#include "at89x52.h"
#include "51hei.h"
#define LCM_RW P2_7 //定義引腳
#define LCM_RS P3_5
#define LCM_E P3_4
#define LCM_Data P0
#define Busy 0x80 //用于檢測(cè)LCM狀態(tài)字中的Busy標(biāo)識(shí)
void WriteDataLCM(unsigned char WDLCM);
void WriteCommandLCM(unsigned char WCLCM,BuysC);
unsigned char ReadDataLCM(void);
unsigned char ReadStatusLCM(void);
void LCMInit(void);
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);
void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);
void Delay5Ms(void);
void Delay400Ms(void);
unsigned char code uctech[] = {" *51hei* "};
unsigned char code net[] = {" www.raoushi.com "};
void main(void)
guandz();//關(guān)閉點(diǎn)陣
guanled();//關(guān)閉led數(shù)碼管
Delay400Ms(); //啟動(dòng)等待,等LCM講入工作狀態(tài)
LCMInit(); //LCM初始化
Delay5Ms(); //延時(shí)片刻(可不要)
DisplayListChar(0, 5, uctech);
DisplayListChar(0, 0, net);
ReadDataLCM();//測(cè)試用句無(wú)意義
while(1);
//寫數(shù)據(jù)
ReadStatusLCM(); //檢測(cè)忙
LCM_Data = WDLCM;
LCM_RS = 1;
LCM_RW = 0;
LCM_E = 0; //若晶振速度太高可以在這后加小的延時(shí)
LCM_E = 0; //延時(shí)
LCM_E = 1;
//寫指令
void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC為0時(shí)忽略忙檢測(cè)
if (BuysC) ReadStatusLCM(); //根據(jù)需要檢測(cè)忙
LCM_Data = WCLCM;
LCM_RS = 0;
LCM_RW = 0;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
//讀數(shù)據(jù)
LCM_RS = 1;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
return(LCM_Data);
//讀狀態(tài)
LCM_Data = 0xFF;
LCM_RS = 0;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
while (LCM_Data & Busy); //檢測(cè)忙信號(hào)
return(LCM_Data);
void LCMInit(void) //LCM初始化
LCM_Data = 0;
WriteCommandLCM(0x38,0); //三次顯示模式設(shè)置,不檢測(cè)忙信號(hào)
Delay5Ms();
Delay5Ms();
Delay5Ms();
WriteCommandLCM(0x38,1); //顯示模式設(shè)置,開(kāi)始要求每次檢測(cè)忙信號(hào)
WriteCommandLCM(0x08,1); //關(guān)閉顯示
WriteCommandLCM(0x01,1); //顯示清屏
WriteCommandLCM(0x06,1); // 顯示光標(biāo)移動(dòng)設(shè)置
WriteCommandLCM(0x0C,1); // 顯示開(kāi)及光標(biāo)設(shè)置
//按指定位置顯示一個(gè)字符
Y &= 0x1;
X &= 0xF; //限制X不能大于15,Y不能大于1
if (Y) X |= 0x40; //當(dāng)要顯示第二行時(shí)地址碼+0x40;
X |= 0x80; // 算出指令碼
WriteCommandLCM(X, 0); //這里不檢測(cè)忙信號(hào),發(fā)送地址碼
WriteDataLCM(DData);
//按指定位置顯示一串字符
unsigned char ListLength;
ListLength = 0;
Y &= 0x1;
while (DData[ListLength]>0x19) //若到達(dá)字串尾則退出
if (X <= 0xF) //X坐標(biāo)應(yīng)小于0xF
DisplayOneChar(X, Y, DData[ListLength]); //顯示單個(gè)字符
ListLength++;
X++;
//5ms延時(shí)
void Delay5Ms(void)
unsigned int TempCyc = 5552;
while(TempCyc--);
//400ms延時(shí)
unsigned char TempCycA = 5;
unsigned int TempCycB;
while(TempCycA--)
TempCycB=7269;
while(TempCycB--);
