查看: 3404|回復(fù): 2
剛剛寫完的16*64點陣驅(qū)動,不為最佳方案,請高手指教、供初學(xué)者學(xué)習(xí)
ID:51090 發(fā)表于 2014-9-18 00:22 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg51.h>
#include<intrins.h>
sbit SERIN=P2^3;
sbit SRCK=P2^1;
sbit RCK1=P2^0;
sbit G1OUT=P2^7; //+
sbit G2OUT=P2^2; //-
sbit AOUT=P2^4;
sbit BOUT=P2^5;
sbit COUT=P2^6;
uchar code table[4][128]={
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x06,0x40,0x38,0x50,0x08,0x48,0x08,0x48,0x08,0x40,0xFF,0xFE,0x08,0x40,0x08,0x48,0x0E,0x28,0x38,0x30,0xC8,0x20,0x08,0x50,0x09,0x92,0x08,0x0A,0x28,0x06,0x10,0x02,//我
0x22,0x20,0x22,0x20,0xFF,0xA0,0x22,0x20,0x3E,0xFC,0x08,0x24,0x7F,0x24,0x49,0x24,0x49,0x24,0x7F,0x24,0x08,0x24,0xFF,0x44,0x08,0x44,0x08,0x94,0x09,0x08,0x08,0x00,//勒
0x01,0x00,0x01,0x00,0x02,0x80,0x02,0x40,0x04,0x20,0x09,0x18,0x11,0x0E,0x61,0x04,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x00,0x00,//個
0x01,0x00,0x01,0x00,0x01,0x00,0x3F,0xFC,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x7F,0xFE,0x02,0x00,0x06,0x00,0x08,0x20,0x10,0x10,0x3F,0xF8,0x10,0x10,0x00,0x00,//去
void delay1(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=10;y>0;y--);
void send(uchar byte)
  uchar i=8;
  while(i--)
    SRCK =0;
    SERIN=(byte&0x80);
    byte<<=1;
   SRCK =1;
void sendb(uchar bite)
  while(bite--)
    SRCK =0;
    SERIN=0;
   SRCK =1;
void OutPut(uchar k)
  RCK1=0;
  RCK1=1;
  RCK1=0;
  delay1(k);
void lost()
uchar i=64;
OutPut(10);
while(i--)
  SRCK =0;
  SERIN=0;
  SRCK =1;
OutPut(0);
void main(void)
uint a, b,c,d,e;
EA=1;
ET0=1;
TMOD=0x02;
TH0=56;
TR0=1;
G2OUT=0;
  for(a=0;a<32;a++)
  if(a%16==0)e=40;
    else e=4;
  while(e--)
   for(b=0;b<16;b++)
   for(c=0;c<4;c++)
   for(d=0;d<2;d++)
         send(table[c][2*b+d+a*2]);
   if(a>16)sendb(a);
   G1OUT=b/8;
   AOUT=0x01&b;
      BOUT=0x02&b;
      COUT=0x04&b;
   lost();
收藏收藏3 分享淘帖 頂 踩
ID:43559 發(fā)表于 2015-1-19 05:24 | 只看該作者
感謝分享。
ID:107781 發(fā)表于 2016-4-2 22:01 | 只看該作者
怎樣實現(xiàn)右移動?8個595如何從低到高列掃描?
