// Main.c
// Copyright (C) 2013 Shenyang JYXD.
// WEN BO RUI
// Tool chain: KEIL Full c
//#pragma CD OE DB SB // Compilation directives
#include <STC8G.H>
#include <intrins.h>
//#include
//#include
uint Period; //Period刷新周期
uint PWM;
uint Pulse; //脈沖個數(shù)
uchar Speed; //速度變量
uchar count;
uint excount;
bit Gra; //漸變/跳變總控制位
bit Gra7; //七彩漸亮漸滅控制位
bit Gra3; //紅綠藍漸亮漸滅控制位
bit BP; //亮到暗,暗到亮轉(zhuǎn)換位
bit LEDdelay ; //LED定時到標(biāo)志位
sbit key1 = P3^1; //花樣組合鍵
sbit key2 = P3^5; //速度組合鍵
uchar led1[12]={0x10,0x030,0x20,0x60,0x40,0x50,0x70,0x50,0x40,0x60,0x20,0x30};//紅、黃、綠、青、藍、粉、白、粉、藍、青、綠、黃
uchar led2[24]={0x10,0x00,0x30,0x00,0x20,0x00,0x60,0x00,0x40,0x00,0x50,0x00,
0x70,0x00,0x50,0x00,0x40,0x00,0x60,0x00,0x20,0x00,0x30,0x00};
uchar led3[3]={0x10,0x20,0x40}; //紅、綠、藍
uchar ledcount,ledcount1;
//以下定義函數(shù)
// 1毫秒延時函數(shù)delayms();花樣及速度掃描函數(shù)keyscan();
/*void delayms(unsigned int ms)
unsigned char i ;
while(ms--)
for(i = 0 ; i < 120 ; i++) ;
void Pattern1(); //花樣1函數(shù)--------->跳變無滅燈過程
void Pattern2(); //花樣2函數(shù)--------->跳變有滅燈過程
void Pattern34();
void keyscan()
if(k1 = 0) {Speed = 20;Period = 25;} //預(yù)設(shè)4種速度200MS
if(k1 = 1) {Speed = 50;Period = 50;} //500MS
if(k1 = 2) {Speed = 100;Period = 100;} //1S
if(k1 = 3) {Speed = 150;Period = 200;} //1.5S
if(k2 = 0) {ledcount1 = 0;Pattern1();} //預(yù)設(shè)4種花樣
if(k2 = 1) {ledcount1 = 0;Pattern2();}
if(k2 = 2) {ledcount = 0;Gra3 = 1;Pattern34();}
if(k2 = 3) {ledcount = 0;Gra7 = 1;Pattern34();}
void value()
if(Speed == 20) PWM = Pulse*8;
if(Speed == 50) PWM = Pulse*4; //脈沖個數(shù)
if(Speed == 100)PWM = Pulse*2;
if(Speed == 150)PWM = Pulse;
void Reset(void)
unsigned char code rst[ ]={0xe4,0xc0,0xe0,0xc0,0xe0,0x32};
(*((void (*)(void))(rst)))();
_nop_ ();
_nop_ ();
_nop_ ();
P1 = 0;
TMOD = 0x11; //11.0592M晶振的10ms定時初值(100分之一秒)
TH0 = 0x0db;
TL0 = 0x0ff;
TH1 = 0x0ff; //0.05ms(20000分之一秒)
TL1 = 0x0D1;
EA = 1; //開啟總中斷允許
ET0 = 1; //允許T0定時器中斷
ET1 = 1; //允許T1定時器中斷
TR0 = 1; //開啟T0定時器
EX0=1; //開外部中斷0
IT0=1; //下降沿觸發(fā)
keyscan();
//Pattern1() 花樣函數(shù)1-------------跳變無滅燈過程
void Pattern1()
//keyscan();
Gra = 0; //跳變位=0
if(LEDdelay)
LEDdelay = 0;
P1 = led1[ledcount];
ledcount++;
if(ledcount>11)
ledcount = 0;
//Pattern2() 花樣函數(shù)2-------------跳變有滅燈過程
void Pattern2()
keyscan();
Gra = 0;
if(LEDdelay)
LEDdelay = 0;
P1 = led2[ledcount];
ledcount++;
if(ledcount>23)
ledcount = 0;
//Pattern3() 花樣函數(shù)3-------------3彩漸變
void Pattern3()
keyscan();
if(Speed == 20) Period = 25;
if(Speed == 50) Period = 50;
if(Speed == 100)Period = 100;
if(Speed == 150)Period = 200;
Gra = 1;
Gra3 = 1;
//Pattern4() 花樣函數(shù)4-------------7彩漸變
void Pattern34()
Gra = 1; //漸變位 = 1
// 定時器0中斷服務(wù)程序
void time0(void) interrupt 1
TR1 =0;
TF0 =0;
TH0=0xdb; //重新寫入初值
TL0=0xff;
if(!Gra) //執(zhí)行跳變程序
count ++;
if(count > Speed)
LEDdelay = 1;
count = 0;
if(Gra)
TR1 = 1; //開啟TR1;
if(!BP) //
if(Gra7)
P1 = led1[ledcount1]; //10ms到,亮相應(yīng)的LED
if(Gra3)
P1 = led3[ledcount1]; //10ms到,亮相應(yīng)的LED
Pulse++;
value();
if(Pulse >= Period)
Pulse = Period;
BP = 1; //一個周期完成轉(zhuǎn)換模式
if(BP)
if(Gra7)
if(Gra3)
value();
Pulse--; //脈沖個數(shù)
if(Pulse == 0)
Pulse = 0;
BP = 0; //一個周期完成轉(zhuǎn)換模式
ledcount1++;
if(Gra7)
if(ledcount1 > 11)
ledcount1 = 0;
Gra7 = 0;
if(Gra3)
if(ledcount1 > 2)
ledcount1 = 0;
Gra3 = 0;
// 定時器1中斷服務(wù)程序
void timer1() interrupt 3
PWM --;
TH1 = 0xff; //0.05ms(20000分之一秒)
TL1 = 0xD1;
if(PWM == 0)
P1 = 0;
TR1 = 0;
// 外部中斷0中斷服務(wù)程序 下降沿觸發(fā)
void extern0(void) interrupt 0
IE0 = 0; // 清標(biāo)志位
excount++;
if(excount>50) // 50大約3秒
EA = 0;
//P1_5 = 1;
excount = 0;
Reset();
