查看: 7246|回復: 2
dspic33F系列的單片機驅動rx8025T C語言程序
ID:59583 發表于 2014-3-21 13:59 | 顯示全部樓層 |閱讀模式
#include "config.h"
#include    "p33FJ256MC710.h"
/* r8025N寄存器定義 */
#define RX8025_REG_SEC          0x00
#define RX8025_REG_MIN          0x01
#define RX8025_REG_HOUR         0x02
#define RX8025_REG_WDAY         0x03
#define RX8025_REG_MDAY         0x04
#define RX8025_REG_MONTH        0x05
#define RX8025_REG_YEAR         0x06
#define RX8025_REG_RAM          0x07//#define RX8025_REG_DIGOFF       0x07  8025
#define RX8025_REG_ALWMIN       0x08
#define RX8025_REG_ALWHOUR      0x09
#define RX8025_REG_ALWWDAY      0x0a
#define RX8025_REG_TMCNT0       0x0b//#define RX8025_REG_ALDMIN       0x0b
#define RX8025_REG_TMCNT1       0x0c//#define RX8025_REG_ALDHOUR      0x0c
/* 0x0d is reserved */
#define RX8025_REG_FLAG         0x0e//#define RX8025_REG_CTRL1        0x0e
#define RX8025_REG_CTRL         0x0f//#define RX8025_REG_CTRL2         0x0f
#define RX8025_BIT_FLAG_VDET     (1<<0)//用于檢測溫度補償的狀態
#define RX8025_BIT_FLAG_VLF      (1<<1)//用于檢測電壓低的狀態
typedef struct strtime{
        BYTE        cSecond;
        BYTE        cMinute;
        BYTE        cHour;
        BYTE        cMonth;
        BYTE        cWeek;
        BYTE        cDay;
        UINT16        sYear;
}strTIME;
BYTE rx8025_get_time(strTIME *get_time);
/* I2C定義 */
INT Time_Adjust(strTIME *dt);
BYTE is_leap_year(UINT16 year);
UINT16 bcd2bin(BYTE val);
BYTE bin2bcd(unsigned val);
VOID IdleI2C(VOID);
VOID StartI2C(VOID);
BYTE WriteI2C(BYTE byte);
VOID StopI2C(VOID);
VOID RestartI2C(VOID);
BYTE getsI2C(BYTE*, BYTE);
VOID NotAckI2C(VOID);
VOID InitI2C(VOID);
UINT16 ACKStatus(VOID);
BYTE getI2C(VOID);
VOID AckI2C(VOID);
UINT16 EEAckPolling(BYTE);
UINT16 putstringI2C(BYTE *wrptr,BYTE Write_Data_Length);
UINT32 TimeToMinute(strTIME *Time_Set);
UINT32 TimeToSecond(strTIME *Time_Set);
VOID MinuteToTime(UINT32 Minute,strTIME *T);
VOID SecondToTime(UINT32 SecondT,strTIME *T);
void TimeDir(strTIME *T);
**  Time:        liwenjin 2012.10
**  Function:讀取rx8025n內部寄存器
**  Input:
**  Output:
**  Attention
UINT16 rx8025_read_regs(BYTE Add, BYTE ReadDatatLength,BYTE *Data)
    BYTE ErrorCode;
//        Add=Add<<4;//地址(高4位)加傳送模式00(低四位)
        IdleI2C();                                                //Wait for bus Idle
        StartI2C();                                                //Generate Start condition
        WriteI2C(0x64);                        //發送寫控制命令,0x64
    ErrorCode = ACKStatus();                //Return ACK Status
        WriteI2C(Add);                                //Send High Address
        RestartI2C();                                        //Generate Restart
        WriteI2C(0x65);                                //發送讀控制命令
        getsI2C(Data,ReadDatatLength);                        //Read Length number of bytes to Data
        NotAckI2C();                                        //send Not Ack
        StopI2C();                                                //Send Stop Condition
        return(ErrorCode);
