查看: 3|回復: 0
這是我剛做的LM016L顯示屏單片機程序
ID:1165136 發表于 2025-12-17 10:28 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
這個程序想在仿真軟件里面實現
研究了好久
原來加入一個滑動電阻改變它的背光以及控制它的D0-D7口需要加一個10K的上拉電阻
  1. #include <reg51.h>
  2. sbit LCD_RS = P2^0;
  3. sbit LCD_RW = P2^1;
  4. sbit LCD_E  = P2^2;
  5. #define LCD_DATA P0
  6. sbit KEY1 = P1^0;
  7. sbit KEY2 = P1^1;
  8. sbit KEY3 = P1^2;
  9. void DelayMs(unsigned int ms) {
  10.     unsigned int i, j;
  11.     for(i = ms; i > 0; i--)
  12.         for(j = 110; j > 0; j--);
  13. }
  14. void LCD_WriteCmd(unsigned char cmd) {
  15.     LCD_RS = 0;
  16.     LCD_RW = 0;
  17.     LCD_DATA = cmd;
  18.     DelayMs(1);
  19.     LCD_E = 1;
  20.     DelayMs(1);
  21.     LCD_E = 0;
  22.     DelayMs(1);
  23. }
  24. void LCD_WriteDat(unsigned char dat) {
  25.     LCD_RS = 1;
  26.     LCD_RW = 0;
  27.     LCD_DATA = dat;
  28.     DelayMs(1);
  29.     LCD_E = 1;
  30.     DelayMs(1);
  31.     LCD_E = 0;
  32.     DelayMs(1);
  33. }
  34. void LCD_Init() {
  35.     DelayMs(20);
  36.     LCD_WriteCmd(0x38);
  37.     DelayMs(5);
  38.     LCD_WriteCmd(0x38);
  39.     DelayMs(5);
  40.     LCD_WriteCmd(0x38);
  41.     LCD_WriteCmd(0x0C);
  42.     LCD_WriteCmd(0x06);
  43.     LCD_WriteCmd(0x01);
  44.     DelayMs(2);
  45. }
  46. void LCD_ShowStr(unsigned char x, unsigned char y, unsigned char *str) {
  47.     unsigned char addr;
  48.
  49.     if(y == 0) addr = 0x80 + x;
  50.     else       addr = 0xC0 + x;
  51.     LCD_WriteCmd(addr);
  52.
  53.     while(*str != '\0') {
  54.         LCD_WriteDat(*str);
  55.         str++;
  56.     }
  57. }
  58. unsigned char Key_Scan() {
  59.     if(KEY1 == 0) {
  60.         DelayMs(20);
  61.         if(KEY1 == 0) {
  62.             while(KEY1 == 0);
  63.             return 1;
  64.         }
  65.     }
  66.     else if(KEY2 == 0) {
  67.         DelayMs(20);
  68.         if(KEY2 == 0) {
  69.             while(KEY2 == 0);
  70.             return 2;
  71.         }
  72.     }
  73.     else if(KEY3 == 0) {
  74.         DelayMs(20);
  75.         if(KEY3 == 0) {
  76.             while(KEY3 == 0);
  77.             return 3;
  78.         }
  79.     }
  80.     return 0;
  81. }
  82. void main() {
  83.     unsigned char key_val;
  84.     LCD_Init();
  85.     LCD_ShowStr(0,0,"請選擇速度:");
  86.
  87.     while(1) {
  88.         key_val = Key_Scan();
  89.         if(key_val != 0) {
  90.             LCD_WriteCmd(0x01);
  91.             switch(key_val) {
  92.                 case 1:
  93.                     LCD_ShowStr(0,0,"Speed: Low");
  94.                     break;
  95.                 case 2:
  96.                     LCD_ShowStr(0,0,"Speed: Mid");
  97.                     break;
  98.                 case 3:
  99.                     LCD_ShowStr(0,0,"Speed: High");
  100.                     break;
  101.                 default:
  102.                     break;
  103.             }
  104.         }
  105.     }
  106. }
