查看: 1012|回復: 2
ATMEGA8單片機+SI5351雙通道高頻信號發生器
ID:1136941 發表于 2025-1-13 15:54 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
我是個無線電愛好者,平時喜歡DIY高頻電路,由于高端的信號發生器價格太高,就制作了這個裝置。SI5351是3通道輸出的方波PLL信號發生器,驅動是移植后略加修改的,原驅動是一個通道輸出,水平所限不能實現3個通道輸出。兩個通道頻率可以分別調節,頻率范圍500KHZ-120MHZ.以下是源程序:
ATMEGA-8L單片機
內部RC時鐘8MHZ
#include "mega16.h"
#include "i2c.h"
#include "delay.h"
#asm
  .equ __i2c_port=0x12 //D端口地址0x12
  .equ __sda_bit=6 //6腳
  .equ __scl_bit=7 //7腳
#endasm
#define uint8_t unsigned char
#define uint16_t unsigned int
#define uint32_t  signed long int
#define SI_CLK0_CONTROL    16
#define SI_CLK1_CONTROL    17
#define SI_CLK2_CONTROL    18
#define SI_SYNTH_PLL_A    26
#define SI_SYNTH_PLL_B    34
#define SI_SYNTH_MS_0        42
#define SI_SYNTH_MS_1        50
#define SI_SYNTH_MS_2        58
#define SI_PLL_RESET        177
#define SI_R_DIV_1 0x00
#define SI_R_DIV_2 0x16
#define SI_R_DIV_4 0x20
#define SI_R_DIV_8 0x30
#define SI_R_DIV_16 0x40
#define SI_R_DIV_32 0x50
#define SI_R_DIV_64 0x60
#define SI_R_DIV_128 0x70
#define SI_CLK_SRC_PLL_A 0x00
#define SI_CLK_SRC_PLL_B 0x20
#define XTAL_FREQ    25000000 // 晶體頻率
#define I2C_START 0x08
#define I2C_START_RPT 0x10
#define I2C_SLA_W_ACK 0x18
#define I2C_SLA_R_ACK 0x40
#define I2C_DATA_ACK 0x28
#define I2C_WRITE 0xc0
#define I2C_READ  0xc1
unsigned char Table[]="0123456789";
unsigned char Data[9];
/**********1602**************/
#define RS_1 PORTC.2=1
#define RS_0 PORTC.2=0
#define EN_1 PORTC.0=1
#define EN_0 PORTC.0=0
#define LCD_D4_1 PORTB.4=1
#define LCD_D4_0 PORTB.4=0
#define LCD_D5_1 PORTB.3=1
#define LCD_D5_0 PORTB.3=0
#define LCD_D6_1 PORTB.2=1
#define LCD_D6_0 PORTB.2=0
#define LCD_D7_1 PORTB.1=1
#define LCD_D7_0 PORTB.1=0
//////////函數聲明//////////////////////////////////
void i2cSendRegister(uint8_t reg,uint8_t data);
void setupPLL(uint8_t pll, uint8_t mult, uint32_t num, uint32_t denom);
void setupMultisynth(uint8_t synth, uint32_t divider, uint8_t rDiv);
//void si5351aOutputOff(uint8_t clk);
void si5351aSetFrequency(uint8_t td,uint32_t frequency);
void LCD_en_write(void);//液晶使能
void LCD_by(uchar abc);//寫字節
void LCD_set_xy(uchar x, uchar y);//寫地址
void LCD_write_str(uchar X,uchar Y,uchar *s);//寫字符串
void LCD_init(void);//液晶初始化
void delay_nus(uint n);
void del_ms(uint n);
void delay_us(unsigned  int n);
void process_8(unsigned long i,unsigned char *p);
void display_8(unsigned char x, unsigned char y, unsigned char *p);
/*8位數預處理函數*/
  p[0]=i/100000000%10;
  p[1]=i/10000000%10;
  p[2]=i/1000000%10;
  p[3]=i/100000%10;
  p[4]=i/10000%10;
  p[5]=i/1000%10;
  p[6]=i/100%10;
  p[7]=i/10%10;
  p[8]=i%10;
/*8位數顯示函數*/
  unsigned char i;
  LCD_set_xy( x, y );
  RS_1;            //RS=1,寫顯示內容
  for(i=0;i<9;i++)//8
    if(i==3)
        LCD_write_str(3,0,".");
    if(i==6)
        LCD_write_str(7,0,".");
        LCD_by(Table[p[ i]]);
     delay_us(5);
     EN_1;