**  Function:寫rx8025n內部寄存器
**  Input:        ControlByte, Add, *wrptr.
**  Output:        None
**  Attention:先發命令地址,再發地址,最后發數據
INT rx8025_write_regs(BYTE Add,BYTE WriteDataLength,BYTE *wrptr)
        BYTE ErrorCode;
        IdleI2C();                                        //wait for bus Idle
        WriteI2C(0x64);                          //send controlbyte for a write,0x64h
        WriteI2C(Add);                        //send low address
        putstringI2C(wrptr,WriteDataLength);                //send data
        StopI2C();                                        //Generate Stop
        return(ErrorCode);
**  Function:從8025N獲取時間
**  Input:
**  Output:        None
**  Attention:
    BYTE date[7];
    BYTE err;
    err = rx8025_read_regs(RX8025_REG_SEC,7,date);
    if (!err)return err; //err為0時表示錯誤,err=1表示正常接收
    get_time->cSecond =(BYTE)bcd2bin(date[RX8025_REG_SEC]&0x7f);
    get_time->cMinute =(BYTE)bcd2bin(date[RX8025_REG_MIN]&0x7f);
    get_time->cHour = bcd2bin(date[RX8025_REG_HOUR] & 0x3f);
    get_time->cDay = bcd2bin(date[RX8025_REG_MDAY] & 0x3f);
    get_time->cMonth= bcd2bin(date[RX8025_REG_MONTH] & 0x1f);
    get_time->sYear= bcd2bin(date[RX8025_REG_YEAR]);
**  Function:校正8025N的時間
**  Input:
**  Output:        None
**  Attention:
    BYTE date[7];
    //該8025假定能被4整除是閏年,但2100年不是閏年(BUG)
    date[RX8025_REG_SEC] = bin2bcd(dt->cSecond);
    date[RX8025_REG_MIN] = bin2bcd(dt->cMinute);
    date[RX8025_REG_HOUR] = bin2bcd(dt->cHour);
//  date[RX8025_REG_WDAY] = bin2bcd(dt->cWeek);
    date[RX8025_REG_MDAY] = bin2bcd(dt->cDay);
    date[RX8025_REG_MONTH] = bin2bcd(dt->cMonth);
    date[RX8025_REG_YEAR] = bin2bcd(dt->sYear% 100);
    return rx8025_write_regs(RX8025_REG_SEC,7,date);
**  Function:BCD轉BIN
**  Input:
**  Output:        None
**  Attention:
        return ((val&0x0f)+(val >> 4)*10);
**  Function:BIN轉BCD
**  Input:
**  Output:        None
**  Attention:
        return ((val / 10) << 4) + val % 10;
**  Function:判斷是否為閏年
**  Input:
**  Output:        None
**  Attention:
        return (!(year % 4) && (year % 100)) || !(year % 400);
**  Function:初始化I2C(1)外設
**  Input:
**  Output:        None
**  Attention:Sets up Master mode, No slew rate control, 100Khz
VOID InitI2C(VOID)
    /*I2C2BRG=[(1/Fscl-PGD)*FCY]-2,當Fsc1=100khz時,1/fsc1=(1/100)*1000000=10000ns,PGD=130ns,即10000-130=9870
     I2C2BRG=(9870*5.5296)/1000-2=52.5;*/
        I2C2BRG = 0x0034;
        //初始化IIC外設,設為主模式, No Slew Rate
        I2C2CONbits.I2CEN=0;// 禁止I2Cx 模塊
    I2C2CONbits.DISSLW=1;//禁止斜率控制位
    I2C2CONbits.SCLREL=1;//釋放SCLx時鐘
        I2C2RCV = 0x0000;
        I2C2TRN = 0x0000;
        I2C2CONbits.I2CEN=1;// 使能 I2Cx 模塊,并將 SDAx 和 SCLx 引腳配置為串口引腳
**  Function:StartI2C()
**  Input:
**  Output:        None
**  Attention:        Generates an I2C Start Condition
VOID StartI2C(VOID)
        //This function generates an I2C start condition and returns status
        //of the Start.
