查看: 1525|回復(fù): 1
ESP8266太空人動畫的OLED顯示
ESP8266 太空人動畫的 OLED 顯示接線
  1. SCL - D1
  2. SDA - D2
  3. VCC - 3V
  4. GND - GND
代碼
  1. #include <Wire.h>
  2. #include <Adafruit_GFX.h>
  3. #include <Adafruit_SSD1306.h>
  4. #define SCREEN_WIDTH 128
  5. #define SCREEN_HEIGHT 64
  6. int fps=40;
  7. #define OLED_RESET -1
  8. Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
  9. #include "images_invert.h"
  10. void setup() {
  11. Serial.begin(115200);
  12. if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
  13.    Serial.println(F("SSD1306 allocation failed"));
  14.    for(;;);
  15. }// Pause for 2 seconds
  16. // Clear the buffer.
  17. }
  18. void loop() {
  19. display.clearDisplay();
  20. display.drawBitmap(0, 0, gImage_1, 128, 64, 1);
  21. display.display();
  22. delay(fps);
  23. display.clearDisplay();
  24. display.drawBitmap(0, 0, gImage_2, 128, 64, 1);
  25. display.display();
  26. delay(fps);
  27. display.clearDisplay();
  28. display.drawBitmap(0, 0, gImage_3, 128, 64, 1);
  29. display.display();
  30. delay(fps);
  31. display.clearDisplay();
  32. display.drawBitmap(0, 0, gImage_4, 128, 64, 1);
  33. display.display();
  34. delay(fps);
  35. display.clearDisplay();
  36. display.drawBitmap(0, 0, gImage_5, 128, 64, 1);
  37. display.display();
  38. delay(fps);
  39. display.clearDisplay();
  40. display.drawBitmap(0, 0, gImage_6, 128, 64, 1);
  41. display.display();
  42. delay(fps);
  43. display.clearDisplay();
  44. display.drawBitmap(0, 0, gImage_7, 128, 64, 1);
  45. display.display();
  46. delay(fps);
  47. display.clearDisplay();
  48. display.drawBitmap(0, 0, gImage_8, 128, 64, 1);
  49. display.display();
  50. delay(fps);
  51. display.clearDisplay();
  52. display.drawBitmap(0, 0, gImage_9, 128, 64, 1);
  53. display.display();
  54. delay(fps);
  55. display.clearDisplay();
  56. display.drawBitmap(0, 0, gImage_10, 128, 64, 1);
  57. display.display();
  58. delay(fps);
  59. display.clearDisplay();
  60. display.drawBitmap(0, 0, gImage_11, 128, 64, 1);
  61. display.display();
  62. delay(fps);
  63. display.clearDisplay();
  64. display.drawBitmap(0, 0, gImage_12, 128, 64, 1);
  65. display.display();
  66. delay(fps);
  67. display.clearDisplay();
  68. display.drawBitmap(0, 0, gImage_13, 128, 64, 1);
  69. display.display();
  70. delay(fps);
  71. display.clearDisplay();
  72. display.drawBitmap(0, 0, gImage_14, 128, 64, 1);
  73. display.display();
  74. delay(fps);
  75. display.clearDisplay();
  76. display.drawBitmap(0, 0, gImage_15, 128, 64, 1);
  77. display.display();
  78. delay(fps);
  79. display.clearDisplay();
  80. display.drawBitmap(0, 0, gImage_16, 128, 64, 1);
  81. display.display();
  82. delay(fps);
  83. display.clearDisplay();
  84. display.drawBitmap(0, 0, gImage_17, 128, 64, 1);
  85. display.display();
  86. delay(fps);
  87. display.clearDisplay();
  88. display.drawBitmap(0, 0, gImage_18, 128, 64, 1);
  89. display.display();
  90. delay(fps);
  91. display.clearDisplay();
  92. display.drawBitmap(0, 0, gImage_19, 128, 64, 1);
  93. display.display();
  94. delay(fps);
  95. display.clearDisplay();
  96. display.drawBitmap(0, 0, gImage_20, 128, 64, 1);
  97. display.display();
  98. delay(fps);
  99. }
取模
打開目標(biāo)圖片文件夾,導(dǎo)入一張圖片,選擇 批量轉(zhuǎn)換 ,于是每一幀圖片的 128*64=1024 個(gè) 16 位信息將以 .c 文件格式被分別存儲至 batch 文件夾下。將所有C文件中的代碼復(fù)制到同一文件中,重名為 images.h 文件。
效果展示
反相取值
Code.zip
13.48 KB, 下載次數(shù): 5, 下載積分: 黑幣 -5
工程代碼
參與人數(shù) 1黑幣 +50 收起 理由
收藏收藏1 分享淘帖 頂1 踩
ID:46004 發(fā)表于 2024-10-16 16:44 | 只看該作者
學(xué)習(xí)中,不錯。
