查看: 2435|回復: 0
字符串與數組的長度判斷函數
ID:51090 發表于 2014-9-17 14:33 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<stdio.h>
#include<string.h>
//void fit (char * zifuchuan, unsigned int size);
//void fit (char * , unsigned int size);
void fit (char * string, unsigned int size);
int main (void)
// char mesg[ ] = "I'm best, no one can shotme";
const char * mesg = "I'm best, no one can shotme";
puts(mesg);
fit (mesg, 7);
puts(mesg);
puts("Lets look at some of the string:");
puts (mesg +8);   //從第八個數字輸出
return 0;
//void fit (char * zifuchuan, unsigned intsize)  編寫程序不可以太浮躁,這個是zifuzhuan上面是zifuchuan 不一樣,絕對不可以
// if (strlen(zifuzhuan) >size)
//  *(zifuchan + size) ='\0';
if (