        I2C2CONbits.SEN = 1;                //Generate Start COndition
        while (I2C2CONbits.SEN);        //Wait for Start COndition
**  Function: RestartI2C()
**  Input:
**  Output:        None
**  Attention:Generates a restart condition and optionally returns status
        I2C2CONbits.RSEN = 1;                //Generate Restart
        while (I2C2CONbits.RSEN);        //Wait for restart
**  Function: StopI2C()
**  Input:
**  Output:        None
**  Attention:Generates a bus stop condition
VOID StopI2C(VOID)
        I2C2CONbits.PEN = 1;                //Generate Stop Condition
        while (I2C2CONbits.PEN);        //Wait for Stop
**  Function: WriteI2C()
**  Input:
**  Output:        None
**  Attention:rites a byte out to the bus
        //This function transmits the byte passed to the function
        while (I2C2STATbits.TRSTAT);        //Wait for bus to be idle
        I2C2TRN = byte;                                //Load byte to I2C2 Transmit buffer
        if(I2C2STATbits.IWCOL)        /* If write collision occurs,return -1 */
        return 1;
               while (I2C2STATbits.TBF);                //wait for data transmission
    return 0;
**  Function: IdleI2C()
**  Input:
**  Output:        None
**  Attention:Waits for bus to become Idle
VOID IdleI2C(VOID)
        while (I2C2STATbits.TRSTAT);                //Wait for bus Idle
**  Function: ACKStatus()
**  Input:
**  Output:        Acknowledge Status.
**  Attention:Return the Acknowledge status on the bus
        return (!I2C2STATbits.ACKSTAT);                //Return Ack Status
**  Function: NotAckI2C()
**  Input:        None.
**  Output:        None.
**  Attention:Generates a NO Acknowledge on the Bus
        I2C2CONbits.ACKDT = 1;                        //Set for NotACk
        I2C2CONbits.ACKEN = 1;
        while(I2C2CONbits.ACKEN);                //wait for ACK to complete
        I2C2CONbits.ACKDT = 0;                        //Set for NotACk
**  Function: AckI2C()
**  Input:        None.
**  Output:        None.
**  Attention:Generates an Acknowledge.
VOID AckI2C(VOID)
        I2C2CONbits.ACKDT = 0;                        //Set for ACk
**  Function: getsI2C()
**  Input:        array poINTer, Length.
**  Output:        None.
**  Attention:read Length number of Bytes INTo array
BYTE getsI2C(BYTE *rdptr, BYTE Length)
        while (Length --)
                *rdptr++ = getI2C();                //get a single byte
                if(I2C2STATbits.BCL)                //Test for Bus collision
                        return(-1);
                if(Length)
                        AckI2C();                                //Acknowledge until all read
        return(0);
**  Function: getI2C()
**  Input:        None.
**  Output:        contents of I2C2 receive buffer.
**  Attention:Read a single byte from Bus
BYTE getI2C(VOID)
        I2C2CONbits.RCEN = 1;                        //Enable Master receive
        Nop();
