查看: 2652|回復: 0
c語言流池濾波法(瞎琢磨的,濾波效果灰常好)
ID:51090 發表于 2014-9-17 22:35 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
uint16 FlowPoolFilter(uint32 *Pool,uint16 Data,uint8 *PoolIndex,uint8 PoolSize)
(*Pool)+=Data;
if((*PoolIndex)< PoolSize )(*PoolIndex)++;
else (*Pool)-=((*Pool)/(*PoolIndex));
return (*Pool)/(*PoolIndex);
Eg: 獲取TOS  CPU的使用率
void Tos_ComputeCPURate()
static uint8 Count,i;
static uint32 Pool;
static uint8 Use;
if(_Tos_TaskTotal-1!=Tos_TaskCurrent)Use++;
Count++;
if(Count>100){Count=0;Tos_CPUInfor.Userate_CPU=FlowPoolFilter(&Pool,Use,&i,100);Use=0;}
