如題
- #include "ADF4351.h"
- #define SET_LE() GPIO_SetBits(GPIOC, GPIO_Pin_8) //LE
- #define CLR_LE() GPIO_ResetBits(GPIOC, GPIO_Pin_8)
- #define SET_SCL() GPIO_SetBits(GPIOA, GPIO_Pin_5) //CLK
- #define CLR_SCL() GPIO_ResetBits(GPIOA, GPIO_Pin_5)
- #define SET_DATA() GPIO_SetBits(GPIOA, GPIO_Pin_7) //DAT
- #define CLR_DATA() GPIO_ResetBits(GPIOA, GPIO_Pin_7)
- #define SET_CE() GPIO_SetBits(GPIOC, GPIO_Pin_13) //CE
- #define CLR_CE() GPIO_ResetBits(GPIOC, GPIO_Pin_13)
- u8 buf[4];
- //寫入32個字節
- void ADF4351_Write(u32 adf_dat)
- u8 i;
- CLR_LE();
- for (i = 0; i < 32; i++)
- if ((adf_dat & 0x80000000) == 0x80000000)
- SET_DATA();
- else
- CLR_DATA();
- CLR_SCL();
- SET_SCL();
- CLR_SCL();
- adf_dat <<= 1;
- SET_LE();
- delay(1);
- CLR_LE();
- void delay (int length)
- int i;
- i = length * 200 ;
- while (i >0)
- i--;
- void ADF4351_Initiate(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOA |RCC_APB2Periph_GPIOD, ENABLE); ;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_13;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOC, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_7;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
- GPIO_Init(GPIOD, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
- GPIO_ResetBits(GPIOC, GPIO_Pin_9); //PDRF恒為0
- SET_CE();
- //void WriteToADF4350(unsigned char count,unsigned char *buf);
- //Function that writes to the ADF4350 via the SPI port.
- void WriteToADF4350(unsigned char count, unsigned char *buf)
- unsigned char ValueToWrite = 0;
- unsigned char i = 0;
- unsigned char j = 0;
- delay(1);
- CLR_SCL();
- CLR_LE();
- delay(1);
- for(i=count;i>0;i--)
- ValueToWrite = *(buf + i - 1);
- for(j=0; j<8; j++)
- if(0x80 == (ValueToWrite & 0x80))
- SET_DATA(); //Send one to SDO pin
- else
- CLR_DATA(); //Send zero to SDO pin
- delay(1);
- SET_SCL();
- delay(1);
- ValueToWrite <<= 1; //Rotate data
- CLR_SCL();
- CLR_DATA();
- delay(1);
- SET_LE();
- delay(1);
- CLR_LE();
- //void ReadFromADF4350(unsigned char count,unsigned char *buf)
- //Function that reads from the ADF4350 via the SPI port.
- void ReadFromADF4350(unsigned char count, unsigned char *buf)
- unsigned int iTemp = 0;
- unsigned char RotateData = 0;
- delay(1);
- CLR_SCL();
- CLR_LE();
- delay(1);
- for(j=count; j>0; j--)
- for(i=0; i<8; i++)
- RotateData <<= 1; //Rotate data
- delay(1);
- // iTemp = GP4DAT; //Read DATA of ADF4350
- SET_SCL();
- if(0x00000020 == (iTemp & 0x00000020))
- RotateData |= 1;
- delay(1);
- CLR_SCL();
- *(buf + j - 1)= RotateData;
- delay(1);
- SET_LE();
- delay(1);
- CLR_LE();
- void Frequency_25MHz(void)
- { //4G輸出配置
- buf[3] = 0x00;
- buf[2] = 0x58;
- buf[1] = 0x00; //write communication register 0x00580005 to control the progress
- buf[0] = 0x05; //to write Register 5 to set digital lock detector
- WriteToADF4350(4,buf);
- buf[3] = 0x00;
- buf[2] = 0x0F; //EC //(DB23=1)The signal is taken from the VCO directly;(DB22-20:6H)the RF divider is 64;(DB19-12:50H)R is 80
- buf[1] = 0xA0; //(DB11=0)VCO powerd up;
- buf[0] = 0x24; //(DB5=1)RF output is enabled;(DB4-3=3H)Output power level is 5
- buf[3] = 0x00;
- buf[2] = 0x00;
- buf[1] = 0x04; //(DB14-3:96H)clock divider value is 150.