        while(!I2C2STATbits.RBF);                //Wait for receive bufer to be full
        return(I2C2RCV);                                //Return data in buffer
**  Function: putstringI2C()
**  Input:        poINTer to array
**  Output:        None.
**  Attention:writes a string of data upto PAGESIZE from array
        BYTE i;
        for(i= 0; i <Write_Data_Length; i++)                //Transmit Data Until Pagesize
                if(WriteI2C(*wrptr))                        //Write 1 byte
                        return(-3);                                //Return with Write Collision
                IdleI2C();                                        //Wait for Idle bus
                if(I2C2STATbits.ACKSTAT)
                        return(-2);                                //Bus responded with Not ACK
                wrptr++;
        return(0);
//定義閏年及非閏年中每個月的天數
BYTE MonthDayNum[2][12]={{31,29,31,30,31,30,31,31,30,31,30,31},{31,28,31,30,31,30,31,31,30,31,30,31}};
**  Function:        把時間轉換為分鐘(從2000年開始的時間)
**  Input:
**  Output:
**  Attention
        BYTE c;
        UINT32        TimeMinute,i;
        Time_Set->sYear &= 0xFF;
        TimeMinute=(UINT32)525600*(UINT32)Time_Set->sYear;                        //年//525600=(60*24*365)
        c=((Time_Set->sYear-1)>>2)+1;
        TimeMinute+=(UINT32)1440*(UINT32)c;//1440=60*24
        if(Time_Set->sYear&0x03) c=1;                                        //閏年判斷
        else                                         c=0;
        if (Time_Set->cMonth==0) return 0;
        for (i=0;i<(Time_Set->cMonth-1);i++) {                        //月
                TimeMinute+=(UINT32)1440*(UINT32)MonthDayNum[c][i];////1440=60*24
        if (Time_Set->cDay==0) return 0;
        TimeMinute+=((UINT32)1440*(UINT32)(Time_Set->cDay-1) );                //日
        TimeMinute+=((UINT32)60*(UINT32)Time_Set->cHour);                                        //小時
        TimeMinute+=(UINT32)(Time_Set->cMinute);                                        //分
        return TimeMinute;
**  Function:        把時間轉換為秒(從2000年開始的時間)
**  Input:
**  Output:
**  Attention
        UINT32 TimeSecond;
        TimeSecond = TimeToMinute(Time_Set)*60;
        TimeSecond += Time_Set->cSecond;                                                //秒
        return TimeSecond;
**  Time:
**  Function:        分鐘值轉換為年月日時分秒
**  Input:
**  Output:
**  Attention
        INT iTemp1,iTemp2,i,HourT;
        T->cSecond=0;
        HourT=Minute/60;
        T->cMinute=Minute%60;
        iTemp1=HourT/(365*24);
        iTemp2=HourT%(365*24);
        T->sYear=iTemp1;
        iTemp2-=((iTemp1>>2)+1)*24;
        if(iTemp1&0x03) iTemp1=1;                                                        //閏年判斷
        else                        iTemp1=0;
        for ( i=0;i<12;i++ ) {
                if (iTemp2<MonthDayNum[iTemp1][i]*24) break;
                iTemp2-=MonthDayNum[iTemp1][i]*24;
        T->cMonth=i+1;
        T->cDay=iTemp2/24;
        T->cHour=iTemp2%24;
        T->cDay++;
**  Time:
**  Function:
**  Input:
**  Output:
**  Attention
        UINT32 iTemp1,iTemp2,i,sTemp,HourT;
        HourT=SecondT/3600;
        sTemp=SecondT%3600;
        T->cMinute=sTemp/60;
        T->cSecond=sTemp%60;
        for ( iTemp1=0;iTemp1<100;iTemp1++ ) {
                if(iTemp1&0x03) iTemp2 = 365*24;
                else iTemp2 = 366*24;
                if (HourT>=iTemp2) {
                        HourT -= iTemp2;
                else {
                        break;
        T->sYear=iTemp1;
        else                        iTemp1=0;
                if (HourT < MonthDayNum[iTemp1][i]*24) break;
                HourT -= MonthDayNum[iTemp1][i]*24;
        T->cMonth = i+1;
        T->cDay = HourT/24;
        T->cHour = HourT%24;
        T->cDay++;
        iTemp2=SecondT%(7*24*3600);
        if (iTemp2>=1) T->cWeek=iTemp2-1;
        else                   T->cWeek=6;
        BYTE buf[64];
        UINT16 len;
        len = sprintf((char *)buf,"%d年%d月%d日 %d:%d:%d\r\n",T->sYear,T->cMonth,T->cDay,T->cHour,T->cMinute,T->cSecond);
        sioapi_puts(P30f6012SER2,(BYTE*)buf,(UINT)len);
ID:62890 發表于 2014-6-12 17:18 | 顯示全部樓層
你好 請教8025讀取的時候 分鐘寄存器的地址是0x01還是0x10;
http://www.raoushi.com/bbs/dpj-24748-1.html
ID:71233 發表于 2022-11-14 13:40 | 顯示全部樓層
請問樓主有沒有RX8025T的中文數據手冊?
