查看: 3072|回復: 0
ds1302時鐘-AVR程序代碼
ID:51024 發表于 2014-7-12 01:58 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
學AVR時候寫的一些程序,分享一下
#include
#include "DS1302.h"
#include
void ds1302_init(void)
    PORTX=0x00;
    DDRX=0x07;
void write_ds1302_byte(unsigned char dat)
    unsigned char i;
    for(i=0;i<8;i++)
    SCK=0;
    IO_out=dat&0x01;
    dat=dat>>1;
    SCK=1;
void write_ds1302(unsigned char add,unsigned char dat)
    RST=1;
    delay_us(1);
    write_ds1302_byte(add);
    write_ds1302_byte(dat);
    RST=0;
    delay_us(2);
    IO_out=0;
    SCK=0;
unsigned char read_ds1302(unsigned char add)
    unsigned char i,value=0;
    RST=1;
    IO_setting=0;
    for(i=0;i<8;i++)
    value=value>>1;
    SCK=0;
    SCK=0; //必須給兩次。
    if(IO_in) value=value|0x80;
    SCK=1;
    IO_setting=1;
    SCK=0;
    RST=0;
    delay_us(2);
    IO_out=0;
    return value;
void set_rtc(unsigned char* time_data)
    unsigned char i,j,write_add;
    for(i=0;i<7;i++)
        j=time_data[i]/10;
        time_data[i]=time_data[i];
        time_data[i]=time_data[i]+j*16;
    write_ds1302(0x8e,0x00);//去除寫保護
    for(i=0,write_add=0x8c;i<7;i++,write_add-=2)
        write_ds1302(write_add,time_data[i]);
    write_ds1302(0x8e,0x80);
void read_rtc(unsigned char* time_data)
    unsigned char i,j,read_add;
    for(i=0,read_add=0x8d;i<7;i++,read_add-=2)
        time_data[i]=read_ds1302(read_add);
    for(i=0;i<7;i++)
        j=time_data[i]/16;
        time_data[i]%=16;
        time_data[i]+=j*10;