- buf[0] = 0xB3;
- buf[3] = 0x01;
- buf[2] = 0x00; //(DB6=1)set PD polarity is positive;(DB7=1)LDP is 6nS;
- buf[1] = 0x8E; //(DB8=0)enable fractional-N digital lock detect;
- buf[0] = 0x42; //(DB12-9:7H)set Icp 2.50 mA;
- WriteToADF4350(4,buf); //(DB23-14:1H)R counter is 1
- buf[3] = 0x08;
- buf[2] = 0x00;
- buf[1] = 0x80; //(DB14-3:6H)MOD counter is 6;
- buf[0] = 0x11; //(DB26-15:6H)PHASE word is 1,neither the phase resync
- WriteToADF4350(4,buf); //nor the spurious optimization functions are being used
- //(DB27=1)prescaler value is 8/9
- buf[3] = 0x00;
- buf[2] = 0x28;
- buf[1] = 0x00;
- buf[0] = 0x00; //(DB14-3:0H)FRAC value is 0;
- WriteToADF4350(4,buf); //(DB30-15:140H)INT value is 320;
- ////25MHz
- // buf[3] = 0x00;
- // buf[2] = 0x58;
- // buf[1] = 0x00;
- // buf[0] = 0x05;
- // WriteToADF4350(4,buf);
- // buf[3] = 0x00;
- // buf[2] = 0x8C;
- // buf[1] = 0x80;
- // buf[0] = 0x3C;
- // buf[3] = 0x00;
- // buf[2] = 0x00;
- // buf[1] = 0x04;
- // buf[0] = 0xB3;
- // buf[3] = 0x00;
- // buf[2] = 0x00;
- // buf[1] = 0x4E;
- // buf[0] = 0x42;
- // buf[3] = 0x08;
- // buf[2] = 0x00;
- // buf[1] = 0x80;
- // buf[0] = 0x11;
- // buf[3] = 0x00;
- // buf[2] = 0x50;
- // buf[1] = 0x00;
- // buf[0] = 0x00;
- /*-------------------------------------200MHz---------------------------------------------
- Reference frequency: 20MHz;Output frequency: 200MHz;VCO frequency: 3200MHz;Prescaler: 8/9;
- RF divider: 16;VCO channel spacing frequency: 200KHz;PFD frequency: 10MHz;
- INT: 320;FRAC: 0;MOD: 100;R: 1;Lock Clk Div: 6; bank clk div: 200; Phase: 1
- /*RFout = [INT + (FRAC/MOD)] * (Fpfd/RF Divider)*/
- /*Fpfd = REFIN * [(1 + D)/(R * (1 + T))]*/
- /*Fvco = RF divider * Output frequency 2.2G-4.4G*/
- void ADF_SetFre(void){
- u32 adf_data;
- u16 adf_R=1; //RF參考分頻系數
- u8 adf_D=0; //RF REFin倍頻器位(0 or 1)
- u8 adf_T=0; //參考二分頻位,產生占空比50%,減少周跳
- u16 adf_Locktime=160;
- u16 adf_MOD=1;
- u16 adf_INT=256;
- u16 adf_FARC=0;
- u16 adf_PHASE=1;
- // u8 pinduan;
- CLR_SCL();
- CLR_LE();
- //配置寄存器5
- adf_data = 0x00580000; //數字鎖存 LD引腳的工作方式為數字鎖存 D23 D22=01
- adf_data =adf_data | ADF_R5;
- ADF4351_Write(adf_data);
- //配置寄存器4
- adf_data = 0x00800038;
- /*(DB23=1)The signal is taken from the VCO directly,信號直接從VCO獲得
- 可修改RF divider, R的值(DB22-20)the RF divider is 16;
- (DB11=0)VCO powerd up; 輔助RF輸出禁用; 頻段選擇時鐘,分頻至125k, 分頻值160*/
- adf_data = adf_data | (RF_div32 << 20); //RF divider is 16
- adf_data = adf_data | (160 << 12); //頻段選擇時鐘
- adf_data = adf_data | ADF_R4; //(DB5=1)RF output is enabled;(DB4-3=3H)Output power level is 5dBm
- //配置寄存器3
- adf_data = 0x00848000;
- /*選擇高頻段(D23=1), APB6ns(D22=0,=建議小數分頻使用),,(D21=0,小數分頻使用) 使能CSR(D18=1),(D16 D15=01)快速鎖定
- 可修改clock divider value的值*/
- adf_data = adf_data | (adf_Locktime << 3);
- adf_data = adf_data | ADF_R3;
- //配置寄存器2
- adf_data = 0x61002040;
- //低雜散輸出, 禁用參考倍頻, 二分頻觸發器使能(減少周跳必須)
- //使能雙緩沖器, 設置電荷磅電流0.31, 小數N分頻(40), 設置R分頻器的值為1
- //設置鑒相器的極性, (DB6)同向濾波器1,反向濾波器0,這里用同向濾波器
- adf_data = adf_data | (adf_D << 25);
- adf_data = adf_data | (adf_T << 24);
- adf_data = adf_data | (adf_R << 14);
- adf_data = adf_data | ADF_R2;
- //配置寄存器1
- adf_data = 0x01008000;
- //禁用相位調整,預分頻器的值為8/9
- //相位字為1
- adf_data = adf_data | (adf_PHASE << 15);
- adf_data = adf_data | (adf_MOD << 3);
- adf_data = adf_data | ADF_R1;
- //配置寄存器0
- adf_data = 0x00000000;
- adf_data = adf_data | (adf_INT << 15);
- adf_data = adf_data | (adf_FARC << 3);
- adf_data= adf_data | ADF_R0;
0_Datasheet.rar
2025-1-1 21:59 上傳
下載積分: 黑幣 -5
1.37 MB, 下載次數: 0, 下載積分: 黑幣 -5
1_原理圖.rar
2025-1-1 21:59 上傳
下載積分: 黑幣 -5
632.17 KB, 下載次數: 0, 下載積分: 黑幣 -5
3_STM32測試源程序.7z
2025-1-2 15:21 上傳
下載積分: 黑幣 -5
186.47 KB, 下載次數: 0, 下載積分: 黑幣 -5
ADF435X模塊使用說明和測試記錄.rar
2025-1-1 22:01 上傳
下載積分: 黑幣 -5
997.56 KB, 下載次數: 0, 下載積分: 黑幣 -5
