查看: 1957|回復: 1
51單片機音樂播放器Proteus仿真
ID:1139743 發表于 2024-12-16 14:56 | 顯示全部樓層 |閱讀模式
主要代碼
#include "reg52.h"
#include "intrins.h"
sbit BEEP=P1^0;
uchar tick,tl,th;
uchar TABLE[]={
   0x82,0x01,0x81,0x94,0x84,0xB4,0xA4,0x04,
   0x82,0x01,0x81,0x94,0x84,0xC4,0xB4,0x04,
   0x82,0x01,0x81,0xF4,0xD4,0xB4,0xA4,0x94,
   0xE2,0x01,0xE1,0xD4,0xB4,0xC4,0xB4,0x04,
   0x00};
uchar TABLE1[]={
   0xfb,0x04,0xfb,0x90,0xfc,0x09,0xfc,0x44,
   0xfc,0xac,0xfd,0x09,0xfd,0x34,0xfd,0x82,
   0xfd,0xc8,0xfe,0x06,0xfe,0x22,0xfe,0x56,
   0xfe,0x85,0xfe,0x9a,0xfe,0xC1};
void timer0() interrupt 1 using 1
        TL0=tl;TH0=th;
        //請補充中斷服務函數內容
        BEEP=~BEEP;
void delay1()
        uint i;
        for(i=0;i<20000;i++) ;
void delay(tt)
          uint i;
        for(i=0;i<=tt;i++)
        delay1();
void main(void)
        uchar t,t0,k=0;
                //請補充初始化代碼:定時器T0,工作方式1,中斷總開關使能,定時器T0開關使能
                TMOD=0x01;IE=0x82;
                while(TABLE[k]!=0)
                        tick=(TABLE[k])&0x0f;
                        t=(_crol_(TABLE[k],4))&0x0f;
                        if(t!=0)
                                t0=(--t)*2+1;
                                t=t*2;
                                tl=TL0=TABLE1[t0];
                                th=TH0=TABLE1[t];
                                TR0=1;
                        else TR0=0;
                        delay(tick);
                        k++;
                TR0=0;
01.7z
82.45 KB, 下載次數: 0, 下載積分: 黑幣 -5
仿真和代碼
ID:1135606 發表于 2025-1-9 06:04 | 顯示全部樓層
程序不完整
