查看: 920|回復: 0
51單片機4*4鍵盤控制電機行為
請幫我看一下為什么我按下鍵盤后沒有對應的反應,只是有信號進入單片機,是哪里錯了嗎?
(從左上開始向右:正,反,加,減
                             開,停)
void keyscan(void)
    uchar Hang;
    uchar Lie;
    uchar hh=0;
    P1=0xf0;
    if((P1&0xf0)!=0xf0)
                        delay10ms();
             if((P1&0xf0)!=0xf0)
          Hang=0xfe;
          for(hh=0;hh<=3;hh++)
                                                        P1=Hang;
                                                        if((P1&0xf0)!=0xf0)
        Lie=(P1&0xf0|0x0f);
                    switch (Lie)
                    case 0xef: currentOp = FORWARD; break;  //
                    case 0xdf: currentOp = REVERSE; break;  //
                    case 0xbf: currentOp = SPEED_UP; break;  //
                    case 0x7f: currentOp = SPEED_DOWN; break;  //
                    case 0xdd: currentOp = STOP; break;  //
                    case 0xe0: currentOp = STOP; break;
                    default: break;
                    return;
                    Hang = _crol_(Hang, 1);  //
