查看: 3540|回復: 0
stc內部RAM使用測試C語言
ID:59306 發表于 2014-2-27 15:05 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
//讀片外擴展RAM,內部R/C時鐘及ID號C語言參考程序
/* ---  STC International Limited ----------------------------------------------        */
/* ---  宏晶科技    姚永平    2009/3/19    V1.0 --------------------------------        */
/* ---  STC11Fxx/10Fxx  系列單片機,讀片外擴展RAM,軟件實現自定義下載程序---------          */
/* ---  Mobile: 13922805190 ----------------------------------------------------        */
/* ---  Fax: 0755-82944243 -----------------------------------------------------    */
/* ---  Tel: 0755-82948412 -----------------------------------------------------    */
/* ---  本演示程序在STC-ISP Ver 3.0A.PCB的下載編程工具上測試通過 ---------------        */
/* ---  如果要在程序中使用該程序,請在程序中注明使用了宏晶科技的資料及程序 -------        */
/* ---  如果要在文章中引用該程序,請在文章中注明使用了宏晶科技的資料及程序--------   */
#include<reg51.h>
#include<intrins.h>
sfr  IAP_CONTR =  0xC7;
sbit MCU_Start_Led  =  P1^7;
//unsigned char self_command_array[4] =  {0x22,0x33,0x44,0x55};
#define Self_Define_ISP_Download_Command  0x22
//#define RELOAD_COUNT  0xfb   //18.432MHz,12T,SMOD=0,9600bps
#define RELOAD_COUNT  0xfd   //11.0592MHz,12T,SMOD=0,9600bps
void serial_port_initial();
void send_UART(unsigned char);
void UART_Interrupt_Receive(void);
void soft_reset_to_ISP_Monitor(void);
void delay(void);
void display_MCU_Start_Led(void);
void main(void)
    unsigned  char i = 0;
    unsigned  char j = 0;
        unsigned  char temp_data = 0;
    unsigned  int  k = 0;
        unsigned char xdata *xdata_point;
//        unsigned char idata *idata_point;
    serial_port_initial();      //串口初始化
//    display_MCU_Start_Led();    //點亮發光二極管表示單片機開始工作
//    send_UART(0x34);            //串口發送數據表示單片機串口正常工作
//    send_UART(0xa7);            //串口發送數據表示單片機串口正常工作
//        xdata_point = 0x400;
        xdata_point = 0x0000;
//    temp_data = 0;
    temp_data = 0xff;
        for(k=0;k<32768;k++)
                *xdata_point = temp_data;
                xdata_point++;
                i = 0;
//                P0 = 0xFF;
                i = *xdata_point;
                send_UART(i);
                xdata_point++;
        for(j=0;j<255;j++)
                temp_data++;
                xdata_point++;
        xdata_point = 0x7800;
        for(j=0;j<255;j++)
                i = 0;
//                P0 = 0xFF;
                i = *xdata_point;
                send_UART(i);
                xdata_point++;
        idata_point = 0xF1;
        for(j=0;j<15;j++)
                i = *idata_point;
                send_UART(i);
                idata_point++;
    while(1);
    SCON    =   0x50;   //0101,0000 8位可變波特率,無奇偶校驗位
    TMOD    =   0x21;   //0011,0001 設置頂時器1為8位自動重裝計數器
    TH1     =   RELOAD_COUNT;   //設置定時器1自動重裝數
    TL1     =   RELOAD_COUNT;
    TR1     =   1;    //開定時器1
    ES      =   1;    //允許串口中斷
    EA      =   1;    //開總中斷
void send_UART(unsigned char i)
    ES     =   0;  //關串口中斷
    TI     =   0;  //清零串口發送完成中斷請求標志
    SBUF   =   i;
    while(TI ==0); //等待發送完成
    ES     =   1;  //允許串口中斷
void UART_Interrupt_Receive(void) interrupt 4
    unsigned char   k   =   0;
    if(RI==1)
        RI  =   0;
        k   =   SBUF;
        if(k==Self_Define_ISP_Download_Command)   //是自定義下載命令
            delay();    //延時1秒就足夠了
            delay();    //延時1秒就足夠了
            soft_reset_to_ISP_Monitor();    //軟復位到系統ISP監控區
        send_UART(k);
        TI  =  0;
    IAP_CONTR   =    0x60;   //0110,0000   軟復位到系統ISP監控區
void delay(void)
    unsigned int j  =   0;
    unsigned int g  =   0;
    for(j=0;j<5;j++)
        for(g=0;g<60000;g++)
            _nop_();
            _nop_();
            _nop_();
            _nop_();
            _nop_();
    for(i=0;i<3;i++)
        MCU_Start_Led   =   0;  //頂亮MCU開始工作指示燈
        delay();
        MCU_Start_Led   =   1;  //熄滅MCU開始工作指示燈
        delay();
