查看: 4555|回復: 0
如何讓測速更精確,誤差變小 程序有些看不懂 求注釋
ID:58477 發表于 2014-5-13 18:09 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<AT89X52.H>
sbit led1=P2^4;
sbit led2=P2^5;
sbit led3=P2^6;
sbit led4=P2^7;
sbit key1=P1^0;
sbit key2=P1^1;
sbit key3=P1^2;
sbit key4=P1^3;
sbit key5=P1^4;
sbit key6=P1^5;
sbit zheng=P2^0;
sbit fan=P2^1;
sbit zhengled=P3^6;
sbit fanled=P3^7;
sbit zhixing=P3^5;
uchar code table[]={0xA0,0xBB,0x62,0x2A,0x39,0x2C,0x24,0xBA,
                          0x20,0x28,0x30,0x25,0xE4,0x23,0x64,0x74};
uint count=0,count1=0,time=0;
uint qian,bai,shi,ge;
uint moshi=0;
uchar pwm=75,key55=0,key66=75,xianshi=1;
unsigned long int jishu=0,shuzhi;
void delay(uint xms)  //延時函數
int a,b;
for(a=xms;a>0;a--)
  for(b=110;b>0;b--);
void initclock()      //時鐘初始化
T2MOD=0x00;
T2CON=0x04; /*定時器2為自動重裝定時工作模式)  TR2=1 */
RCAP2L=(65536-50000)%256;  //給定時器T2裝初值
RCAP2H=(65536-50000)/256;
TR2=1;    //打開定時器中斷1,2
ET2=1;
EA=1;   //開中斷
void timer_init()       //定時器一初始化
TMOD=0x15;
TH1=(65536-50000)/256;
TL1=(65536-50000)%256;
ET1=1;   //開定時器零1中斷
TR1=1;   //啟動計數器1
TH0=0X00;
TL0=0X00;
ET0=1;   //開計數器中斷
TR0=1;   //啟動計數器器0
EA=1;   //開中斷
void jisuan()         //計算時間速度距離函數
if(time==1)
   jishu=10;
   jishu=TH0*256+TL0;     //讀取計數器的值
   TH0=0X00;
   TL0=0X00;       //重裝
   time=0;
   TF2=0;
   jishu=jishu*60;
   shuzhi=jishu;
void display(uint shu)                                   //
  qian=shu/1000;
  bai=shu%1000/100;
  shi=shu%1000%100/10;
  ge=shu%1000%100%10;
   led1=0;
   P0=table[qian];
   delay(5);
   led1=1;
   led2=0;
   P0=table[bai];
   delay(5);
   led2=1;
   led3=0;
   P0=table[shi];
   delay(5);
   led3=1;
   led4=0;
   P0=table[ge];
   delay(5);
   led4=1;
void keyscan()                               //
if(key1==0)
  delay(5);
  if(key1==0)
   while(!key1);
   moshi=0;
if(key2==0)
  delay(5);
  if(key2==0)
   while(!key2);
   moshi=1;
if(key3==0)
  delay(5);
  if(key3==0)
   EA=0;
   delay(2);
   while(!key3);
   key66=key66+5;
   if(key66>=100)
    key66=100;
   pwm=key66;
   EA=1;
if(key4==0)
  delay(5);
  if(key4==0)
   while(!key4);
   EA=0;
   delay(2);
   key66=key66-5;
   if(key66<=25)
    key66=25;
   pwm=key66;
   EA=1;
if(key5==0)
  delay(5);
  if(key5==0)
   while(!key5);
   key55++;
   if(key55==1)
    timer_init();
    initclock();
    EA=1;
    delay(100);
    zhixing=0;
   if(key55==2)
    key55=0;
    zhixing=1;
    EA=0;
    zheng=0;
    fan=0;
    jishu=0;
if(key6==0)
  delay(5);
  if(key6==0)
   while(!key6);
  //  display(shuzhi);
   xianshi++;
    if(xianshi==3)
     xianshi=1;
void chuli()
uint i,j;
i=key66*20;
j=shuzhi;
if(i>j)
  pwm=pwm+1;
if(j>i)
  pwm=pwm-1;
    uint ms;
   ms++;
   if(xianshi==1)
    display(key66*20);
   if(xianshi==2)
    display(shuzhi);
   keyscan();
    jisuan();
    if(ms==15)
     ms=0;
     chuli();
void T1_time()interrupt 5     //定時器
TF2=0;
count++;
if(count==10)
  time=1;
  count=0;
void time1(void)interrupt 3         //定時器1溢出,yichu=1
TH1=(65536-1000)/256;
TL1=(65536-1000)%256;
count1++;
if(count1==156)
   count1=0;
if(moshi==0)
   zheng=0;
   zhengled=0;
   fanled=1;
   if(count1<pwm)
     fan=1;
   if(count1>=pwm)
     fan=0;
if(moshi==1)
   fan=0;
   zhengled=1;
   fanled=0;
   if(count1<pwm)
     zheng=1;
   if(count1>=pwm)
     zheng=0;
