查看: 938|回復: 1
求BL25CM1A驅動代碼
ID:958702 發表于 2024-12-25 14:34 | 顯示全部樓層 |閱讀模式
大佬們,有沒有BL25CM1A這個EEPROM的驅動代碼呀,單片機是STM32F407的
ID:404160 發表于 2024-12-25 23:15 | 顯示全部樓層
以下是一個簡單的STM32F407單片機對BL25CM1A EEPROM的驅動代碼示例,使用I2C通信協議:
```c
#include "stm32f4xx.h"
#include "stm32f4xx_i2c.h"
// 定義EEPROM的I2C地址
#define EEPROM_ADDR 0xA0
// 初始化I2C1
void I2C1_Init(void)
    GPIO_InitTypeDef GPIO_InitStruct;
    I2C_InitTypeDef I2C_InitStruct;
    // 使能I2C1和GPIO的時鐘
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1, ENABLE);
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
    // 配置SCL和SDA引腳
    GPIO_InitStruct.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
    GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;
    GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStruct.GPIO_OType = GPIO_OType_OD;
    GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_UP;
    GPIO_Init(GPIOB, &GPIO_InitStruct);
    // 將引腳連接到I2C1的AF功能
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource6, GPIO_AF_I2C1);
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_I2C1);
    // 配置I2C1
    I2C_InitStruct.I2C_ClockSpeed = 100000;
    I2C_InitStruct.I2C_Mode = I2C_Mode_I2C;
    I2C_InitStruct.I2c_DutyCycle = I2C_DutyCycle_2;
    I2C_InitStruct.I2C_OwnAddress1 = 0x00;
    I2C_InitStruct.I2C_Ack = I2C_Ack_Enable;
    I2C_InitStruct.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
    I2C_Init(I2C1, &I2C_InitStruct);
    // 使能I2C1
    I2C_Cmd(I2C1, ENABLE);
// 向EEPROM寫一個字節
void EEPROM_WriteByte(uint16_t address, uint8_t data)
    // 等待I2C空閑
    while (I2C_GetFlagStatus(I2C1, I2C_FLAG_BUSY));
    // 發送起始條件
    I2C_GenerateSTART(I2C1, ENABLE);
    while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT));
    // 發送EEPROM地址和寫命令
    I2C_Send7bitAddress(I2C1, EEPROM_ADDR, I2C_Direction_Transmitter);
    while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
    // 發送高字節地址
    I2C_SendData(I2C1, (address >> 8) & 0xFF);
    while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
    // 發送低字節地址
    I2C_SendData(I2C1, address & 0xFF);
    // 發送數據
    I2C_SendData(I2C1, data);
    // 發送停止條件
    I2C_GenerateSTOP(I2C1, ENABLE);
// 從EEPROM讀一個字節
uint8_t EEPROM_ReadByte(uint16_t address)
    uint8_t data = 0;
    // 等待I2C空閑
    // 發送起始條件
    // 發送EEPROM地址和寫命令
    // 發送高字節地址
    // 發送低字節地址
    // 重新發送起始條件
    // 發送EEPROM地址和讀命令
    I2C_Send7bitAddress(I2C1, EEPROM_ADDR, I2C_Direction_Receiver);
    while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
    // 讀取數據
    while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_RECEIVED));
    data = I2C_ReceiveData(I2C1);
    // 發送停止條件
    return data;
**代碼解釋**:
1. **I2C1_Init函數**:
    - 首先使能I2C1和相應GPIO的時鐘。
    - 配置I2C1的SCL和SDA引腳(這里使用GPIOB的引腳6和7)為復用功能、開漏輸出、上拉電阻。
    - 將這些引腳連接到I2C1的復用功能。
    - 配置I2C1的參數,如時鐘速度為100kHz,I2C模式、占空比、自身地址、ACK使能等。
    - 最后使能I2C1。
2. **EEPROM_WriteByte函數**:
    - 等待I2C總線空閑。
    - 發送起始條件,等待主模式選擇事件。
    - 發送EEPROM地址和寫命令,等待發送器模式選擇事件。
    - 發送要寫入數據的高字節地址,等待字節傳輸完成事件。
    - 發送低字節地址,等待字節傳輸完成事件。
    - 發送要存儲的數據,等待字節傳輸完成事件。
    - 發送停止條件結束傳輸。
3. **EEPROM_ReadByte函數**:
    - 等待I2C總線空閑。
    - 發送起始條件,等待主模式選擇事件。
    - 發送要讀取數據的高字節地址,等待字節傳輸完成事件。
    - 重新發送起始條件,等待主模式選擇事件。
    - 發送EEPROM地址和讀命令,等待接收器模式選擇事件。
    - 讀取數據,等待字節接收事件。
    - 發送停止條件結束傳輸。
**使用說明**:
- 在使用這些函數之前,確保已經正確配置了STM32F407的系統時鐘。
- 在`main`函數中調用`I2C1_Init()`來初始化I2C1。
- 使用`EEPROM_WriteByte(uint16_t address, uint8_t data)`函數將一個字節數據寫入EEPROM的指定地址,例如:`EEPROM_WriteByte(0x0000, 0x55);`。
- 使用`EEPROM_ReadByte(uint16_t address)`函數從EEPROM的指定地址讀取一個字節數據,例如:`uint8_t value = EEPROM_ReadByte(0x0000);`。
請注意,這只是一個基礎的驅動代碼示例,實際使用中可能需要根據BL25CM1A EEPROM的數據手冊進行更細致的調整,比如處理不同的頁寫操作、塊擦除操作,以及添加錯誤處理代碼等。并且,不同的STM32開發環境可能需要調整頭文件的包含和一些函數的調用方式,例如使用STM32CubeMX生成的代碼可能會使用`HAL`庫,而這里使用的是標準外設庫。如果遇到問題,可以根據具體的開發環境和芯片手冊進行調試和修改。
這個代碼是使用C語言為STM32F407單片機生成的BL25CM1A EEPROM的驅動代碼。首先,通過`I2C1_Init`函數初始化I2C1接口,包括使能相關時鐘,配置I2C引腳和I2C的參數。`EEPROM_WriteByte`函數用于向EEPROM寫入一個字節的數據,它遵循I2C協議的傳輸步驟,先等待I2C總線空閑,發送起始條件,發送EEPROM地址和寫命令,接著發送要寫入數據的地址,最后發送數據并發送停止條件。`EEPROM_ReadByte`函數用于從EEPROM讀取一個字節的數據,其流程和寫操作類似,但在發送地址后需要重新發送起始條件并發送讀命令,然后讀取數據。最后給出了代碼的使用說明,指導用戶如何調用這些函數進行數據的讀寫操作,同時也提醒用戶根據具體情況可能需要進一步完善和調整代碼。
