查看: 351|回復: 0
電力采集程序qt源碼
ID:312272 發表于 2024-8-22 08:51 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. #include "mainwindow.h"
  2. #include "ui_mainwindow.h"
  3. #include <QTimer>
  4. #include <QDebug>
  5. MainWindow::MainWindow(QWidget *parent) :
  6.     QMainWindow(parent),
  7.     ui(new Ui::MainWindow), m_serialPort(new QSerialPort()), m_timer(new QTimer)
  8. {
  9.     ui->setupUi(this);
  10.     QComboBox* serialCbo = findChild<QComboBox*>("cboSerial", Qt::FindChildOption::FindChildrenRecursively);
  11.     //獲取所有串口信息
  12.     foreach(const QSerialPortInfo &info,QSerialPortInfo::availablePorts())
  13.     {
  14.         qDebug() << "serialPortName:" << info.portName();
  15.         qDebug() << "isBusy:" << info.isBusy();
  16.         qDebug() << "isNull:" << info.isNull();
  17.         qDebug() << "serialCbo:" << serialCbo;
  18.         if(!info.isBusy()){
  19.             serialCbo->addItem(info.portName());
  20.         }
  21.     }
  22. }
  23. MainWindow::~MainWindow()
  24. {
  25.     delete ui;
  26. }
  27. void MainWindow::on_btnOpenSerial_clicked()
  28. {
  29.     QPushButton* btn = findChild<QPushButton*>("btnOpenSerial", Qt::FindChildOption::FindChildrenRecursively);
  30.     if(btn->text() == "打開串口"){//打開
  31.         if(m_serialPort->isOpen())//如果串口已經打開了 先給他關閉了
  32.         {
  33.             m_serialPort->clear();
  34.             m_serialPort->close();
  35.         }
  36.         //設置串口名字 假設我們上面已經成功獲取到了 并且使用第一個
  37.         QComboBox* serialCbo = findChild<QComboBox*>("cboSerial", Qt::FindChildOption::FindChildrenRecursively);
  38.         m_serialPort->setPortName(serialCbo->currentText());
  39.         QLabel* serialState = findChild<QLabel*>("lblSerialState", Qt::FindChildOption::FindChildrenRecursively);
  40.         if(!m_serialPort->open(QIODevice::ReadWrite))//用ReadWrite 的模式嘗試打開串口
  41.         {
  42.             serialState->setText(serialCbo->currentText() + "打開失敗!");
  43.             return;
  44.         }
  45.         //打開成功
  46.         serialState->setText(serialCbo->currentText() + "打開成功!");
  47.         m_serialPort->setBaudRate(QSerialPort::Baud9600,QSerialPort::AllDirections);//設置波特率和讀寫方向
  48.         m_serialPort->setDataBits(QSerialPort::Data8);        //數據位為8位
  49.         m_serialPort->setFlowControl(QSerialPort::NoFlowControl);//無流控制
  50.         m_serialPort->setParity(QSerialPort::NoParity);    //無校驗位
  51.         m_serialPort->setStopBits(QSerialPort::OneStop); //一位停止位
  52.         //連接信號槽 當下位機發送數據QSerialPortInfo 會發送個 readyRead 信號,我們定義個槽void receiveInfo()解析數據
  53.         connect(m_serialPort,SIGNAL(readyRead()),this, SLOT(receiveInfo()));
  54.         connect(m_timer,SIGNAL(timeout()),this, SLOT(timeUpdate()));
  55.         btn->setText("關閉串口");
  56.     }else {//關閉
  57.         QComboBox* serialCbo = findChild<QComboBox*>("cboSerial", Qt::FindChildOption::FindChildrenRecursively);
  58.         QLabel* serialState = findChild<QLabel*>("lblSerialState", Qt::FindChildOption::FindChildrenRecursively);
  59.         if (m_serialPort->isOpen())
  60.         {
  61.             m_serialPort->close();
  62.             serialState->setText(serialCbo->currentText() + "關閉成功!");
  63.             btn->setText("打開串口");
  64.             return;
  65.         }
  66.         serialState->setText(serialCbo->currentText() + "不能重復關閉!");
  67.     }
  68. }
  69. float power;
  70. int i = 1;
  71. QByteArray buf;
  72. void MainWindow::receiveInfo()
  73. {
  74.     m_timer->start(100);
  75.     buf.append(m_serialPort->readAll());
  76. }
  77. void MainWindow::timeUpdate(){
  78.     m_timer->stop();
  79.     if(buf.length() > 0){
  80.         qDebug() << "receive..." << buf.length();
  81.         //上述方法不是每次都返回21,每次可能不能完全讀完,分幾次讀取,或一次讀完的都有
  82.         if(buf.length() != 25){//只對正確的情況做處理,其余數據不全的忽略
  83.             return;
  84.         }
  85.         //buf[17] 返回類型為 QByteRef 類型,并非char,不能用它
  86.         //而應該用at()
  87.         //取電壓
  88.         qDebug("volt %02x-%02x", buf.at(3), buf.at(4));
  89.         float volt = ((unsigned char)buf.at(3) << 8) + (unsigned char)buf.at(4);
  90.         qDebug() << volt;
  91.         volt *= 0.1;
  92.         QString data = QString("電壓:%1 V").arg(volt);
  93.         QLabel* lblVolt = findChild<QLabel*>("lblVolt", Qt::FindChildOption::FindChildrenRecursively);
  94.         lblVolt->setText(data);
  95.         //取電流
  96.         float circuit = (buf.at(5) << 8) + buf.at(6);
  97.         circuit += ((buf.at(7) << 8) + buf.at(8)) << 16;
  98.         data = QString("電流:%1 mA").arg(circuit);
  99.         QLabel* lblCircut = findChild<QLabel*>("lblCircut", Qt::FindChildOption::FindChildrenRecursively);
  100.         lblCircut->setText(data);
  101.         //取功率
  102.         power = (buf.at(9) << 8) + buf.at(10);
  103.         power += ((buf.at(11) << 8) + buf.at(12)) << 16;
  104.         power *= 0.1;
  105.         data = QString("功率:%1 W").arg(power);
  106.         QLabel* lblPower = findChild<QLabel*>("lblPower", Qt::FindChildOption::FindChildrenRecursively);
  107.         lblPower->setText(data);
  108.         //取頻率
  109.         qDebug("%02x-%02x", buf.at(17), buf.at(18));
  110.         float freq = ((unsigned char)buf.at(17) << 8) + (unsigned char)buf.at(18);
  111.         freq *= 0.1;
  112.         data = QString("頻率:%1 Hz").arg(freq);
  113.         QLabel* lblFreq = findChild<QLabel*>("lblFreq", Qt::FindChildOption::FindChildrenRecursively);
  114.         lblFreq->setText(data);
  115.         QLabel* serialState = findChild<QLabel*>("lblSerialState", Qt::FindChildOption::FindChildrenRecursively);
  116.         QString statebuf = QString("正在采集 %1 次").arg(i);
  117.         serialState->setText(statebuf);
  118.         //update 圖形
  119.         //PaintFrame* frame = findChild<PaintFrame*>("frame", Qt::FindChildOption::FindChildrenRecursively);
  120.         //frame->update(i, 140-(int)power, i, 140);
  121.     }
  122.     buf.clear();
  123. }
部分代碼下載(可能有錯誤,僅供參考): electricty.rar (8.6 KB, 下載次數: 0)