     delay_us(5);
     EN_0;
void LCD_by(uchar abc)//寫字節
    delay_nus(500);//500
    if(((abc<<0)&0x80)==0)
     LCD_D7_0;
     else LCD_D7_1;
    if(((abc<<1)&0x80)==0)
     LCD_D6_0;
     else LCD_D6_1;
    if(((abc<<2)&0x80)==0)
     LCD_D5_0;
     else LCD_D5_1;
    if(((abc<<3)&0x80)==0)
     LCD_D4_0;
     else LCD_D4_1;
    LCD_en_write();
    if(((abc<<4)&0x80)==0)
     LCD_D7_0;
     else LCD_D7_1;
    if(((abc<<5)&0x80)==0)
     LCD_D6_0;
     else LCD_D6_1;
    if(((abc<<6)&0x80)==0)
     LCD_D5_0;
     else LCD_D5_1;
    if(((abc<<7)&0x80)==0)
     LCD_D4_0;
     else LCD_D4_1;
    LCD_en_write();
void LCD_set_xy( uchar x, uchar y )//寫地址函數
    uchar address;
    if (y == 0) address = 0x80 + x;
    address = 0xc0 + x;
    RS_0;           //RS=0,寫命令
    LCD_by(address);
void LCD_write_str(uchar X,uchar Y,uchar *s)//寫字符串
    LCD_set_xy(X,Y);
    RS_1;
    while(*s)
       LCD_by(*s);
       s++;
void LCD_init(void)     //液晶初始化
    RS_0;            //寫命令
    del_ms(500);
    LCD_by(0x30);
    del_ms(60);
    LCD_by(0x30);
    del_ms(10);
    LCD_by(0x30);
    del_ms(10);
    LCD_by(0x02);
    del_ms(10);
    LCD_by(0x28);         //4bit test顯示模式設置(不檢測忙信號)
    del_ms(10);
    LCD_by(0x08);         // 顯示關閉
    del_ms(10);
    LCD_by(0x01);         // 顯示清屏
    del_ms(10);
    LCD_by(0x06);         // 顯示光標移動
    del_ms(10);
    LCD_by(0x0C);         // 顯示開及光標設置
    del_ms(100);
void delay_nus(uint n)       //N us延時函數
   uint i=0;
   for (i=0;i<n;i++){;}
void del_ms(uint n)//ms延時函數
{ uchar j;
  while(n--)
  {for(j=0;j<125;j++);}
   if(n==0)
   return ;
   while (--n);
//---------Si5351----------------
    i2c_start();//啟動
    i2c_write(0xc0);//5351地址I2C_WRITE 0b11000000
    i2c_write(reg);//存儲地址
    i2c_write(data);//一字節數據
    i2c_stop();//停止
    delay_ms(2);
    uint32_t P1;                    // PLL config register P1
    uint32_t P2;                    // PLL config register P2
    uint32_t P3;                    // PLL config register P3
    P1 = (uint32_t)(128 * ((float)num / (float)denom));
    P1 = (uint32_t)(128 * (uint32_t)(mult) + P1 - 512);
    P2 = (uint32_t)(128 * ((float)num / (float)denom));
    P2 = (uint32_t)(128 * num - denom * P2);
    P3 = denom;
    i2cSendRegister(pll + 0, (P3 & 0x0000FF00) >> 8);
    i2cSendRegister(pll + 1, (P3 & 0x000000FF));
    i2cSendRegister(pll + 2, (P1 & 0x00030000) >> 16);
    i2cSendRegister(pll + 3, (P1 & 0x0000FF00) >> 8);
    i2cSendRegister(pll + 4, (P1 & 0x000000FF));
    i2cSendRegister(pll + 5, ((P3 & 0x000F0000) >> 12) | ((P2 & 0x000F0000) >> 16));
    i2cSendRegister(pll + 6, (P2 & 0x0000FF00) >> 8);
    i2cSendRegister(pll + 7, (P2 & 0x000000FF));
    uint32_t P1;                    // Synth config register P1
    uint32_t P2;                    // Synth config register P2
    uint32_t P3;                    // Synth config register P3
