查看: 14063|回復: 4
51單片機紅外接收代碼加解碼
ID:59583 發表于 2014-3-13 22:22 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
頭文件 stc12c5a.h下載: http://www.raoushi.com/mcu/2564.html
頭文件 1602.h 下載: http://www.raoushi.com/bbs/dpj-24671-1.html
  ///*redPC838.c文件
* 紅外接收數據,中斷方式,并通過串口發送
* 晶振:11.0592M*/
#include<STC12c5a.h>
#include<1602.h>
typedef unsigned char uint8;
sbit Ir_Pin = P3^3;
uint8 Ir_Buf[4]; //用于保存解碼結果
extern int keynum=1;
void int1_init(void)
IT1 = 1; //下降沿有效
EX1 = 1;
EA = 1;
TMOD = 0x01;
/*獲取低電平時間*/
unsigned int Ir_Get_Low()
TL0 = 0;
TH0 = 0;
TR0 = 1;
while (!Ir_Pin && (TH0&0x80)==0);
TR0 = 0;
return (TH0 * 256 + TL0);
/* 獲取高電平時間*/
unsigned int Ir_Get_High()
TL0 = 0;
TH0 = 0;
TR0 = 1;
while (Ir_Pin && (TH0&0x80)==0);
TR0 = 0;
void PC838()
{ int1_init();
void int1_isr() interrupt 2
unsigned int temp;
char i,j;
temp = Ir_Get_Low();
if ((temp < 7833) || (temp > 8755))  //引導脈沖低電平8500~9500us
return;
temp = Ir_Get_High();
if ((temp < 3686) || (temp > 4608))  //引導脈沖高電平4000~5000us
return;
for (i=0; i<4; i++) //4個字節
for (j=0; j<8; j++) //每個字節8位
if ((temp < 184) || (temp > 737)) //200~800us
return;
if ((temp < 184) || (temp > 1843)) //200~2000us
return;
Ir_Buf[ i] >>= 1;
if (temp > 1032) //1120us
Ir_Buf[ i] |= 0x80;
if( Ir_Buf[2]=~ Ir_Buf[3])  //驗證鍵數據碼和其反碼是否相等,一般情況下不必驗證用戶碼
if(Ir_Buf[2]==0x16)  keynum=0; //a[0]=00h;a[1]=ffh
if(Ir_Buf[2]==0x0c)  keynum=1; //a[0]=00h;a[1]=ffh
if(Ir_Buf[2]==0x18)  keynum=2; //a[0]=00h;a[1]=ffh
if(Ir_Buf[2]==0x5E)  keynum=3;
if(Ir_Buf[2]==0x08)  keynum=4;
if(Ir_Buf[2]==0x1C)  keynum=5;
if(Ir_Buf[2]==0x5A)  keynum=6;
if(Ir_Buf[2]==0x42)  keynum=7;
if(Ir_Buf[2]==0x52)  keynum=8;
if(Ir_Buf[2]==0x4A)  keynum=9;
if(Ir_Buf[2]==0x45)  keynum=10; //ON/OFF
if(Ir_Buf[2]==0x46)  keynum=11; //MODE
if(Ir_Buf[2]==0x47)  keynum=12; //靜音
if(Ir_Buf[2]==0x44)  keynum=13; //暫停
if(Ir_Buf[2]==0x40)  keynum=14; //下一曲
if(Ir_Buf[2]==0x43)  keynum=15; //上一曲
if(Ir_Buf[2]==0x07)  keynum=16; //EQ
if(Ir_Buf[2]==0x15)  keynum=17; //VOL-
if(Ir_Buf[2]==0x09)  keynum=18; //VOL+
if(Ir_Buf[2]==0x19)  keynum=19; //RPT
if(Ir_Buf[2]==0x0D)  keynum=20; //U/SD
  //  beep();        //蜂鳴器響一聲 提示解碼成功
//******************8redPC838.h文件
#ifndef _redPC838_
#define _redPC838_
#define uint  unsigned int
void PC838();
extern int keynum;
#endif
收藏收藏3 分享淘帖 頂 踩
ID:45963 發表于 2015-6-19 17:49 | 只看該作者
牛牛牛
ID:201936 發表于 2017-7-9 14:10 | 只看該作者
謝謝了,保存下來
ID:558624 發表于 2019-7-28 15:19 | 只看該作者
謝謝分享,下載了
ID:33548 發表于 2019-10-22 20:37 | 只看該作者
謝謝分享,下載了
