#include <reg51.h> #include <intrins.h> #define ushort unsigned short //P0,P1,P2,P3數(shù)據(jù)類型是 unsigned short ;數(shù)值范圍 :0~~~~65 635 #define uint unsigned int ushort code display_P0[]={ //P0 口顯示內(nèi)容 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, //P0--》P3逐個堆積點亮部分的P0 流水點亮 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, //P0 全滅等待 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, //P0--》P3逐個堆積點亮部分的P0 堆積點亮 0x7E,0x7D,0x7B,0x77,0x6F,0x5F,0x3F, 0x3E,0x3D,0x3B,0x37,0x2F,0x1F, 0x1E,0x1D,0x1B,0x17,0x0F, 0x0E,0x0D,0x0B,0x07, 0x06,0x05,0x03, 0x02,0x01, 0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //P0 閃爍 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, //P0--》P3間隔點亮部分的P0 1,3,5,7 亮。2,4,6,8滅 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //P0 閃爍 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFE,0xFC,0xF8,0xF0,0xE0,0xC0,0x80,0x00, //P0--》P3從兩邊到中間逐個點亮部分的P0逐個點亮 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //P0--》P3從兩邊到中間逐個點亮部分的P0全亮等待 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //P0--》P3從兩邊到中間逐個熄滅部分的P0全亮等待 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF, //P0--》P3從兩邊到中間逐個熄滅部分的P0逐個熄滅 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //P0 閃爍// 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFE,0xFC,0xF8,0xF0,0xE0,0xC0,0x80,0x00, //P0--》P3從左到右逐個點亮部分的P0逐個點亮 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //P0--》P3從左到右逐個點亮部分的P0全亮等待 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //P0--》P3從右到左逐個熄滅部分的P0全亮等待 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF, //P0--》P3從右到左逐個熄滅部分的P0逐個熄滅 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //P0 閃爍 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, }; ushort code display_P1[]={ 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F, 0x7E,0x7D,0x7B,0x77,0x6F,0x5F,0x3F, 0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F, 0x3E,0x3D,0x3B,0x37,0x2F,0x1F, 0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F, 0x1E,0x1D,0x1B,0x17,0x0F, 0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F, 0x0E,0x0D,0x0B,0x07, 0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07, 0x06,0x05,0x03, 0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03, 0x02,0x01, 0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01, 0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00, 0x00,0x00,0x00, 0x00,0x00, 0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFC,0xF8,0xF0,0xE0,0xC0,0x80,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFC,0xF8,0xF0,0xE0,0xC0,0x80,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, }; ushort code display_P2[]={ 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F, 0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F, 0x7E,0x7D,0x7B,0x77,0x6F,0x5F,0x3F, 0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F, 0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F, 0x3E,0x3D,0x3B,0x37,0x2F,0x1F, 0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F, 0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F, 0x1E,0x1D,0x1B,0x17,0x0F, 0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F, 0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F, 0x0E,0x0D,0x0B,0x07, 0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07, 0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07, 0x06,0x05,0x03, 0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03, 0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03, 0x02,0x01, 0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01, 0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01, 0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00, 0x00,0x00,0x00, 0x00,0x00, 0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x7F,0x3F,0x1F,0x0F,0x07,0x03,0x01,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x01,0x03,0x07,0x0F,0x1F,0x3F,0x7F,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFC,0xF8,0xF0,0xE0,0xC0,0x80,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, }; ushort code display_P3[]={ 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F, 0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F, 0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F, 0x7E,0x7D,0x7B,0x77,0x6F,0x5F,0x3F, 0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F, 0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F, 0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F, 0x3E,0x3D,0x3B,0x37,0x2F,0x1F, 0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F, 0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F, 0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F, 0x1E,0x1D,0x1B,0x17,0x0F, 0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F, 0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F, 0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F, 0x0E,0x0D,0x0B,0x07, 0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07, 0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07, 0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07, 0x06,0x05,0x03, 0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03, 0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03, 0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03, 0x02,0x01, 0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01, 0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01, 0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01, 0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00, 0x00,0x00,0x00, 0x00,0x00, 0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, 0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x7F,0x3F,0x1F,0x0F,0x07,0x03,0x01,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x01,0x03,0x07,0x0F,0x1F,0x3F,0x7F,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFE,0xFC,0xF8,0xF0,0xE0,0xC0,0x80,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, }; void delayms(uint ms) //延時子程序 { ushort k; while(ms--) { for(k = 0; k < 50; k++); } } void main(void) //P0---》P3 初始狀態(tài) { ushort i; P0 = 0xff; P1 = 0xff; P2 = 0xff; P3 = 0xff; while(1) //定義P0,P1,P2,P3, for(i=0;i <946; i++) { P0 =display_P0[i]; P1 =display_P1[i]; P2 =display_P2[i]; P3 =display_P3[i]; delayms(50); } } |
