查看: 664|回復(fù): 0
51單片機匯編語言 秒表
ID:1084649 發(fā)表于 2024-12-6 17:39 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
KEY1 BIT P1.0                ;按鍵1 IO口定義--啟動/暫停定時器
KEY2 BIT P1.1                ;按鍵2 IO口定義--定時器停止,清零
ORG 0000H
LJMP MAIN                         ;跳轉(zhuǎn)至MAIN
ORG 000BH
LJMP T0_INT
ORG 0100H
COUNT EQU 40H
SEC EQU 41H
AX EQU 42H
SEC1 EQU 44H
MAIN:
        MOV SP,#60H
        MOV TMOD,#01H
        MOV TL0,#0B0H
        MOV TH0,#3CH
        SETB EA
        CLR TR0
        MOV SEC,#0
        MOV AX,#0
M_LOOP:
        JNB KEY1,PK1        ;當(dāng)KEY1按下時,跳轉(zhuǎn)至PK1
        JNB KEY2,PK2        ;當(dāng)KEY2按下時,跳轉(zhuǎn)至PK2
        ACALL DISPLAY
        LJMP M_LOOP
PK1:ACALL DISPLAY
        JNB KEY1,PK1
        CPL TR0
        LJMP M_LOOP
PK2:ACALL DISPLAY
        JNB KEY2,PK2
        CLR TR0
        MOV SEC,#00H
        MOV AX,#00H
        LJMP M_LOOP
DISPLAY:
        MOV A,#01B
        MOV P2,A
        MOV DPTR,#TAB
        MOV A,AX
        MOV B,#10
        DIV        AB
        MOVC A,@A+DPTR
        MOV P0,A
        ACALL DELAY
        MOV P0,#0FFH
        MOV A,#10B
        MOV P2,A
        MOV DPTR,#TAB
        MOV A,AX
        MOV B,#10
        DIV AB
        MOV A,B
        MOVC A,@A+DPTR
        MOV P0,A
        CALL DELAY
        MOV P0,#0FFH
        MOV A,#100B
        MOV P2,A
        MOV A,SEC
        MOV B,#10
        DIV        AB
        MOVC A,@A+DPTR
        MOV P0,A
        ACALL DELAY
        MOV P0,#0FFH
        MOV A,#1000B
        MOV P2,A
        MOV DPTR,#TAB
        MOV A,SEC
        MOV B,#10
        DIV AB
        MOV A,B
        MOVC A,@A+DPTR
        MOV P0,A
        CALL DELAY
        MOV P0,#0FFH
        RET
T0_INT:
        MOV TL0,#0B0H
        MOV TH0,#3CH
        PUSH PSW
        MOV A,COUNT
        INC A
        MOV COUNT,A
        CJNE A,#20,T0RE
        MOV A,#00H;
        MOV COUNT,A
        MOV A,SEC
        INC A
        MOV SEC,A
        CJNE A,#60,T0RE
        MOV A,#00H
        MOV SEC,A
        INC AX
T0RET: POP PSW
           RETI
DELAY:
           MOV R1,#40
DELAY1:NOP
           DJNZ R1,DELAY1
           RET
TAB:
     DB 0C0H,0F9H,0A4H,0B0H,99H,92H,82H,0F8H,080H,090H
END
