程序如下 原本是 按key1 數(shù)字加,按key2數(shù)字減,按key3數(shù)字清零,按key4 數(shù)字每秒自動加1。。。現(xiàn)在key1、2、3都正常,按key4沒自動加1。求高手賜教。問題出在哪里呢?
#include<reg52.h>
sbit dula=P2^6;
sbit wela=P2^7;
sbit key1=P3^4;
sbit key2=P3^5;
sbit key3=P3^6;
sbit key4=P3^7;
uchar num,numt0;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
void init() //定時器0初始化程序
TMOD=0x01;
TH0=(65536-45872)/256;
TL0=(65536-45872)%256;
EA=1;
ET0=1;
TR0=1;
void delayms(uchar xms) //延時程序
uchar i,j;
for(i=xms;i>0;i--)
for(j=113;j>0;j--);
void keyscan() //鍵盤掃描程序
if(key1==0) //掃描按鍵1
delayms(10);
if(key1==0)
num++;
if(num==60)
num=0;
while(!key1);
if(key2==0) //掃描按鍵2
delayms(10);
if(key2==0)
if(num==0)
num=60;
num--;
while(!key2);
if(key3==0) //掃描按鍵3
delayms(10);
if(key3==0)
num=0;
while(!key3);
if(key4==0) //掃描按鍵4
delayms(10);
if(key4==0)
while(!key4);
TR0=!TR0;
void display(uchar laiyuan)//數(shù)碼管顯示 掃描程序
uchar shi,ge;
shi=laiyuan/10;
ge=laiyuan%10;
dula=1;
P0=table[shi];
dula=0;
P0=0xff;
wela=1;
P0=0xfe;
wela=0;
P0=0x00;
delayms(5);
dula=1;
P0=table[ge];
dula=0;
P0=0xff;
wela=1;
P0=0xfd;
wela=0;
P0=0x00;
delayms(5);
void T0_time() interrupt 1 //定時器0 中斷服務(wù)程序
numt0++;
if(numt0==20)
numt0=0;
num=num++;
if(num==60)
num=0;
void main () //主程序
num=0x00;
init();
keyscan();
display(num);
