演示PY32F030K28自帶RTC并驅(qū)動(dòng)LED數(shù)碼顯示時(shí)鐘。
* 文件名程: main.c
* 作 者: 東莞鄧凱哥
* 功 能: 主函數(shù)
* 硬 件: PY32F030K28-StartKit-V0.1
* 說明:數(shù)碼管顯示RTC時(shí)鐘DEMO
* 軟件版本 V0.0.1(2024/4/16 16:02)
#include "main.h"
#include "rtc.h"
#include "rcc.h"
#include "led.h"
#include "usart.h"
#include "timepare.h"
/* Private variables ---------------------------------------------------------*/
const uint8_t dispArr[] = {LL_LED_DISP_0, LL_LED_DISP_1, LL_LED_DISP_2, LL_LED_DISP_3, LL_LED_DISP_4, \
LL_LED_DISP_5, LL_LED_DISP_6, LL_LED_DISP_7, LL_LED_DISP_8, LL_LED_DISP_9
static uint8_t dotdis = 0 ;
**函數(shù)信息 :System_Tick(uint32_t Ticks)
**功能描述 :系統(tǒng)嘀嗒時(shí)鐘配置
**輸入?yún)?shù) :Ticks 頻率
**輸出參數(shù) :無
**說 明 :
void System_Tick(uint32_t Ticks)
SysTick->LOAD = (uint32_t)((SystemCoreClock / Ticks) - 1UL); /* set reload register */
SysTick->VAL = 0UL; /* Load the SysTick Counter Value */
SysTick->CTRL = SysTick_CTRL_CLKSOURCE_Msk |
SysTick_CTRL_TICKINT_Msk |
SysTick_CTRL_ENABLE_Msk; /* Enable the Systick Timer */
**函數(shù)信息 :main()
**功能描述 :主函數(shù)
**輸入?yún)?shù) :無
**輸出參數(shù) :無
**說 明 :
int main(void)
/* 配置系統(tǒng)時(shí)鐘 */
APP_RCC_Config();
/* 配置USART1相關(guān)參數(shù) */
APP_USART1_Config();
/* 配置LED相關(guān)參數(shù) */
APP_LED_Config();
/* 配置RTC相關(guān)參數(shù) */
APP_RTC_Config();
/* 設(shè)置RTC時(shí)間 */
SET_RTC_Time(8,14,23);
/* 開啟系統(tǒng)嘀嗒定時(shí)器 */
System_Tick(1000);
while (1)
if( TimePare.Tim1ms_flag == 1 ) //1ms任務(wù)
TimePare.Tim1ms_flag = 0;
if( ++TimePare.Tim10ms_count >= 10 )
TimePare.Tim10ms_count = 0;
TimePare.Tim10ms_flag = 1;
if( ++TimePare.Tim50ms_count >= 50 )
TimePare.Tim50ms_count = 0;
TimePare.Tim50ms_flag = 1;
if( TimePare.Tim10ms_flag == 1 ) //10ms 任務(wù)
TimePare.Tim10ms_flag = 0;
if( ++TimePare.Tim100ms_count >= 10 )
TimePare.Tim100ms_count = 0;
TimePare.Tim100ms_flag = 1;
if( ++TimePare.Tim200ms_count >= 20 )
TimePare.Tim200ms_count = 0;
TimePare.Tim200ms_flag = 1;
if( TimePare.Tim50ms_flag == 1 ) //50ms 任務(wù)
TimePare.Tim50ms_flag = 0;
if( TimePare.Tim100ms_flag == 1 ) //100ms 任務(wù)
TimePare.Tim100ms_flag = 0;
if( ++TimePare.Tim500ms_count >= 5 )
TimePare.Tim500ms_count = 0;
TimePare.Tim500ms_flag = 1;
if( TimePare.Tim200ms_flag == 1 ) //200ms 任務(wù)
TimePare.Tim200ms_flag = 0;
if( TimePare.Tim500ms_flag == 1 ) //500ms 任務(wù)
dotdis ++;
APP_UpadateRtcTimeStruct();
//顯示RTC時(shí)鐘
LL_LED_SetDisplayValue(LED, LL_LED_COM0, dispArr[ RTC_TimeStruct.hour /10]);
// if( dotdis / 2 ) //常規(guī)的方法,用除法
if( dotdis >> 1 ) //更高效的方法,用移位
dotdis = 0;
LL_LED_SetDisplayValue(LED, LL_LED_COM1, dispArr[ RTC_TimeStruct.hour %10] | LL_LED_DISP_DOT ); //時(shí)鐘點(diǎn)閃爍
}else{
LL_LED_SetDisplayValue(LED, LL_LED_COM1, dispArr[ RTC_TimeStruct.hour %10] );
LL_LED_SetDisplayValue(LED, LL_LED_COM2, dispArr[ RTC_TimeStruct.min /10]);
LL_LED_SetDisplayValue(LED, LL_LED_COM3, dispArr[ RTC_TimeStruct.min %10]);
TimePare.Tim500ms_flag = 0;
if( ++TimePare.Tim1s_count >= 2 )
TimePare.Tim1s_count = 0;
TimePare.Tim1s_flag = 1;
if( TimePare.Tim1s_flag == 1 ) //1000ms 任務(wù)
printf("Hours = %02d, Min = %02d, Sec = %02d\r\n",\
RTC_TimeStruct.hour, RTC_TimeStruct.min, RTC_TimeStruct.sec); //串口打印 時(shí),分,秒
TimePare.Tim1s_flag = 0;
* @brief 錯(cuò)誤執(zhí)行函數(shù)
* @param 無
* @retval 無
void APP_ErrorHandler(void)
/* 無限循環(huán) */
while (1)
#ifdef USE_FULL_ASSERT
* @brief 輸出產(chǎn)生斷言錯(cuò)誤的源文件名及行號(hào)
* @param file:源文件名指針
* @param line:發(fā)生斷言錯(cuò)誤的行號(hào)
* @retval 無
void assert_failed(uint8_t *file, uint32_t line)
/* 用戶可以根據(jù)需要添加自己的打印信息,
例如: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* 無限循環(huán) */
while (1)
#endif /* USE_FULL_ASSERT */
程序和PDF格式的原理圖:
01.7z
(1.07 MB, 下載次數(shù): 5)
2024-9-9 01:39 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
