#include <reg52.h>
#include <intrins.h>
sbit Beep = P2^3 ;
unsigned char n=0; //n為節(jié)拍常數(shù)變量
unsigned char code music_tab[] ={
0x18, 0x30, 0x1C , 0x10, //格式為: 頻率常數(shù), 節(jié)拍常數(shù), 頻率常數(shù), 節(jié)拍常數(shù),
0x20, 0x40, 0x1C , 0x10,
0x18, 0x10, 0x20 , 0x10,
0x1C, 0x10, 0x18 , 0x40,
0x1C, 0x20, 0x20 , 0x20,
0x1C, 0x20, 0x18 , 0x20,
0x20, 0x80, 0xFF , 0x20,
0x30, 0x1C, 0x10 , 0x18,
0x20, 0x15, 0x20 , 0x1C,
0x20, 0x20, 0x20 , 0x26,
0x40, 0x20, 0x20 , 0x2B,
0x20, 0x26, 0x20 , 0x20,
0x20, 0x30, 0x80 , 0xFF,
0x20, 0x20, 0x1C , 0x10,
0x18, 0x10, 0x20 , 0x20,
0x26, 0x20, 0x2B , 0x20,
0x30, 0x20, 0x2B , 0x40,
0x20, 0x30, 0x1C , 0x10,
0x18, 0x20, 0x15 , 0x20,
0x26, 0x40, 0x20 , 0x20,
0x2B, 0x20, 0x26 , 0x20,
0x20, 0x20, 0x30 , 0x80,
0x20, 0x10, 0x1C , 0x10,
0x20, 0x20, 0x26 , 0x20,
0x2B, 0x20, 0x30 , 0x20,
0x2B, 0x40, 0x20 , 0x15,
0x1F, 0x05, 0x20 , 0x10,
0x1C, 0x10, 0x20 , 0x20,
0x20, 0x20, 0x30 , 0x30,
0x18, 0x40, 0x1C , 0x20,
0x20, 0x20, 0x26 , 0x40,
0x13, 0x60, 0x18 , 0x20,
0x15, 0x40, 0x13 , 0x40,
0x18, 0x80, 0x00
void delay (unsigned char m) //控制頻率延時
unsigned i=3*m;
while(--i);
void delayms(unsigned char a) //豪秒延時子程序
while(--a);
unsigned char p,m; //m為頻率常數(shù)變量
unsigned char i=0;
TMOD&=0x0f;
TMOD|=0x01;
TH0=0xd8;TL0=0xef;
IE=0x82;
play:
a: p=music_tab[ i];
if(p==0x00)
i=0, delayms(1000); goto play; //如果碰到結(jié)束符,延時1秒,回到開始再來一遍
if(p==0xff)
i=i+1;delayms(100),TR0=0; goto a; //若碰到休止符,延時100ms,繼續(xù)取下一音符
m=music_tab[i++], n=music_tab[i++]; //取頻率常數(shù) 和 節(jié)拍常數(shù)
TR0=1; //開定時器0
while(n!=0) //等待節(jié)拍完成,輸出音頻
Beep=~Beep;
delay(m);
TR0=0; //關(guān)定時器0
void int0() interrupt 1 //采用中斷定時器0 控制節(jié)拍
TH0=0xd8;
TL0=0xef;
n--;
