查看: 2389|回復: 0
關于矩陣鍵盤的問題,求給位高手給我解答下問題所在。。
ID:64047 發表于 2014-7-24 12:02 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
做了一個矩陣鍵盤程序,要求是當按下對應的鍵時數碼管顯示對應的數值0到F,問題在按下按鍵時數碼管無反應
                   ORG 0000H
                   AJMP MAIN
                   NOP
MAIN:           LCALL KEY
                  LCALL DIS
                   AJMP MAIN
KEY:           LCALL KEYY //調掃描鍵盤
                   JNZ KEY1          //有鍵按下轉KEY1
                   LCALL DEL
                   AJMP MAIN
KEY1:           LCALL DEL  //去抖
                   LCALL KEYY //再檢測
                   JZ MAIN          //無鍵按下轉回主程序
KEY0:           JNZ KEY0          //等待釋放按鍵
                   CPL A
                   MOV R3,A
                   LCALL KEY2
KEYY:           MOV P1,#0FH
                   MOV A,P1
                   MOV 30H,A
                   MOV P1,#0F0H
                   MOV A,P1
                   MOV 31H,A
                   ANL 30H,#0FH
                   MOV A,30H
                   ANL 31H,#0F0H
                   ADD A,31H
                   CPL A
                   RET
KEY2:           CJNE R3,#0EEH,KEY3
                   MOV R2,#00H
                   AJMP DIS
KEY3:           CJNE R3,#0EDH,KEY4
                   MOV R2,#01H
                   AJMP DIS
KEY4:           CJNE R3,#0EBH,KEY5
                   MOV R2,#02H
                   AJMP DIS
KEY5:           CJNE R3,#0E7H,KEY6
                   MOV R2,#03H
                   AJMP DIS
KEY6:           CJNE R3,#0DEH,KEY7
                   MOV R2,#04H
                   AJMP DIS
KEY7:           CJNE R3,#0DEH,KEY8
                   MOV R2,#05H
                   AJMP DIS
KEY8:           CJNE R3,#0DEH,KEY9
                   MOV R2,#06H
                   AJMP DIS
KEY18:           AJMP MAIN
KEY9:           CJNE R3,#0DEH,KEY10
                   MOV R2,#07H
                   AJMP DIS
KEY10:           CJNE R3,#0DEH,KEY11
                   MOV R2,#08H
                   AJMP DIS
KEY11:           CJNE R3,#0DEH,KEY12
                   MOV R2,#09H
                   AJMP DIS
KEY12:           CJNE R3,#0DEH,KEY13
                   MOV R2,#0AH
                   AJMP DIS
KEY13:           CJNE R3,#0DEH,KEY14
                   MOV R2,#0BH
                   AJMP DIS
KEY14:           CJNE R3,#0DEH,KEY15
                   MOV R2,#0CH
                   AJMP DIS
KEY15:           CJNE R3,#0DEH,KEY16
                   MOV R2,#0DH
                   AJMP DIS
KEY16:           CJNE R3,#0DEH,KEY17
                   MOV R2,#0EH
                   AJMP DIS
KEY17:           CJNE R3,#0DEH,KEY18
                   MOV R2,#0FH
                   AJMP DIS
DIS:           MOV A,R2
                   MOV DPTR,#DUAN
                   MOVC A,@A+DPTR
           MOV P0,A
                   SETB P2.3
                   CLR P2.3
                   MOV P0,#0FEH
                   SETB P2.2
                   LCALL DEL
                   CLR P2.2
                   RET
DEL:           MOV R7,#50
DEL2:           MOV R6,#100
                   DJNZ R6,$
                   DJNZ R7,DEL2
                   RET
DUAN: DB   3Fh,06h,5Bh,4Fh,66h,6Dh,7Dh,07h,7Fh,6Fh,77h,7Ch,39h,5Eh,79h,71h
                   END
