查看: 1283|回復: 0
單片機智能電飯鍋程序Proteus仿真原理圖
全部在壓縮包里面
  1. #include "reg52.h"
  2. #include "intrins.h"
  3. #include "onewire.h"
  4. sfr AUXR=0x8e;
  5. sbit S30=P3^0;unsigned int KEY_zhufan=0;
  6. sbit S31=P3^1;unsigned int KEY_dingshi=0;
  7. sbit S32=P3^2;unsigned int KEY_jia=0;
  8. sbit S33=P3^3;unsigned int KEY_jian=0;
  9. unsigned char SMG[10]={0x3f,0x06,0x5b,0x4f,0x66,
  10. 0x6d,0x7d,0x07,0x7f,0x6f};
  11. unsigned char SMG_DOT[10]={0xbf,0x86,0xdb,0xbf,0xe6,
  12. 0xed,0xfd,0x87,0xff,0xef};
  13. unsigned char WMG[6]={0xfe,0xfd,0xfb,0xf7,0XEF,0XDF};
  14. unsigned int temp;unsigned int decide_temp=30;
  15. unsigned int number=120;unsigned int frequency=0;
  16. void Delay(unsigned int t){
  17. while(t--);
  18. }
  19. void put_one(unsigned int pos,unsigned char dat){
  20. P2=WMG[pos];
  21. P0=dat;
  22. }
  23. void put_temp(){
  24. put_one(0,0x00);
  25. Delay(100);
  26. put_one(1,0x00);
  27. Delay(100);
  28. put_one(2,0x00);
  29. Delay(100);
  30. put_one(3,SMG[(temp/100)%10]);
  31. Delay(100);
  32. put_one(4,SMG[(temp/10)%10]);
  33. Delay(100);
  34. put_one(5,SMG[temp%10]);
  35. Delay(100);
  36. }
  37. void put_temp_dingshi(){
  38. put_one(0,SMG[(number/100)%10]);
  39. Delay(100);
  40. put_one(1,SMG[(number/10)%10]);
  41. Delay(100);
  42. put_one(2,SMG[number%10]);
  43. Delay(100);
  44. put_one(3,0x00);
  45. Delay(100);
  46. put_one(4,SMG[(temp/10)%10]);
  47. Delay(100);
  48. put_one(5,SMG[temp%10]);
  49. Delay(100);
  50. }
  51. void Delay_temp(unsigned int t){
  52. while(t--){
  53.   put_temp();
  54. }
  55. }
  56. void DS28B20_temp(){
  57. unsigned char LSB,MSB;
  58.
  59. init_ds18b20();
  60. Write_DS18B20(0xcc);
  61. Write_DS18B20(0x44);
  62. Delay_temp(200);
  63. init_ds18b20();
  64. Write_DS18B20(0xcc);
  65. Write_DS18B20(0xbe);
  66.
  67. LSB=Read_DS18B20();
  68. MSB=Read_DS18B20();
  69. temp=MSB;
  70. temp=(temp<<8)|LSB;
  71. temp=temp*0.0625;
  72. }
  73. void DS28B20_temp_dingshi(){
  74. unsigned char LSB,MSB;
  75.
  76. init_ds18b20();
  77. Write_DS18B20(0xcc);
  78. Write_DS18B20(0x44);
  79. Delay(200);
  80. init_ds18b20();
  81. Write_DS18B20(0xcc);
  82. Write_DS18B20(0xbe);
  83.
  84. LSB=Read_DS18B20();
  85. MSB=Read_DS18B20();
  86. temp=MSB;
  87. temp=(temp<<8)|LSB;
  88. temp=temp*0.0625;
  89. }
  90. void put_number(){
  91. put_one(0,SMG[(number/100)%10]);
  92. Delay(100);
  93. put_one(1,SMG[(number/10)%10]);
  94. Delay(100);
  95. put_one(2,SMG[number%10]);
  96. Delay(100);
  97. put_one(3,0x00);
  98. Delay(100);
  99. put_one(4,0x00);
  100. Delay(100);
  101. put_one(5,0x00);
  102. Delay(100);
  103. }
  104. void Init_timer0(void)
  105. {
  106.         AUXR &= 0x7F;
  107.         TMOD &= 0xF0;
  108.         TL0 = 0x00;
  109.         TH0 = 0xDC;
  110.         TF0 = 0;
  111.         TR0=1;
  112.
  113.   ET0=1;
  114.   EA=1;
  115. }
  116. void Timer0_break()interrupt 1
  117. {
  118.   frequency++;
  119.         if(frequency==100*60){
  120.           if(number==0){
  121.           TR0=0;
  122.                 KEY_zhufan=0;KEY_dingshi=0;KEY_jia=0;KEY_jian=0;
  123.           }
  124.           if(number!=0){
  125.           number--;
  126.           frequency=0;
  127.           }
  128.         }
  129. }
  130. void OFF(){
  131. put_one(0,0x5c);//0101 1100
  132. Delay(100);
  133. put_one(1,0x71);
  134. Delay(100);
  135. put_one(2,0x71);
  136. Delay(100);
  137. put_one(3,0x00);
  138. Delay(100);
  139. put_one(4,0x00);
  140. Delay(100);
  141. put_one(5,0x00);
  142. Delay(100);
  143. }
  144. void KEY(){
  145. if(S30==0){
  146.   Delay(30000);
  147.         if(S30==1){
  148.         KEY_zhufan=1;
  149.         KEY_dingshi=0;
  150.         KEY_jia=0;KEY_jian=0;
  151.         }
  152. }
  153. if(S31==0){
  154.   Delay(30000);
  155.         if(S31==1){
  156.         KEY_jia=0;KEY_jian=0;KEY_zhufan=0;
  157.         KEY_dingshi=1;
  158.         Init_timer0();
  159.         }
  160. }
  161. if(S32==0){
  162.   Delay(30000);
  163.         if(S32==1){
  164.         KEY_zhufan=0;KEY_dingshi=0;KEY_jian=0;
  165.         number+=10;
  166.         KEY_jia=1;
  167.         }
  168. }
  169. if(S33==0){
  170.   Delay(30000);
  171.         if(S33==1){
  172.         KEY_zhufan=0;KEY_dingshi=0;KEY_jia=0;
  173.         number-=10;
  174.         KEY_jian=1;
  175.         }
  176. }
  177. }
  178. void main(){
  179.         P1=0x7f;
  180. while(1){
  181.         KEY();
  182. if(KEY_jia+KEY_jian+KEY_zhufan+KEY_dingshi==0){
  183. OFF();
  184. }
  185. if(KEY_jia==1||KEY_jian==1){
  186.   put_number();
  187. }
  188. if(KEY_zhufan==1){
  189.    DS28B20_temp();
  190.    //put_temp();
  191.          if(temp>=decide_temp){
  192.          P1=0x3f;     //0011 1111
  193.          put_temp();
  194.          KEY_zhufan=0;
  195.          }
  196.          if(temp<decide_temp){
  197.          P1=0xff;     //1111 1111
  198.          put_temp();
  199.          }
  200. }
  201. if(KEY_dingshi==1){
  202.    DS28B20_temp_dingshi();
  203.          if(temp>=decide_temp){
  204.                   P1=0x3f;
  205.             put_temp_dingshi();
  206.
  207.          }
  208.          if(temp<decide_temp){
  209.       P1=0xff;
  210.                   put_temp_dingshi();
  211.
  212.          }
  213. }
  214. }
  215. }
仿真程序.7z
103.1 KB, 下載次數: 0, 下載積分: 黑幣 -5
代碼
收藏收藏1 分享淘帖 頂1 踩
