為啥數碼管不能正確顯示啊(代碼借鑒了論壇里的)
#include <REGX51.H>
sbit RED_A=P0^0;
sbit YELLOW_A=P0^1;
sbit GREEN_A=P0^2;
sbit RED_B=P0^3;
sbit YELLOW_B=P0^4;
sbit GREEN_B=P0^5;
unsigned char seg[]={0xC0,0xF9,0xA4,0xB0,0x99,
0x92,0x82,0xF8,0x80,0x90};
unsigned char wei[]={0xFE,0xFD};
unsigned int count0=0,timeleft=5,Time_Count=0,
Flash_Count=0,Operation_Type=1;
void inittimer()
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
ET0=1;
EA=1;
TR0=1;
void delay(unsigned int time)
unsigned int i,j;
for(i=0;i<time;i++)
for(j=0;j<120;j++);
void display(unsigned int time, unsigned char port)
unsigned char tens=time/10;
unsigned char units=time%10;
P3 = wei[0];
if (port==1)
P1=seg[tens];
P2=seg[tens];
delay(1);
P3 = wei[1];
if (port==1)
P1 = seg[units];
P2 = seg[units];
delay(1);
inittimer();
while(1){};
void T0_INT() interrupt 1
count0++;
if(count0>=20)
if (timeleft>0)
timeleft--;
count0=0;
switch(Operation_Type)
case 1:
RED_A=1;YELLOW_A=1;GREEN_A=0;
RED_B=0;YELLOW_B=1;GREEN_B=1;
if(++Time_Count!=100)
return;
display(timeleft,2);
Time_Count=0;
Operation_Type=2;
break;
case 2:
if(++Time_Count!=10)
return;
Time_Count=0;
YELLOW_A=~YELLOW_A;GREEN_A=1;
if(++Flash_Count!=10)
return;
Flash_Count=0;
Operation_Type=3;
break;
case 3:
RED_A=0;YELLOW_A=1;GREEN_A=1;
RED_B=1;YELLOW_B=1;GREEN_B=0;
return;
display(timeleft,1);
Time_Count=0;
Operation_Type=4;
break;
case 4:
return;
Time_Count=0;
YELLOW_B=~YELLOW_B;GREEN_B=1;
return;
Flash_Count=0;
Operation_Type=1;
break;
