查看: 7189|回復: 0
關于DELPHI ADO內存得不到釋放的問題
ID:262 發表于 2014-5-20 16:06 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
一程序使用ADO動態創建TADOQuery類,使用中發現每次open后,內存都得不到釋放,無論free,close后都都到釋放,N次運行后內存終會崩掉,上CSDN、GOOGLE中文都無法得到正解的解釋。糾結許久,終看到一老外的ADO類的源碼分析,恍然大悟。
TADOQuery = class(TCustomADODataSet)
constructor TCustomADODataSet.Create(AOwner: TComponent);
begin
inherited Create(AOwner);
FCommand := TADOCommand.Create(Self);
destructor TADOQuery.Destroy;
begin
// Problem: destroy before delete of members
inherited Destroy;
FreeAndNil(FSQL);
end;
destructor TADOCommand.Destroy;
begin
// The same problem: destroy before delete of members
inherited Destroy;
Connection := nil;
FCommandObject := nil;
FreeAndNil(FParameters);
end;
See this discussion:
groups.google.ru/groups&lr=&threadm=41ed54ce%241%40newsgroups.borland.com&rnum=6&prev=/groups%3Fas_q%3DTADOCommand%26as_ugroup%3D*borland*%26as_scoring%3Dd%26lr%3D%26num%3D20%26hl%3Dru
Possible workarounds:
- don't create TADOQuery and TADOCommand dynamically (use some static
instances), "ignore small leak" on terminating of application;
- patch adodb.pas ...
