hex文件和單片機程序下載:
32個LED多花樣流水燈-源程序、hex.rar
(3.68 KB, 下載次數: 612)
2014-10-13 09:41 上傳
下載積分: 黑幣 -5
51單片機32個LED多花樣流水燈-源程序:
- #include <reg51.h>
- #include <intrins.h>
- #define ushort unsigned short //P0,P1,P2,P3數據類型是 unsigned short ;數值范圍 :0~~~~65 635
- #define uint unsigned int
- ushort code display_P0[]={ //P0 口顯示內容
- 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, //P0--》P3逐個堆積點亮部分的P0 流水點亮
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, //P0 全滅等待
- 0xFF,0xFF,0xFF,
- 0xFF,0xFF,
- 0xFF,
- 0xFF,0xFF,0xFF,
- 0xFF,0xFF,
- 0xFF,
- 0xFF,0xFF,0xFF,
- 0xFF,0xFF,
- 0xFF,
- 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, //P0--》P3逐個堆積點亮部分的P0 堆積點亮
- 0x7E,0x7D,0x7B,0x77,0x6F,0x5F,0x3F,
- 0x3E,0x3D,0x3B,0x37,0x2F,0x1F,
- 0x1E,0x1D,0x1B,0x17,0x0F,
- 0x0E,0x0D,0x0B,0x07,
- 0x06,0x05,0x03,
- 0x02,0x01,
- 0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //P0 閃爍
- 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, //P0--》P3間隔點亮部分的P0 1,3,5,7 亮。2,4,6,8滅
- 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
- 0xFE,0xFC,0xF8,0xF0,0xE0,0xC0,0x80,0x00, //P0--》P3從兩邊到中間逐個點亮部分的P0逐個點亮
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //P0--》P3從兩邊到中間逐個點亮部分的P0全亮等待
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //P0--》P3從兩邊到中間逐個熄滅部分的P0全亮等待
- 0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF, //P0--》P3從兩邊到中間逐個熄滅部分的P0逐個熄滅
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //P0 閃爍//
- 0xFE,0xFC,0xF8,0xF0,0xE0,0xC0,0x80,0x00, //P0--》P3從左到右逐個點亮部分的P0逐個點亮
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //P0--》P3從左到右逐個點亮部分的P0全亮等待
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //P0--》P3從右到左逐個熄滅部分的P0全亮等待
- 0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF, //P0--》P3從右到左逐個熄滅部分的P0逐個熄滅
- ushort code display_P1[]={
- 0xFF,0xFF,0xFF,
- 0xFF,0xFF,
- 0xFF,
- 0xFF,0xFF,0xFF,
- 0xFF,0xFF,
- 0xFF,
- 0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,
- 0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,
- 0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,
- 0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,
- 0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,
- 0x06,0x05,0x03,
- 0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,
- 0x02,0x01,
- 0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
- 0x00,
- 0x00,0x00,0x00,
- 0x00,0x00,
- 0x00,
- ushort code display_P2[]={
- 0xFF,0xFF,0xFF,
- 0xFF,0xFF,
- 0xFF,
- 0x06,0x05,0x03,
- 0x02,0x01,
- 0x00,
- 0x00,0x00,0x00,
- 0x00,0x00,
- 0x00,
- 0x00,0x00,0x00,
- 0x00,0x00,
- 0x00,
- 0x7F,0x3F,0x1F,0x0F,0x07,0x03,0x01,0x00,
- 0x01,0x03,0x07,0x0F,0x1F,0x3F,0x7F,0xFF,
- ushort code display_P3[]={
- 0x06,0x05,0x03,
- 0x02,0x01,
- 0x00,
- 0x00,0x00,0x00,
- 0x00,0x00,
- 0x00,
- 0x00,0x00,0x00,
- 0x00,0x00,
- 0x00,
- 0x00,0x00,0x00,
- 0x00,0x00,
- 0x00,
- void delayms(uint ms) //延時子程序
- ushort k;
- while(ms--)
- for(k = 0; k < 50; k++);
- void main(void) //P0---》P3 初始狀態
- ushort i;
- P0 = 0xff;
- P1 = 0xff;
- P2 = 0xff;
- P3 = 0xff;
- while(1) //定義P0,P1,P2,P3,
- for(i=0;i <946; i++)
- P0 =display_P0[i];
- P1 =display_P1[i];
- P2 =display_P2[i];
- P3 =display_P3[i];
- delayms(50);
