
      when "0101"=>Q<="0100100" ;
      when "0110"=>Q<="0100000" ;
      when "0111"=>Q<="0001111" ;
      when "1000"=>Q<="0000000" ;
      when "1001"=>Q<="0000100" ;
      when others=>null;
      end case;
     end process;
  y6<=q(6);y5<=q(5);y4<=q(4);y3<=q(3);y2<=q(2);y1<=q(1);y0<=q(0);
end;
綜合無(wú)誤后點(diǎn)file--creat/Update/Creat Symbol files for  current file生成元件符號(hào)。
注意:以上編寫(xiě)如果用兩位直接組合成四位二進(jìn)制計(jì)數(shù)器,則無(wú)需用除法器。其他模塊也根據(jù)個(gè)人習(xí)慣可以不同。
7.建立原理圖文件
畫(huà)圖鏈接電路,在綜合無(wú)誤后,與開(kāi)發(fā)板管腳對(duì)應(yīng)相連,再綜合無(wú)誤后即可仿真。
注意:硬件仿真時(shí),對(duì)于不用的管腳要設(shè)置成三態(tài)輸出。
