自行車(chē) 碼表 ,有電路圖 程序 仿真文件
2015-12-23 22:12 上傳
- #include "d:\c51\reg51.h"
- #include "d:\c51\intrins.h"
- sbit LCM_RS=P3^0;
- sbit LCM_RW=P3^1;
- sbit LCM_EN=P3^7;
- #define BUSY 0x80 //常量定義
- #define DATAPORT P1
- #define uchar unsigned char
- #define uint unsigned int
- #define L 50
- uchar str0[16],str1[16],count;
- uint speed;
- unsigned long time;
- void ddelay(uint);
- void lcd_wait(void);
- void display();
- void initLCM();
- void WriteCommandLCM(uchar WCLCM,uchar BusyC);
- void STR();
- void account();
- /*********延時(shí)K*1ms,12.000mhz**********/
- void int0_isr(void) interrupt 0 /*遙控使用外部中斷0,接P3.2口*/
- unsigned int temp;
- time=count;
- TR0=0;
- temp=TH0;
- temp=((temp << 8) | TL0);
- TH0=0x3c;
- TL0=0xaf;
- count=0;
- TR0=1;
- time=time*50000+temp;
- void time0_isr(void) interrupt 1 /*遙控使用定時(shí)計(jì)數(shù)器1 */
- TH0 =0x3c;
- TL0 =0xaf;
- count++;
- void main(void)
- TMOD=0x01; /*TMOD T0選用方式1(16位定時(shí)) */
- IP|=0x01; /*INT0 中斷優(yōu)先*/
- TCON|=0x11; /*TCON EX0下降沿觸發(fā),啟動(dòng)T0*/
- IE|=0x83;
- TH0=0x3c;
- TL0=0xaf;
- initLCM();
- WriteCommandLCM(0x01,1); //清顯示屏
- for(;;)
- account();
- display();
- void account()
- unsigned long a;
- if (time!=0)
- a=L*360000000/time;
- speed=a;
- void STR()
- str0[0]='S';
- str0[1]='p';
- str0[2]='e';
- str0[3]='e';
- str0[4]='d';
- str0[5]=' ';
- str0[6]=(speed%100000)/10000+0x30;
- str0[7]=(speed%10000)/1000+0x30;
- str0[8]=(speed%1000)/100+0x30;
- str0[9]='.';
- str0[10]=(speed%100)/10+0x30;
- str0[11]=speed%10+0x30;
- str0[12]='k';
- str0[13]='m';
- str0[14]='/';
- str0[15]='h';
- void ddelay(uint k)
- uint i,j;
- for(i=0;i<k;i++)
- for(j=0;j<60;j++)
- /**********寫(xiě)指令到LCD子函數(shù)************/
- if(BusyC)lcd_wait();
- DATAPORT=WCLCM;
- LCM_RS=0; /* 選中指令寄存器*/
- LCM_RW=0; // 寫(xiě)模式
- LCM_EN=1;
- _nop_();
- _nop_();
- _nop_();
- LCM_EN=0;
- /**********寫(xiě)數(shù)據(jù)到LCD子函數(shù)************/
- void WriteDataLCM(uchar WDLCM)
- lcd_wait( ); //檢測(cè)忙信號(hào)
- DATAPORT=WDLCM;
- LCM_RS=1; /* 選中數(shù)據(jù)寄存器 */
- LCM_EN=1;
- _nop_();
- _nop_();
- _nop_();
- LCM_EN=0;
- /***********lcd內(nèi)部等待函數(shù)*************/
- DATAPORT=0xff; //讀LCD前若單片機(jī)輸出低電平,而讀出LCD為高電平,則沖突,Proteus仿真會(huì)有顯示邏輯黃色
- LCM_EN=1;
- LCM_RS=0;
- LCM_RW=1;
- _nop_();
- _nop_();
- _nop_();
- while(DATAPORT&BUSY)
- { LCM_EN=0;
- _nop_();
- _nop_();
- LCM_EN=1;
- _nop_();
- _nop_();
- LCM_EN=0;
- /**********LCD初始化子函數(shù)***********/
- void initLCM( )
- DATAPORT=0;
- ddelay(15);
- WriteCommandLCM(0x38,0); //三次顯示模式設(shè)置,不檢測(cè)忙信號(hào)
- ddelay(5);
- ddelay(5);
- ddelay(5);
- WriteCommandLCM(0x38,1); //8bit數(shù)據(jù)傳送,2行顯示,5*7字型,檢測(cè)忙信號(hào)
- WriteCommandLCM(0x08,1); //關(guān)閉顯示,檢測(cè)忙信號(hào)
- WriteCommandLCM(0x01,1); //清屏,檢測(cè)忙信號(hào)
- WriteCommandLCM(0x06,1); //顯示光標(biāo)右移設(shè)置,檢測(cè)忙信號(hào)
- WriteCommandLCM(0x0c,1); //顯示屏打開(kāi),光標(biāo)不顯示,不閃爍,檢測(cè)忙信號(hào)
- /****顯示指定坐標(biāo)的一個(gè)字符子函數(shù)****/
- void DisplayOneChar(uchar X,uchar Y,uchar DData)
- Y&=1;
- X&=15;
- if(Y)X|=0x40; //若y為1(顯示第二行),地址碼+0X40
- X|=0x80; //指令碼為地址碼+0X80
- WriteCommandLCM(X,0);
- WriteDataLCM(DData);
- /*******顯示指定坐標(biāo)的一串字符子函數(shù)*****/
- void DisplayListChar(uchar X,uchar Y,uchar *DData)
- uchar ListLength=0;
- Y&=0x01;
- X&=0x0f;
- while(X<16)
- DisplayOneChar(X,Y,DData[ListLength]);
- ListLength++;
- X++;
- void display()
- STR();
- DisplayListChar(0,0,str0);
- DisplayListChar(0,1,str1);
自行車(chē)測(cè)速仿真.rar
2014-2-26 16:59 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
48.8 KB, 下載次數(shù): 187, 下載積分: 黑幣 -5
碼表
評(píng)分
查看全部評(píng)分