    P1 = 128 * divider - 512;
    P2 = 0;
    P3 = 1;
    i2cSendRegister(synth + 0,   (P3 & 0x0000FF00) >> 8);
    i2cSendRegister(synth + 1,   (P3 & 0x000000FF));
    i2cSendRegister(synth + 2,   ((P1 & 0x00030000) >> 16) | rDiv);
    i2cSendRegister(synth + 3,   (P1 & 0x0000FF00) >> 8);
    i2cSendRegister(synth + 4,   (P1 & 0x000000FF));
    i2cSendRegister(synth + 5,   ((P3 & 0x000F0000) >> 12) | ((P2 & 0x000F0000) >> 16));
    i2cSendRegister(synth + 6,   (P2 & 0x0000FF00) >> 8);
    i2cSendRegister(synth + 7,   (P2 & 0x000000FF));
/* void si5351aOutputOff(uint8_t clk)
    i2cSendRegister(clk, 0x80);
    uint32_t pllFreq;
    uint32_t xtalFreq = XTAL_FREQ;
    uint32_t l;
    float f;
    uint8_t mult;
    uint32_t num;
    uint32_t denom;
    uint32_t divider;
    uint8_t x;
    uint8_t y;
    uint8_t z;
    if(td==1)//1通道
        x=SI_SYNTH_MS_1;
        y=SI_CLK1_CONTROL;
        z=SI_CLK_SRC_PLL_B;
    if(td==2)//2通道
        x=SI_SYNTH_MS_2;
        y=SI_CLK2_CONTROL;
        z=SI_CLK_SRC_PLL_A;
    divider = 900000000 / frequency;
    if (divider % 2) divider--;
    pllFreq = divider * frequency;
    mult = pllFreq / xtalFreq;
    l = pllFreq % xtalFreq;
    f = l;
    f *= 1048575;
    f /= xtalFreq;
    num = f;
    denom = 1048575;
    if(td==1)//1通道
        setupPLL(SI_SYNTH_PLL_B, mult, num, denom);
    if(td==2)//2通道
        setupPLL(SI_SYNTH_PLL_A, mult, num, denom);
    setupMultisynth(x, divider, SI_R_DIV_1);
    i2cSendRegister(SI_PLL_RESET, 0xA0);
    i2cSendRegister(y, 0x4F | z);
void main(void)
    signed long int bj_1=500000;
    signed long int bj_2=500000;
    uchar IC=1;
    uchar ID=1;
    bit ww=1;
    bit ee=1;
    DDRB=0XFF;
    PORTB=0X00;
    DDRC=0XFF;
    PORTC=0X00;
    DDRD=0XC0;
    PORTD=0XFF;
    del_ms(100);
    i2c_init();
    del_ms(100);
    LCD_init();
    del_ms(100);
    LCD_write_str(13,0,"MHz");
    LCD_write_str(0,1,"Bj=");
    del_ms(100);
        if(ee==1)
            si5351aSetFrequency(1,bj_1);
            si5351aSetFrequency(2,bj_2);
            ee=0;
        if(PIND.2==0)//頻率加
            del_ms(2);
            if(PIND.2==0)
                while(!PIND.2);
                   if(ID==1)
                       if(IC==1){bj_1=bj_1+10;}
                       if(IC==2){bj_1=bj_1+100;}
                       if(IC==3){bj_1=bj_1+1000;}
                       if(IC==4){bj_1=bj_1+10000;}
                       if(IC==5){bj_1=bj_1+100000;}
                       if(IC==6){bj_1=bj_1+1000000;}
                       if(IC==7){bj_1=bj_1+10000000;}
                       if(bj_1>120000000)
                           bj_1=120000000;
                       process_8(bj_1,Data);
                       display_8(0,0,Data);
                    if(ID==2)
                        if(IC==1){bj_2=bj_2+10;}
                        if(IC==2){bj_2=bj_2+100;}
                        if(IC==3){bj_2=bj_2+1000;}
                        if(IC==4){bj_2=bj_2+10000;}
                        if(IC==5){bj_2=bj_2+100000;}
                        if(IC==6){bj_2=bj_2+1000000;}
                        if(IC==7){bj_2=bj_2+10000000;}
                        if(bj_2>120000000)
                            bj_2=120000000;
                        process_8(bj_2,Data);
                  ww=1;
        if(PIND.3==0)//頻率減
            del_ms(2);
            if(PIND.3==0)
                while(!PIND.3);
                if(ID==1)
                  if(IC==1){bj_1=bj_1-10;}
                  if(IC==2){bj_1=bj_1-100;}
                  if(IC==3){bj_1=bj_1-1000;}
                  if(IC==4){bj_1=bj_1-10000;}
                  if(IC==5){bj_1=bj_1-100000;}
                  if(IC==6){bj_1=bj_1-1000000;}
                  if(IC==7){bj_1=bj_1-10000000;}
                  if(bj_1<500000)
                      bj_1=500000;
                if(ID==2)
                  if(IC==1){bj_2=bj_2-10;}
                  if(IC==2){bj_2=bj_2-100;}
                  if(IC==3){bj_2=bj_2-1000;}
                  if(IC==4){bj_2=bj_2-10000;}
                  if(IC==5){bj_2=bj_2-100000;}
                  if(IC==6){bj_2=bj_2-1000000;}
                  if(IC==7){bj_2=bj_2-10000000;}
                  if(bj_2<500000)
                      bj_2=500000;
                  ww=1;
        if(PIND.4==0)//通道按下
          del_ms(20);
          if(Td==0)
              while(!Td);
              ID++;
              if(ID>2)
                  ID=1;
                ww=1;
        switch(ID)
            case 1:
            if(ww==1)
                LCD_write_str(14,1,"1");
                ww=0;
            break;
            case 2:
            if(ww==1)
                LCD_write_str(14,1,"2");
                ww=0;
            break;
        if(PIND.0==0)//步進按下
          del_ms(20);
          if(PIND.0==0)
              while(!PIND.0);
              IC++;
              if(IC>7)
                  IC=1;
                ww=1;
       switch(IC)
            case 1://10HZ
            LCD_write_str(3,1,"10Hz  ");//
            break;
            case 2://100HZ
            LCD_write_str(3,1,"100Hz ");//
            break;
            case 3://1KHZ
            LCD_write_str(3,1,"1KHz  ");//
            break;
            case 4://10KHZ
            LCD_write_str(3,1,"10KHz ");//
            break;
            case 5://100KHZ
            LCD_write_str(3,1,"100KHz");//
            break;
            case 6://1MHZ
            LCD_write_str(3,1,"1MHz  ");//
            break;
            case 7://10MHZ
            LCD_write_str(3,1,"10MHz ");//
            break;
  }   SI5351信號發生器.pdf (211.42 KB, 下載次數: 0)
收藏收藏8 分享淘帖 頂 踩
ID:1136941 發表于 2025-1-13 16:14 | 只看該作者
ID:1095428 發表于 2025-3-10 22:51 | 只看該作者
老師你好, DE BA7LNN, 謝謝,73!
